PLEASE HELP!!!! 91 4runner problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-18-2006, 09:25 PM   #1 (permalink)
91HoRunner
Guest
Posts: n/a
View 91HoRunner's Photo Gallery
when i drive it i have to hold the gas pedal all the way down and it
takes a while to get up to speed especially on the high way then
sometimes when i let off a little bit the rpms drop and so does the
speed...also sometimes the rps will go all the way up to 5 till it
kicks in to the next gear...the car did sit for 2 yrs before i bought
it and the toyota mechanic said it may need to be driven for a while
but i have been for 2 months or so...
Posted at author's request, using [url]http://www.AutoBoardz.com[/url] interface
Articles individually verified to usenet standards. Visit URL to contact author/report abuse
Thread archive: [url]http://www.AutoBoardz.com/HELP-91-4runner-problem-Toyota-ftopict200958.html[/url]
Old 12-18-2006, 09:52 PM   #2 (permalink)
=?iso-2022-jp?q?Hachiroku_=1B$B%O%A%m%=2F=1B=28B?=
Guest
Posts: n/a
View =?iso-2022-jp?q?Hachiroku_=1B$B%O%A%m%=2F=1B=28B?='s Photo Gallery
Re: PLEASE HELP!!!! 91 4runner problem
On Tue, 19 Dec 2006 03:25:51 +0000, 91HoRunner wrote:
[color=blue]
> when i drive it i have to hold the gas pedal all the way down and it takes
> a while to get up to speed especially on the high way then sometimes when
> i let off a little bit the rpms drop and so does the speed...also
> sometimes the rps will go all the way up to 5 till it kicks in to the next
> gear...the car did sit for 2 yrs before i bought it and the toyota
> mechanic said it may need to be driven for a while but i have been for 2
> months or so...[/color]
Now is the tranny giving you trouble?
Does it sputter when you put your foot down? Bad gas (you've filled it up,
right?)
But my guess, as a quick fix, is the Fuel Filter.
Old 12-19-2006, 12:49 AM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"91HoRunner" <none@000.com> wrote in message
news:952800_ca0a1bdb1422e979994175a752de4d34@autoboardz.com...[color=blue]
>[/color]
I recommend that you have a competent technician go with you on a road test
to determine the problem. Possible causes are a restriction in the exhaust,
vacuum leak, contaminated MAF sensor, bad spark plugs, bad high tension
wires, bad spark advance, clogged fuel filter, and bad gas.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
Shifting problem on 92' 4runner Alaska 4Runner Lounge 0 06-08-2006 01:05 AM
1990 4Runner, problem while accelerating JamMasterJules 4Runner Lounge 1 03-24-2006 08:49 PM
Problem with cruise control - 4runner 1993 400km 4Runner Lounge 0 01-03-2006 07:25 PM
4Runner V6 engine problem johnwruss 4Runner Lounge 3 04-24-2005 02:32 AM
Corolla 91' Problem faisal Archived Corolla threads 4 02-25-2004 02:31 PM
