<porter_pody_69@hotmail.com> wrote in message
news:1166217664.333839.155980@79g2000cws.googlegroups.com...[color=blue]
> first of all i dont even know if it is nesisary to change the fluid. it
> pops out of first gear when i start off, this problem is only with
> first, the other gears work fine.
> if changing the fluid would help, HOW DO YOU DO IT???? i dont want to
> go to a garoge becaus i have no money but i cant figer out how to do it
> my self.
> PS i also got a sudgestion that the shifter seat or bushing or what
> ever its called could need replacing. if true how is it done?
>[/color]
I doubt if changing the transmission fluid would help, but if you would like
to change it, place a suitable container under the transmission, remove the
drain plug, and let the old fluid drain out. Replace the drain plug, remove
the filler plug, and re-fill the transmission. You will probably need a
siphon or pump to re-fill the transmission because the filler plug is
probably a little over halfway up the side of the transmission case. When
fluid starts to dribble out of the filler opening, the transmission is full.
The person who provided the suggestion that the shifter bushing would cure
the problem was a Toyota Master Diagnostic Technician who worked at a
dealership. I have never seen him give out bad technical advice, so that is
probably what it will take to fix the problem.
I would have to look at the shifter mechanism to be sure, but my guess is,
to replace the shifter bushing, you remove the shifter boot from inside the
vehicle, remove the access cover on top of the shifter, remove the old
shifter bushing, install the new one, and put everything back together.
Ray O wrote:[color=blue]
> news:1166217664.333839.155980@79g2000cws.googlegroups.com...[color=green]
> > my self.
> >[/color]
> Ray O
> (correct punctuation to reply)[/color]
thanks. i gess i will try doing both after all new fluid wouldnt hurt
it!
I used Valvoline synthetic (think its 75W) and it made my transmission
quieter and easier to shift especially in the cold. Its a good ide to make
sure you can remove the fill plug on the side before removing the drain plug
on the bottom.
"Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message
news:e5163$45839bfa$47c2b532$20627@msgid.meganewsservers.com...[color=blue]
> news:1166234393.302179.273880@n67g2000cwd.googlegroups.com...[color=green]
>> Ray O wrote:[color=darkred]
>>> > it
>>> > it
>>> > my self.
>>> like
>>> the
>>> remove
>>> When
>>> full.
>>> cure
>>> that is
>>> is,
>>> the
>>> Ray O
>> it!
>>[/color]
> Start with the shifter bushing if you want to cure the popping out of gear
> problem. Good luck and make sure you use the correct transmission fluid
> when changing it.
> Ray O
>[/color]
