lamp failure sensor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-30-2006, 10:31 PM   #1 (permalink)
paintaday@bellsouth.net
Guest
Posts: n/a
View paintaday@bellsouth.net's Photo Gallery
lamp failure sensor
My license plate bulb went out on my Avalon..........I replaced it, but
the idiot light on the dash still lights whenever I put the car in
gear.
How do I find the sensor in the trunk? What color is it.....? I want
to pull it out and reset it.
HELP!
Old 11-30-2006, 11:27 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: lamp failure sensor
<paintaday@bellsouth.net> wrote in message
news:1164947478.627019.93780@16g2000cwy.googlegroups.com...[color=blue]
> gear.
> HELP!
>[/color]
The lights out sensor for a '97 Avalon is in the trunk on the left wall
(from the perspective of standing behind the car looking forward) between
the trunk trim and sheet metal so you will have to remove the interior side
trim to get at the sensor. You did not mention what year Avalon you have,
but the sensor is likely to be in the same place. The sensor does not need
to be reset when you change bulbs.
The two most likely reasons that the warning light on the dash is still
illuminated is that there is another bulb burnt out or the incorrect
replacement bulb was used.
Before going through the trouble of getting at the sensor, re-check both
license plate bulbs, and all of the rear lights, including tail lights,
brake lights, turn signal bulbs, backup light bulbs, and center high mounted
stop lamp bulb.
Ray O
Old 12-02-2006, 10:55 AM   #3 (permalink)
jeparker49@gmail.com
Guest
Posts: n/a
View jeparker49@gmail.com's Photo Gallery
Ray O wrote:[color=blue]
> stop lamp bulb.
> --[/color]
[color=blue]
>From all that I've read, the warning light can be lit up even if all[/color]
the bulbs are "working" ... but if one (or more) of the bulbs is "on
its last legs" (discolored), that can be the cause. I'd advise
replacing ALL the bulbs (including the high mounted center brake light)
.... relatively cheap fix to avoid future frustrations with the warning
light!
Old 12-02-2006, 01:09 PM   #4 (permalink)
Ray O
Guest
Posts: n/a
<jeparker49@gmail.com> wrote in message
news:1165078524.405935.189300@73g2000cwn.googlegroups.com...[color=blue]
> Ray O wrote:[color=green]
>> mounted
>> stop lamp bulb.
>> --[/color]
>[color=green]
> light!
>[/color]
I believe that the lamp warning sensor works by detecting an open circuit
and is not capable of detecting whether a bulb is on its "last legs." The
OP probably has another bulb burnt out or a problem with wiring.
Ray O
Old 12-02-2006, 07:56 PM   #5 (permalink)
sharx35
Guest
Posts: n/a
View sharx35's Photo Gallery
"Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message
news:e2c31$4571cf61$47c2b532$7871@msgid.meganewsservers.com...[color=blue]
> news:1165078524.405935.189300@73g2000cwn.googlegroups.com...[color=green]
>> Ray O wrote:[color=darkred]
>>> mounted
>>> stop lamp bulb.
>>> --[/color]
>>[color=darkred]
>> light!
>>[/color]
> OP probably has another bulb burnt out or a problem with wiring.[/color]
I had that problem and it traced back to shorts in the wiring harness in the
vicinity of the left trunk lid hinge. Once those shorts were corrected, the
indicators shut off.
[color=blue]
> Ray O
>[/color]
Old 12-03-2006, 08:25 AM   #6 (permalink)
nospampls2002@yahoo.com
Guest
Posts: n/a
View nospampls2002@yahoo.com's Photo Gallery
sharx35 wrote:[color=blue]
> indicators shut off.[/color]
Same here, however, the wires were not broken or shorted, some of the
strands were broken.
The electronic sensor is grounded through the various bulb filaments
and will detect differences in resistance short (no pun intended) of an
entirely open or shorted circuit.
BB code is Off
Smilies are Off
[IMG] code is Off
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
