DuraCrap wires? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-07-2006, 09:10 PM   #1 (permalink)
=?iso-2022-jp?q?Hachiroku_=1B$B%O%A%m%=2F=1B=28B?=
Guest
Posts: n/a
View =?iso-2022-jp?q?Hachiroku_=1B$B%O%A%m%=2F=1B=28B?='s Photo Gallery
DuraCrap wires?
I did the plugs and wires on the Mazda today. I used NipponDenso plugs,
but cheaped out on the wires and went with Duralast (AutoZone).
Starting the car previously has been turning the key and the car jumps to
life. After replacing, turning the key resulted in a bit of a hesitation,
and a second or two of rough idling. After that it smoothed out and ran
well, and started well on subesquent turns of the key.
I'm surprised the car was running at all prior to the change. The manual
called for a gap of .030-.033, and the plugs that were in there were over
..080!
Old 12-07-2006, 10:43 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: DuraCrap wires?
"Hachiroku ????" <Trueno@AE86.gts> wrote in message
news:EQ3eh.2355$g_3.817@trndny02...[color=blue]
> .080!
>[/color]
If the car is fuel injected, check the coolant temperature sensor. If it is
carbureted, check the choke.
Ray O
Old 12-08-2006, 09:25 AM   #3 (permalink)
=?utf-8?B?SGFjaGlyb2t144OP44OB44Ot44Kv?=
Guest
Posts: n/a
View =?utf-8?B?SGFjaGlyb2t144OP44OB44Ot44Kv?='s Photo Gallery
Re: DuraCrap wires?
"Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message
news:444e1$4578e04f$47c2b532$24263@msgid.meganewsservers.com...[color=blue]
> news:EQ3eh.2355$g_3.817@trndny02...[color=green]
>> .080!
>>[/color]
> is carbureted, check the choke.
> Ray O
> (correct punctuation to reply)[/color]
Started it this morning at 16 degrees with a 6 degree Wind Chill. It started
and quit, and the second turn of the key it started and ran great.
However, there is a weird noise coming from somewhere around the rear of the
engine when it's cold, and it sounds like a bearing on the camshaft is
galling... :(
Old 12-08-2006, 12:38 PM   #4 (permalink)
Mark
Guest
Posts: n/a
View Mark's Photo Gallery
Re: DuraCrap wires?
I hate this cold weather, we were all the way down to something like 57
this morning. :-)
Hachirokuãƒ?ãƒ?ãƒ*ク wrote:[color=blue]
> news:444e1$4578e04f$47c2b532$24263@msgid.meganewsservers.com...[color=green]
> > news:EQ3eh.2355$g_3.817@trndny02...[color=darkred]
> >> Starting the car previously has been turning the key and the car jumpsto
> >> .080!
> >>[/color]
> > Ray O
> galling... :([/color]
Old 12-08-2006, 12:42 PM   #5 (permalink)
Ray O
Guest
Posts: n/a
Re: DuraCrap wires?
"Hachiroku????" <Trueno@ae_86.gts> wrote in message
news:QBeeh.6747$H22.4080@trndny09...[color=blue]
>>> to
>>> hesitation,
>>> over
>>> .080!
>>>[/color]
>> Ray O
> started and quit, and the second turn of the key it started and ran great.[/color]
That suggests a cold start enrichment problem. If fuel-injected, check the
coolant temp sender and whatever the engine uses for enrichment, either a
cold start injector, cold start timer.
[color=blue]
> the engine when it's cold, and it sounds like a bearing on the camshaft is
Try thinner oil.
Ray O
Old 12-08-2006, 09:02 PM   #6 (permalink)
Guest
Posts: n/a
Re: DuraCrap wires?
On Fri, 08 Dec 2006 11:42:08 -0600, Ray O wrote:
[color=blue]
> news:QBeeh.6747$H22.4080@trndny09...[color=green]
>> news:444e1$4578e04f$47c2b532$24263@msgid.meganewsservers.com...[color=darkred]
>>>> to
>>>> hesitation,
>>>> over
>>>> .080!
>>> Ray O
>[color=green]
> Try thinner oil.[/color]
I use 3 1/2 quarts Castrol 10W30, and 1 Qt Marvel Mystery oil...
Old 12-08-2006, 09:03 PM   #7 (permalink)
Guest
Posts: n/a
Re: DuraCrap wires?
On Fri, 08 Dec 2006 09:38:25 -0800, Mark wrote:
[color=blue]
> this morning. :-)[/color]
Up your WHAT, you say??? ;)
Actually, today was the first COLD day we've had. Shoot! LAST Thursday it
was 63 degrees!
Old 12-08-2006, 09:59 PM   #8 (permalink)
Ray O
Guest
Posts: n/a
Re: DuraCrap wires?
news:aPoeh.1172$%T5.1134@trndny05...[color=blue]
>[color=green]
>> news:QBeeh.6747$H22.4080@trndny09...[color=darkred]
>>>>> to
>>>>> hesitation,
>>>>> ran
>>>>> manual
>>>>> over
>>>>> .080!
>>>> it
>>>> Ray O
>>> great.[/color]
>> the
>>[color=darkred]
>>> is
> I use 3 1/2 quarts Castrol 10W30, and 1 Qt Marvel Mystery oil...[/color]
Try straight 5W-30 and see if the noise goes away.
Ray O
Old 12-09-2006, 01:08 AM   #9 (permalink)
larry moe 'n curly
Guest
Posts: n/a
View larry moe 'n curly's Photo Gallery
Re: DuraCrap wires?
Hachiroku ãƒ?ãƒ?ãƒ*ク wrote:
[color=blue]
[color=blue]
> I use 3 1/2 quarts Castrol 10W30, and 1 Qt Marvel Mystery oil..[/color]
I read somewhere that at -20F, with 5W-30 it takes about 30 seconds
before the oil reaches the valve train, but with 10W-30 it takes two
minutes.n I've heard lifter noise during the first few seconds with
10W-30 even at 40-50F.
Old 12-09-2006, 01:28 PM   #10 (permalink)
Danny G.
Guest
Posts: n/a
View Danny G.'s Photo Gallery
Re: DuraCrap wires?
"Hachiroku ????" <Trueno@AE86.gts> wrote in message news:7Qoeh.1175$%T5.428@trndny05...[color=blue]
>[color=green]
> was 63 degrees!
>[/color]
Brrrrrr!
It's red flag fire condition weather here.
Old 12-09-2006, 09:36 PM   #11 (permalink)
Guest
Posts: n/a
Re: DuraCrap wires?
On Fri, 08 Dec 2006 22:08:27 -0800, larry moe 'n curly wrote:
[color=blue]
>[color=green]
>[color=green]
> 10W-30 even at 40-50F.[/color]
I WISH it were Lifter noise!!! This is more like a screeching!!
BB code is Off
Smilies are Off
[IMG] code is Off
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 12:48 PM
90 Prizm Engine Removal - the wires? tashirosgt Archived Corolla threads 6 04-20-2006 10:22 PM
plugs & wires Abyss MR2 Forum 10 08-19-2005 12:36 AM
Tercel Clock wires? Help? gezebo Tercel, Paseo, Starlet, and Sera Forum 7 01-03-2005 04:44 PM
