99 tacoma transmission slipping - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-04-2006, 01:34 PM   #1 (permalink)
shawn_h_25
Guest
Posts: n/a
View shawn_h_25's Photo Gallery
Hey group,does anyone know how hard it is to replace or adjust a tv
cable on a tacoma?the transmission is slipping bad.It was slipping 2
years ago and the dealer replaced the tv cable.Its showing the same
symptoms as then.Thanks for any advice.Shawn
Old 12-04-2006, 02:14 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 99 tacoma transmission slipping
"shawn_h_25" <shawn_h_25@yahoo.com> wrote in message
news:1165260871.605317.177440@j44g2000cwa.googlegroups.com...[color=blue]
>[/color]
I'm not sure what you mean by a "tv" cable, but assuming that you mean the
throttle cable for an automatic transmission, it will not have any effect on
a slipping transmission. A slipping transmission is usually caused by worn
friction surfaces, low pressures, bad automatic transmission fluid (ATF),
leaking valves, or weak springs. One of the symptoms of a slipping
transmission is ATF that is black or has a burnt smell.
A mis-adjusted throttle cable will affect how the transmission shifts.
Adjusting the throttle cable is not technically difficult - there is a
specification in the factory service manual, and you probably have to remove
the automatic transmission pan to gain access so plan on changing the ATF
while you are at it and replacing the pan gasket. Make sure you get the
correct type of ATF - it will be marked on the transmission dipstick and in
your owner's manual. You can get online access to factory service manuals
at techinfo.toyota.com for $10/day.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
99 Tacoma price tacomahu 1st Generation (1995.5–2004) 4 12-04-2009 09:58 AM
Supercharger and 7TH INJECTOR KIT on a 99 Tacoma? TTTacoma 1st Generation (1995.5–2004) 1 07-20-2006 02:49 PM
99 Tacoma 2.7 rough idle greg 79 f150 1st Generation (1995.5–2004) 8 03-10-2006 04:37 AM
99 Tacoma SR5 4x4 2.5" lift kit jatkinson 1st Generation (1995.5–2004) 1 11-26-2004 06:05 PM
