Toyota Oil Filter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-04-2006, 11:21 AM   #1 (permalink)
Ron Jones
Guest
Posts: n/a
View Ron Jones's Photo Gallery
Toyota Oil Filter
I have read several test reports e.g.
[url]http://www.mr2.com/TEXT/oil_filter_test.html[/url]
That indicate the Toyota filter is "inferior" I'm hoping to find a good
aftermarket for my RAV4 V6 but since it just uses a filter element (not
canister) haven't found one yet. I use Purolator Pure One in my other cars
and motorcycle when I can get them.
Ron
Old 12-04-2006, 12:06 PM   #2 (permalink)
B A R R Y
Guest
Posts: n/a
View B A R R Y's Photo Gallery
Re: Toyota Oil Filter
Ron Jones wrote:[color=blue]
> That indicate the Toyota filter is "inferior"[/color]
That test is 11 years old.
Old 12-04-2006, 01:53 PM   #3 (permalink)
Coyoteboy
Guest
Posts: n/a
View Coyoteboy's Photo Gallery
B A R R Y wrote:[color=blue]
> Ron Jones wrote:[color=green]
> That test is 11 years old.[/color]
Cant access the URL. But the MR2 and Celica guys are generally of the
opinion that Toyota filters are the best, mainly due to the lack of
check valves in most aftermarket ones. Also the oil change interval on
a 3sgte engine is between 3K and 5K miles - in which time none of my
filters have looked particularly clogged and the oil rarely gets much
more than lightly browned.
Old 12-04-2006, 01:56 PM   #4 (permalink)
Coyoteboy
Guest
Posts: n/a
Coyoteboy wrote:[color=blue]
> B A R R Y wrote:[color=green]
> > Ron Jones wrote:[color=darkred]
> more than lightly browned.[/color]
Also that test is of questionable accuracy, when after 5 mins 0% of the
10 mic particles were filtered yet after another 5mins 1% were?
Old 12-04-2006, 07:33 PM   #5 (permalink)
=?iso-2022-jp?q?Hachiroku_=1B$B%O%A%m%=2F=1B=28B?=
Guest
Posts: n/a
View =?iso-2022-jp?q?Hachiroku_=1B$B%O%A%m%=2F=1B=28B?='s Photo Gallery
On Mon, 04 Dec 2006 17:21:46 +0000, Ron Jones wrote:
[color=blue]
> Ron[/color]
Wow...how things change.
Just about 20 years ago, Consumer Reports said something to the effect
that if you owned a Toyota, you were getting the best fiter made! Using
the same tests as cited in this report.
I was buying them by the case, since I had two Corollas that used the same
filter.
Old 12-04-2006, 09:13 PM   #6 (permalink)
Ron Jones
Guest
Posts: n/a
Here us another article
[url]http://www.corolland.com/oil-filters.html[/url]
that claims the Toyota filter is actually a Purolator but priced much
higher.
It likely makes a difference which car we are talking about. (this is for
Corolla)
rj
">[color=blue][color=green]
>> cars
>> Ron[/color]
> filter.
>[/color]
Old 12-04-2006, 10:15 PM   #7 (permalink)
Guest
Posts: n/a
On Tue, 05 Dec 2006 03:13:39 +0000, Ron Jones wrote:
[color=blue]
> higher.
> Corolla)
> rj[/color]
I try to make sure mine say "Made in Japan"
I believe they are Denso, if memory serves...
[color=blue]
> ">[color=green][color=darkred]
>>> cars
>>> Ron[/color]
>> filter.
>>[/color][/color]
BB code is Off
Smilies are Off
[IMG] code is Off
WTF! 2007 Camry SE Only Giving Me 263.7 mi WITH Full Tank! LunarMist 5th & 6th Generation (2002-2006 & 2007-2011) 262 01-15-2011 01:17 PM
Oil filter relocation warning! jeffmazz 1st Generation (1995.5–2004) 12 02-19-2009 01:24 PM
TOYOTA ENGINES AND OIL SLUDGE - WALL ST JOURNAL bondobondo General Discussion 99 02-02-2007 06:54 PM
Tsb Bulletin El Tano 5th & 6th Generation (2002-2006 & 2007-2011) 20 11-29-2006 12:47 PM
Toyota Oil Filter has changed (4-cyl) Tom 2000 Camry & Solara Lounge 11 01-04-2006 07:57 PM
