Re: Any ideas on the likely problem - OBDII code P1130
Those engines do have a rep for bad mass airflow sensors. If you take the
sensor out and look inside the tube that sticks in the airstream, you'll
see a very fine little wire about an inch up inside. That's the sensing
wire, and if there is any crap on it it will cause some errant readings.
I've seen little bits of fibre from old air filters caught up in there
that can be easily extracted with tweezers. I've also had spotty success
spraying a solvent based cleaner inside the tube. You'll be replacing it
anyway, so if the sensing wire breaks while you try to clean it, you can
at least say you tried.
