95 corolla fuel filter fitting, - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-16-2006, 06:24 AM   #1 (permalink)
buckky65@gmail.com
Guest
Posts: n/a
View buckky65@gmail.com's Photo Gallery
i had the same problem, but i got it out, fitting is cross treaded,
where can i get just the fitting and reflare it too the tubing, can't
seem too find aNYONE LOCALLY IN NY WHERE I LIVE, CHARLIE...
Old 12-16-2006, 10:30 AM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 95 corolla fuel filter fitting,
<buckky65@gmail.com> wrote in message
news:1166271842.022670.299170@j72g2000cwa.googlegroups.com...[color=blue]
>[/color]
Any competent automotive shop should be able to make the repair. Flare-nut
wrenches should be used to loosen and tighten the fittings without damage.
To re-flare the tubing, the damaged part has to be cut off, preferably with
a tubing cutter, and then re-flared with a flaring tool. The problem with
cutting off the damaged tubing is that it will probably be too short to
re-connect and so you will have to replace the entire fuel line or splice in
a section of tubing which I do not recommend due to the possibility of fuel
leaks and fires.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
Fuel fitting 97camryman Camry & Solara Lounge 0 01-27-2006 12:37 PM
1998 Corolla - Where to buy the fuel filter that's under the hood? Anthony1 Archived Corolla threads 7 01-05-2006 03:47 PM
Fuel filter -90 corolla roch00 Archived Corolla threads 5 08-14-2005 02:28 AM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 04:01 PM
Fuel Filter Woes cosmicbutthairs Archived Corolla threads 3 06-08-2003 09:43 AM
