"Shallowrunner" <shallowrunner2002@yahoo.com> wrote in message
news:1166401675.043901.283690@16g2000cwy.googlegroups.com...[color=blue]
> Ray....Not really sure how to perform the rap the block test..but here
> is what I did. I plugged one lead end of my DVM to the KNK position on
> the ECU connector. I did disconnect the connector from the ECU. I then
> grounded my other leak end to the ground cable that was disconnected
> from my battery. I set my meter to AC and displayed zero millivolts. I
> rapped the block a few times and saw that I was detected an increase in
> millivolt signals. It went from zero to about 2.5 millivolts and went
> higher the harder I tapped. Is this telling me that the knock sensor
> circuit is good? If it is the case....then what is my issue? Could the
> valves or rocker arms be causing this fault? Would this affect my
> timing issue? I am totally confused.
> Shallowrunner[/color]
I don't know if the voltage generated by the knock sensor is AC or DC, but I
would imagine that it would be DC since it is essentially static
electtricity. The higher voltage generated by harder tapping suggests that
the knock sensor and circuit is operating normally.
AFAIK, the knock sensor
circuit does not measure voltage, just frequency. For example, more
knocking creates more pulses, and as long as the pulses are coming, the ECU
retards ignition timing until the knocking stops.
I would clear the codes by pulling the EFI fuse and see if the code returns.
You might want to try leaving the knock sensor unplugged and set the base
ignition timing correctly and see if the engine runs better. Perhaps a
knocking signal from the sensor is retarding the timing, which is why base
timing had to be so advanced - the ECU was retarding timing so it needed to
be pretty advanced so that it could retard.
While the engine is running, you might also use an engine stethoscope or a
screwdriver with a long shank against the block to see if you can hear any
mechanical knocking that the knock sensor might pick up.
Ray O
