1991 Camry starting problems. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-10-2006, 12:24 AM   #1 (permalink)
mimedic07
Guest
Posts: n/a
View mimedic07's Photo Gallery
I am having troubles with my fiance's 91 camry. it seems to have an
intermittnet drain on the battery, at times we can go for about a week
without a problem other times it is only about 4 hours and the battery
is dead. I have gone thru most of the wiring systems and not found
anything that looks as if it could be an issue. any help on this would
be greatly appreciated.
Old 12-10-2006, 01:31 AM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 1991 Camry starting problems.
"mimedic07" <brushjames@hotmail.com> wrote in message
news:1165728275.691464.111610@j44g2000cwa.googlegroups.com...[color=blue]
>[/color]
If the battery is more than 5 years old, it may need replacement. There
should be some kind of code on the label or molded into the top of the
battery case that indicates when it was installed. If the battery was ever
left in a discharged state for more than a couple of days, the battery may
be sulfated and has lost its ability to hold a charge.
Check the quality of the connections at the battery clamps. The clamps
should be clean and free of any buildup and tight. If there is any acid
effervescence built up on the terminals and/or clamps, while wearing old
clothes, gloves, and goggles, use an old toothbrush or battery terminal
brush, clean with a poultice of baking soda and water, making sure you rinse
the battery case, clamps, cables, and any surrounding metal thoroughly with
fresh water. A commercial battery terminal cleaner will also work. After
the terminals and clamps are clean, invest in some felt battery washers,
available at auto part stores, under the clamps. Then coat the clamps with
battery terminal protectant, also available at auto parts stores.
As far as intermittent drains, the first things I would check are
aftermarket accessories like audio, security, and remote starter systems
because they are common culprits. If there are any aftermarket accessories
connected directly to the battery, try disconnecting them Also check
interior lights, including glove box and map lights. There are 2 ways to
check for a drain - with an ammeter connected in series or by pulling 1 fuse
at a time until the problem goes away.
During cold or bad weather, using multiple high-draw accessories while the
engine is idling can result in parking the car with less than a fully
charged battery. For example, using the heater fan, rear defogger, and
headlights while idling uses a lot of electricity, and during short trips,
the battery may not get topped off. Try turning off the rear defogger a few
blocks before reaching the destination.
Ray O
Old 12-10-2006, 10:31 AM   #3 (permalink)
Fishface
Guest
Posts: n/a
View Fishface's Photo Gallery
mimedic07 wrote:[color=blue]
> be greatly appreciated.[/color]
"Seem to," you say, but do not describe your diagnostic procedure.
Are you certain the battery is dead? Could the problem be contacts
in the starter? [url]http://www.4x4wire.com/toyota/maintenance/starter/[/url]
Old 12-10-2006, 11:37 AM   #4 (permalink)
mimedic07
Guest
Posts: n/a
Fishface wrote:[color=blue]
> mimedic07 wrote:[color=green]
> in the starter? [url]http://www.4x4wire.com/toyota/maintenance/starter/[/url][/color]
I have concidered the possibility that it is the starter but the car
stats after a booster pack is attached. I have checked for a drain with
a test light and the light flashes (allmost like a blinker is on). I
have cleaned all the battery terminals an so forth. the batery is only
3 years old but we are unsure if it sat uncharged for any amount of
time since the car was purchased about a year ago.
Old 12-10-2006, 01:41 PM   #5 (permalink)
Ray O
Guest
Posts: n/a
news:1165768654.574912.43220@79g2000cws.googlegroups.com...[color=blue]
> Fishface wrote:[color=green]
>> mimedic07 wrote:[color=darkred]
>[/color]
I think that the next step is to have the battery and charging system
checked out. If you do not have a volt/ohm meter, I think it would be
worthwhile to invest in an inexpensive one. You can get a digital volt ohm
meter for under $30 at Radio Shack. There are some items that place a
normal drain on the battery, like the clock, radio pre-set memory, and
engine and transmission computer memory, but the draw should be in the
milliamp range. If the test light is flashing, try disconnecting any
aftermarket items in the car and remove the bulb for the courtesy light in
the trunk, if there is one to see if the flashing goes away.
Ray O
Old 12-10-2006, 05:27 PM   #6 (permalink)
Fishface
Guest
Posts: n/a
Ray O wrote:[color=blue]
> If the test light is flashing, try disconnecting any aftermarket items
> in the car and remove the bulb for the courtesy light in the trunk,
> if there is one to see if the flashing goes away.[/color]
Aftermarket alarm system, perhaps? If my brother-in-law installed
it, that could definitely be the problem! I like your idea of pulling
fuses in combination with the test light...
Old 12-11-2006, 01:24 AM   #7 (permalink)
Ray O
Guest
Posts: n/a
"Fishface" <invalid@ddress.ok?> wrote in message
news:wR%eh.1147$A05.943@trndny08...[color=blue]
> Ray O wrote:[color=green]
>[/color]
In my experience, aftermarket accessories cause more parasitic draw problems
than anything else in the car, with aftermarket alarms being the most common
culprit.
I have a nice Snap-On test light but I can't remember ever using it. A test
light's biggest shortcoming is that it will indicate the presence of voltage
but does not give an indication of what that voltage is. For example, 9
volts is enough to illuminate the test light but not enough to start the
car. I much prefer a volt meter for diagnosis.
Pulling the fuses in combination with a volt meter or test light is an old
trick for finding identifying the circuit with a parasitic draw. Once the
circuit is identified, then you have to find out what loads are on the
circuit and start checking each load. Since aftermarket accessories are the
most common cause of excess draws, I start looking there.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 09:42 PM
Toyota's Globalization Takes Shape through the Camry 2007CamryXLE 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-19-2006 07:52 PM
Toyota Camry Generations spdlva2nv4eva Camry & Solara Lounge 0 08-11-2006 12:45 AM
2001 Toyota Camry problems, is it cursed? flyboi 3rd & 4th Generation (1992–1996 & 1997–2001) 3 06-26-2006 02:43 AM
Fusion marches past Camry! sciguy0504 Camry & Solara Lounge 38 05-04-2006 07:27 AM
