Re: 99 camry - engine light on - strange situation
<ravipb@yahoo.com> wrote in message
news:1165248255.801543.264450@16g2000cwy.googlegroups.com...[color=blue]
> I've a 99 toyota camry, never replaced the battery so far. I usually
> leave the day time lights on (switches automatically ON when the engine
> is started, and switches off
> automatically when the engine is shut down). This morning when I was
> ready for work and came to the car the head lights were ALREADY ON(!)
> and when I tried starting,
> the ENGINECHECK comes on and does not go off, and car engine cranks and
> never get started. If the battery is dead the head lights should not be
> ON correct? Any idea, if it is because of the dead battery or what the
> problem could be.
> Thanks in advance.
> -Ravi
>[/color]
The ignition system needs a little over 10 volts to start the car. It is
possible that the battery has drained below that point, but there is enough
voltage to illuminate the headlights. A 7 year old battery is probably due
for a replacement, especially if you live in a hot or cold climate. It is
possible that the daytime running light relay got stuck due to low battery
voltage. Start by getting the battery replaced and see if the headlight
problem cures itself.
Ray O
