I flushed and filled the cooling system. I ran the car for a LONG time
with the cap loose, then tightened the cap and ran it some more. I took it
for a drive yesterday, and, figuring the temp was rising and the fan was
kicking on while idling, everything was OK.
When the car is in motion, the temp guage barely moves above Cold. If I
let it sit and idle, it builds up heat, but drops again as soon as the car
starts moving.
I got a new thermostat, and installed it using the old thermostat, the
instructions on the box and my Haynes for instructions. Refilled, let the
car get good and HOT, sealed the system and went for a drive. Barely above
Cold again!
I used Peak anti-freeze, a new gasket, Hi Temp gasket compound, etc, etc.
I believe the system is bled out...ran the car until warm, ran it up to
about 2500 RiPpeMs for about 5 minutes, idle again till the fan cam on,
2500 RPMs again, then sealed the system and ran it until the fan came on.
Other than sticking a piece of plastic or cardboard in front of the
radiator, any other ideas?
BTW, the last time I ran the car, I left it idling for 5 minutes after a
10 minute drive, and anti-freeze was dripping out of the overflow bottle...
So both the new and old thermostat are doing the same thing? I'm not
quite sure which one you used by your saying: "> I got a new
thermostat, and installed it using the old thermostat"
Somethings to check: direction of the thermostate, position of the
jiggle valve that lets air out. You probably have a big air pocket that
pushes the coolant out after 10 minutes of running.
In general, too much cooling can point to a stucked-open thermostat,
but overflowing can point to a stucked-closed thermostat.
Hachiroku ãƒ?ãƒ?ãƒ*ク wrote:[color=blue]
> On my Mazda:
> starts moving.
> Cold again!
> 10 minute drive, and anti-freeze was dripping out of the overflow bottle....[/color]
On Sun, 10 Dec 2006 17:01:55 -0800, johngdole wrote:
[color=blue]
> thermostat, and installed it using the old thermostat"[/color]
Should have said "...using the old thermostat as a guide"
I also did what Haynes told me to...
[color=blue]
> pushes the coolant out after 10 minutes of running.[/color]
Wouldn't that cause overheating? And, the way I did it should have bled
the system out.
As far as the 'jiggle valve', the old one didn't HAVE one! Usually the
'jv' goes to the top, so that's where I put it.
[color=blue]
> but overflowing can point to a stucked-closed thermostat.[/color]
Yeah! I don't get it!
[color=blue]
> Hachiroku ãƒ?ãƒ?ãƒ*ク wrote:[color=green]
>> On my Mazda:
>> starts moving.
>> Cold again!
>> 10 minute drive, and anti-freeze was dripping out of the overflow bottle...[/color][/color]
"Hachiroku ????" <Trueno@AE86.gts> wrote in message
news:Po1fh.528$it5.123@trndny06...[color=blue]
> On my Mazda:
> starts moving.
> Cold again!
> bottle...
>[/color]
What is the opening temperature on the replacement thermostat? In most
cars, the thermostat spring should be oriented down.
I forget whether your car has a transverse-mounted engine, but if it does,
check to make sure the electric cooling fan is not stuck on. If it has a
longitudinally mounted engine, make sure the fan clutch is disengaging.
Coolant mix should be 50-50 - straight coolant causes problems like freezing
and overheating.
On Mon, 11 Dec 2006 00:40:25 -0600, Ray O wrote:
[color=blue]
> news:Po1fh.528$it5.123@trndny06...[color=green]
>> On my Mazda:
>> starts moving.
>> Cold again!
>> bottle...
>>[/color]
> and overheating.[/color]
Wow...the one I took out didn't have a 'jiggle valve' in it (lunched
through the cooling system?) but the holes where it would go were at the
top. I put the new one in the same way.
I also replaced the cap today. I know on some Caravans/Voyagers, if the
cap is shot the same thing happens. No go...
I had a two-hour wait for tires today ($29 each...woo hoo!) and I let the
car run for about 40 minutes. I think perhaps the mistake I was making was
opening the radiator cap to top it off. I started using the overflow
bottle and it seems to be getting better, but, I noticed a big puddle of
coolant under the car, that wasn't seeming to come from the overflow
bottle. I believe a new (reman'd) water pump might be in order, too.
<sigh> I chickened out! I'm having the belt and the pump replaced Friday
by a local garage, and the struts done all the way around by another.
AutoZone has a tool loaner program, but I didn't like the looks of the
spring compressor they were loaning out...
> On my Mazda:
> starts moving.
> Cold again!
> bottle...[/color]
Hachi -
When you let it idle until it 'warms up', what does the temperature gauge
read? And when you drive it and it cools off, does the gauge go all the
way back to cold?
news:Gslfh.2962$%T5.1276@trndny05...[color=blue]
>[color=green]
>> news:Po1fh.528$it5.123@trndny06...[color=darkred]
>>> On my Mazda:
>>> it
>>> car
>>> starts moving.
>>> the
>>> above
>>> Cold again!
>>> etc.
>>> on.
>>> bottle...
>>>[/color]
>> does,
>> freezing
> cap is shot the same thing happens. No go...[/color]
A bad radiator cap usually causes overheating, not lack of heat.
[color=blue]
> bottle. I believe a new (reman'd) water pump might be in order, too.[/color]
Yup, after you get the radiator mostly full, top off from the overflow
bottle and let the radiator suck it in.
Look for the source of the puddle under the car. You could go from lack of
heat to meltdown pretty quickly.
[color=blue]
>[/color]
I would tackle the t belt and water pump if there is a reasonably warm place
to work on the car.
I don't do struts because doing them without a wall-mounted professional
strut compressor is very dangerous, and you need to get an alignment
afterwards anyway.
On Mon, 11 Dec 2006 17:48:31 -0600, Ray O wrote:
[color=blue][color=green]
>>[/color]
> to work on the car.[/color]
On Mon, 11 Dec 2006 15:11:32 -0800, mack wrote:
[color=blue]
>> On my Mazda:
>> starts moving.
>> Cold again!
>> bottle...[/color]
> Hachi -
> way back to cold?[/color]
Goes up to halfway, the fan kicks on, and as long as it idles, it acts OK.
When you drive the car it goes down almost all the way to cold.
news:2Emfh.1287$e26.827@trndny04...[color=blue]
>[color=green][color=darkred]
>>>[/color]
>> place
> I have a heated garage. Get your ass out here! ;)
>[/color]
On Tue, 12 Dec 2006 01:07:31 -0600, Ray O wrote:
[color=blue]
> news:2Emfh.1287$e26.827@trndny04...[color=green]
>>[color=darkred]
>>> place
>>[/color]
> That's tempting![/color]
You know where I live (basically!)
It'a actually been kind of nice here lately. Saturday was about 48, and
Sunday was *almost* 60. Today got over 48. Pretty good weather for being
outside at this time of year!
news:lbFfh.1514$e26.1254@trndny04...[color=blue]
>[color=green]
>> news:2Emfh.1287$e26.827@trndny04...[color=darkred]
>>>>> Friday
>>>> place
>>>> to work on the car.
>>>[/color]
> outside at this time of year![/color]
We had single digit temps over the weekend, but close to 50 degrees today
around here. Of course, nothing ever needs fixin' when the weather is nice!
