camshaft timing marks 3a - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-10-2006, 07:47 PM   #1 (permalink)
Larry
Guest
Posts: n/a
View Larry's Photo Gallery
Hello, I am new to this group. I am up to my elbows in 83 tercel. The
timing belt broke the other day. I am rotating the camshaft looking for
marks that line up. What am I looking for?
Also, I have not felt anything go bump. Is this indeed a
non-interferance engine?
Old 12-10-2006, 08:18 PM   #2 (permalink)
=?iso-2022-jp?q?Hachiroku_=1B$B%O%A%m%=2F=1B=28B?=
Guest
Posts: n/a
View =?iso-2022-jp?q?Hachiroku_=1B$B%O%A%m%=2F=1B=28B?='s Photo Gallery
Re: camshaft timing marks 3a
On Sun, 10 Dec 2006 16:47:51 -0800, Larry wrote:
[color=blue]
> non-interferance engine?[/color]
That is an Interference engine. Hopefully, the engine was idling when the
belt broke! There may be some chance it's OK if it was at idle.
The marks should be an arrow, a dot, or an indent on the crank shaft and
cam shaft. Be sure #1 is at TDC!
I think at this point I would remove the valve cover just to make sure
this is worth doing.
Interesting. I looked at [url]www.autozone.com[/url] for a timing belt and they do
NOT say it is an Interference engine. I had an '83 AWD Wagon and was told
by a Toyota tech that the engine WAS interference!
Oh, wait...upon further inspection:
Timing type and interval for a
1983 Toyota Tercel
Interference engine application
substantial and costly engine damage can occur if
belt breaks or slips.
It is recommended at every 60,000 miles or every 48
months to replace timing belt regardless of the
condition.
It IS interference. I would crack the Valve cover and have a look!
Old 12-10-2006, 09:08 PM   #3 (permalink)
Larry
Guest
Posts: n/a
I will pop the valve cover tomorrow. And, no, I had my foot in it
getting onto the highway. Wish me luck.
Hachiroku ãƒ?ãƒ?ãƒ*ク wrote:[color=blue]
>[color=green]
> 1983 Toyota Tercel
> condition.
> It IS interference. I would crack the Valve cover and have a look![/color]
Old 12-10-2006, 09:23 PM   #4 (permalink)
Dave L
Guest
Posts: n/a
View Dave L's Photo Gallery
"Hachiroku ????" <Trueno@AE86.gts> wrote in message
news:rl2fh.3303$Z67.2138@trndny02...[color=blue]
>[color=green]
> 1983 Toyota Tercel
> condition.
Went to the Gates website
@http://www.gates.com/brochure.cfm?brochure=2256&location_id=3487, and
clicked on the Timing Belt Replacement Guide. Although belt manufacure
suggests 60k mile changes, it does not have the " * " next to it indicating
it is an interference engine. Based on the Gates website, it is a
"non-interference" engine. He can breathe easy! Many Toys are
non-interference. Hondas on the other hand...
Hope this helps,
-Dave
Old 12-10-2006, 10:00 PM   #5 (permalink)
Guest
Posts: n/a
On Sun, 10 Dec 2006 21:23:04 -0500, Dave L wrote:
[color=blue]
> news:rl2fh.3303$Z67.2138@trndny02...[color=green]
>>[color=darkred]
>> 1983 Toyota Tercel
>> condition.
> Hope this helps,
> -Dave[/color]
Yeah, I know. Gates says no, but Toyota and AZ say yes.
This has been a mystery that has plagued this group for ages!
Old 12-10-2006, 10:02 PM   #6 (permalink)
Guest
Posts: n/a
On Sun, 10 Dec 2006 18:08:18 -0800, Larry wrote:
[color=blue]
> getting onto the highway. Wish me luck.[/color]
Oh, dear...
Good luck. But, before popping the cover, I would wait for Ray O, or if
you're lucky, Ray O AND Qslim to weigh in. I'm just a hack. Those guys are
for real! (Ray was a Factory Rep, and qslim, until recently was an MDT for
Toyota...)
[color=blue]
> Hachiroku ãƒ?ãƒ?ãƒ*ク wrote:[color=green]
>>[color=darkred]
>> 1983 Toyota Tercel
>> condition.
>> It IS interference. I would crack the Valve cover and have a look![/color][/color]
Old 12-10-2006, 10:44 PM   #7 (permalink)
Dave L
Guest
Posts: n/a
news:lR3fh.4105$IG6.1739@trndny01...[color=blue]
>[color=green]
>> news:rl2fh.3303$Z67.2138@trndny02...[color=darkred]
>>> the
>>> told
>>> 1983 Toyota Tercel
>>> condition.
>> indicating
>> Hope this helps,
>> -Dave[/color]
> This has been a mystery that has plagued this group for ages![/color]
If Toyota says yes, I'd go with that. What better resource than the people
who designed it!
Old 12-11-2006, 01:56 AM   #8 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"Larry" <larry_balogh@msn.com> wrote in message
news:1165798071.583048.294760@73g2000cwn.googlegroups.com...[color=blue]
>[/color]
It has been around 15 years since I looked at the innards of one of those
engines. Set #1 cylinder to TDC compression. There should be a line on the
outside of one of the teeth on the camshaft pulley. Rotate the camshaft so
that the line is pointing straight up and lines up with a notch on the head.
As a general rule, Toyotas with timing belts are non-interference and those
with chains are interference, but I think the 3A engine was an exception to
that rule.
