Re: Air leak in fuel system?
"Ernie Sty" <fake_email@yahoo.com> wrote in message
news:MZGdnTDW8b6uOxXYnZ2dnUVZ_ua3nZ2d@giganews.com...[color=blue]
>I have an older car with fuel injection. If it gets parked with the front
>end higher than the rear for any length of time, you have to crank it for
>at least five minutes, even if you move it to a flat place or with the rear
>end higher, before it'll start. When you start cranking it doesn't fire at
>all, then fires intermittently a pop every few revs, then gradually more
>and more firings until it can run on its own. (of course I don't crank for
>five minutes continuously or the starter would overheat.)
> I'm guessing there's a slight air leak in the fuel system? Or is it
> something else?[/color]
first check that the pump runs at turn on, then check how much pressure
there is, then check that it is rich enough to start, a whiff of carb
cleaner in the air intake will show if it is not rich enough.
It sounds like there is a lack of richness and that warming the engine (and
getting lots of neat fuel in the cylinders) by lots of cranking brings it up
to a state where it can stumble into life.
Mrcheerful
