diagnose wheel bearing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-13-2006, 06:49 PM   #1 (permalink)
Ralph
Guest
Posts: n/a
View Ralph's Photo Gallery
1993 Corolla LE 7A-FE about 300,000 km (186,300 mi)
Front wheel bearing
It sounds like I may have a front wheel bearing worn out. Is there any
definitive diagnosis?
I can't hear anything grinding when I jack up the car and spin the wheel.
These bearings are friction-fit and I would like to avoid letting it go too
long and damaging the hub. The left bearing has already been replaced.
A passenger reports feeling vibration from the right front wheel. One day I
heard an intermittent milling sound which was interrupted by curving. I
don't hear this most days.
Your expert opinion is invited.
- Jack
Old 12-13-2006, 11:48 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: diagnose wheel bearing
"Ralph" <nospam@thanks.com> wrote in message
news:45809f95_2@news.cybersurf.net...[color=blue]
> Front wheel bearing
> too long and damaging the hub. The left bearing has already been
> replaced.
> I heard an intermittent milling sound which was interrupted by curving. I
> - Jack[/color]
It is difficult, if not impossible, to diagnose a sound without actually
hearing the sound. If the noise changes with road speed and increases in
frequency or amplitude when making a left turn, the right wheel bearing
should be checked. Unfortunately, you have to remove the bearing and look
at its condition to determine whether it is bad or not.
Other possible sources of rotational noises are brakes, CV joints, and
differential bearings.
Ray O
Old 12-14-2006, 07:39 AM   #3 (permalink)
Ralph
Guest
Posts: n/a
Thanks again Ray O!
- Jack
Old 12-14-2006, 08:29 AM   #4 (permalink)
nospampls2002@yahoo.com
Guest
Posts: n/a
View nospampls2002@yahoo.com's Photo Gallery
Ralph wrote:[color=blue]
> definitive diagnosis?[/color]
The Factory Service Manual has a specification to check wheel bearing
end play.
It is in the section on brakes, near the part about using a dial
indicator to check disk rotor runout.
See:
Old 12-14-2006, 08:29 AM   #5 (permalink)
Guest
Posts: n/a
end play.
Old 12-14-2006, 11:21 AM   #6 (permalink)
Joe Schmuckatelli
Guest
Posts: n/a
View Joe Schmuckatelli's Photo Gallery
On Wed, 13 Dec 2006 19:49:22 -0500, "Ralph" <nospam@thanks.com> wrote:
[color=blue]
>Front wheel bearing
I just had my front bearings done. It sounded like a growling or
rumbling noise at 40/50+ mph, so I'm not certain you'd hear anything
from spinning the wheel by hand.
Old 12-14-2006, 12:15 PM   #7 (permalink)
Ray O
Guest
Posts: n/a
news:45815422$1_2@news.cybersurf.net...[color=blue]
> Thanks again Ray O!
> - Jack[/color]
You're welcome!
Ray O
Old 12-14-2006, 03:04 PM   #8 (permalink)
SAMMM
Guest
Posts: n/a
View SAMMM's Photo Gallery
you might jack it up and try to wiggle the wheel, top to bottom.
if there's any difference from the other side (which shouldn't have
ANYplay),
then you need a wheel bearing.
good luck, sammm
<nospampls2002@yahoo.com> wrote in message
news:1166106549.532305.123890@j72g2000cwa.googlegroups.com...[color=blue]
> Ralph wrote:[color=green]
> end play.
> See:
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
sounds of a wheel bearing? bowlofturtle General Discussion 2 06-16-2005 04:09 PM
My wheel bearing or not? Ghost Archived Corolla threads 7 06-07-2005 04:49 AM
Boro wheel bearing repair? Nick Hardcore Tech and Competition 3 10-26-2003 08:43 PM