Before you install the timing belt, see if you can rotate the camshaft
freely. If it jams, then you will have to pull the head to check the
valves.
Ray O
Old 12-11-2006, 01:58 AM   #9 (permalink)
Ray O
Guest
Posts: n/a
news:6T3fh.4106$IG6.1475@trndny01...[color=blue]
>[color=green]
> Oh, dear...
> Toyota...)
>[/color]
I guess I should have kept all those factory repair manuals I left behind -
Every factory service manual for every Toyota from 1983 - 1993, including
wiring diagrams, New Model Features, and TSB's :-(
Ray O
Old 12-11-2006, 08:18 AM   #10 (permalink)
Larry
Guest
Posts: n/a
I will pull the valve cover to help insure proper cam timing. Maybe
then I will recognize the marks on the camshaft. The camshaft plops
over evenly. I am going to put a belt on it and do a quick compression
check, soon as it stops raining. Thanks all, and I will keep you
informed.
Ray O wrote:[color=blue]
> news:1165798071.583048.294760@73g2000cwn.googlegroups.com...[color=green]
> >[/color]
> that rule.
> valves.
> Ray O
> (correct punctuation to reply)[/color]
Old 12-11-2006, 05:56 PM   #11 (permalink)
Guest
Posts: n/a
On Mon, 11 Dec 2006 00:58:01 -0600, Ray O wrote:
[color=blue]
> news:6T3fh.4106$IG6.1475@trndny01...[color=green]
>>[color=darkred]
>> Oh, dear...
>> Toyota...)
>>[/color]
> wiring diagrams, New Model Features, and TSB's :-([/color]
Um...YEAH!! ;)
Old 12-11-2006, 06:06 PM   #12 (permalink)
Ray O
Guest
Posts: n/a
news:Rmlfh.1278$e26.282@trndny04...[color=blue]
>[color=green]
>> news:6T3fh.4106$IG6.1475@trndny01...[color=darkred]
>>> Oh, dear...
>>> are
>>> for
>>> Toyota...)
>>>[/color]
>> behind -
> Um...YEAH!! ;)
>[/color]
Nobody ever accused me of having foresight!
Ray O
Old 12-13-2006, 04:38 AM   #13 (permalink)
Larry
Guest
Posts: n/a
Started the car up today! I played with rotating the crank with the cam
in different positions. I do not believe that this is an interference
engine. Thanks to all.
> news:Rmlfh.1278$e26.282@trndny04...[color=green]
> >[color=darkred]
> >>> Oh, dear...
> >>> are
> >>> for
> >>> Toyota...)
> >> behind -
> > Um...YEAH!! ;)
> >[/color]
> Ray O
Old 12-13-2006, 10:21 PM   #14 (permalink)
Guest
Posts: n/a
On Wed, 13 Dec 2006 01:38:06 -0800, Larry wrote:
[color=blue]
> engine. Thanks to all.[/color]
Congrats! Did you do the belt yourself?
The 4WD wagon was a weird car. The engine was North-South, and had an
extra 'pumpkin' in the front. The timing belt was real easy to get at,
since it had an electric fan and the front of the engine was open.
[color=blue]
> Ray O wrote:[color=green]
>> news:Rmlfh.1278$e26.282@trndny04...[color=darkred]
>> >>> Oh, dear...
>> >>> are
>> >>> for
>> >>> Toyota...)
>> >> behind -
>> > Um...YEAH!! ;)
>> >[/color]
>> Ray O
>> (correct punctuation to reply)[/color][/color]
Old 12-14-2006, 12:47 PM   #15 (permalink)
Larry
Guest
Posts: n/a
Doing the belt was not very difficult. Removing the radiator gave me
plenty of room. I could probably do one now in less than two hours. I
doubt I will have the opportunity, the last one lasted 195,000 mi. The
engine is using more oil these days, 500-600 mi. to the quart,
compression on the cylinders is in the low to mid 90's. I was ready to
let it go if the repair was much more involved. I use it now to take
two Labs out to play. It works well on slippery unpaved roads taking
tired, muddy dogs home.
>[color=green]
>[color=green]
> > Ray O wrote:[color=darkred]
> >> >>> Oh, dear...
> >> >>> are
> >> >>> for real! (Ray was a Factory Rep, and qslim, until recently was anMDT
> >> >>> for
> >> >>> Toyota...)
> >> >> behind -
> >> > Um...YEAH!! ;)
> >> Ray O
> >> (correct punctuation to reply)[/color][/color][/color]
BB code is Off
Smilies are Off
[IMG] code is Off
My Timing belt change (very detailed, pics) Gen 4 JerryGiese 3rd & 4th Generation (1992–1996 & 1997–2001) 164 11-10-2011 07:40 AM
Changing V6 Timing Belt Pics and the $270 Coil Connector marc780 5th & 6th Generation (2002-2006 & 2007-2011) 77 02-04-2011 07:08 PM
starlet EP80 timing belt marks paulo lanca Tercel, Paseo, Starlet, and Sera Forum 12 11-07-2006 06:45 PM
NEED HELP: Timing Belt Marks Question turbox2k Camry & Solara Lounge 1 08-16-2005 01:06 PM
V6 camshaft timing information ('cause Toyota, Chilton's & Haynes don't explain it) Toysrme Hardcore Tech and Competition 0 02-19-2005 06:40 PM
