1990 4runner v6 automatic wont move? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-22-2006, 06:46 PM   #1 (permalink)
Guest
Posts: n/a
View :\'s Photo Gallery
Fluid is full but never gets warm/hot on dipstick. I think the pump in
the transmission isnt working. Where it the pump? Can I get to it if
I pull the pan?? Thanks:)
Old 12-22-2006, 11:46 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 1990 4runner v6 automatic wont move?
":) :)" <porshapower@webtv.net> wrote in message
news:504-458C7C49-90@storefull-3332.bay.webtv.net...[color=blue]
>[/color]
The pump is operated by the transmission input shaft behind the bell
housing. The transmission has to come out of the vehicle to get to the
pump.
Before you pull the transmission, you can check pump operation with a
transmission pressure gauge hooked up to the test ports.
What is the condition of the ATF? How many miles are on the transmission,
when is the last time it was serviced, and what service(s) were performed?
Ray O
Old 12-23-2006, 01:08 AM   #3 (permalink)
Guest
Posts: n/a
Hello Ray:) Ive only owned it for a month. The fluid looks like new
but Im thinking they may have changed it before they sold it to me.
They had it rebuilt around 80,000 miles ago at a reputable transmission
shop. How would I test the pressure at the test ports? Am I wasting
my time pulling the pan? Anything under there that could not make it
move? Thanks Ray!! :)Chris
Old 12-23-2006, 11:56 AM   #4 (permalink)
Ray O
Guest
Posts: n/a
news:508-458CD5ED-390@storefull-3336.bay.webtv.net...[color=blue]
>[/color]
If the fluid looks brand new, I would suspect that it was changed or flushed
recently. If the transmission accumulated 80,000 miles without service and
was then flushed, it is possible that flushing dislodged some sludge and
clogged an internal passage somewhere. If the previous owner only changed
the fluid, then servicing should not have caused a problem.
To test pressure at the test ports, remove the test port plug and screw in
the lead for the transmission pressure gauge. Read and record pressure at
idle and at stall speed. The stall test should be conducted over as short a
time as possible, preferably under 20 seconds. A stall test is where you
chock the wheels, set the parking brake, put your left foot firmly on the
service brake pedal, put the transmission in gear, and rev the engine as
high as it will go. Pressures at idle and at stall speed should be steady
and not fluctuating. You can check pressure specifications and interpret
pressures with a repair manual.
Another possible cause is a problem with the shift solenoids. The
transmission has several electrical components - a speed sensor at the
tailshaft, the lockup control near the bell housing, and shift solenoids in
between. With the transmission in gear, there should be 12 volts coming to
the solenoids. Again, a repair manual will show solenoid location and which
solenoids should have voltage under which conditions, although normally,
erratic or incorrect shifting is the symptom from bad shift solenoids.
One more possible cause is a problem with the transmission computer and
related wiring.
It is possible that there is a problem with the valve body which is inside
the transmission pan, but it is unlikely to be apparent with just a visual
inspection, and checking it requires compressed air with a rubber nozzle and
a repair manual to show how the various ports should react when air pressure
is applied.
Ray O
Old 12-23-2006, 06:41 PM   #5 (permalink)
Guest
Posts: n/a
Hello Ray:) Thank You very much for the help. Im going to check the
pressures and go from there. I will post after the holidays on my
findings. Thanks again and Happy Holidays:)
Old 12-23-2006, 09:05 PM   #6 (permalink)
Ray O
Guest
Posts: n/a
news:500-458DCCB6-1735@storefull-3332.bay.webtv.net...[color=blue]
>[/color]
You're welcome!
BTW, there is another possibility, and that is that the shift linkage is
broken or disconnected.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
1st issue with 07'Camry AESANTIAGO 5th & 6th Generation (2002-2006 & 2007-2011) 949 01-08-2008 02:49 PM
F/S 1999 Toyota 4Runner SR5 V6 (York PA) snoviking 4Runner Lounge 0 06-13-2006 09:19 PM
1990 V6 Rim Size blkdmnrcing 1st & 2nd Generation (1983–1986 & 1987-1991) 3 12-13-2005 07:31 PM
1990 V6 Bad Cold Run Problem jtorbitt 1st & 2nd Generation (1983–1986 & 1987-1991) 2 09-30-2003 08:23 PM
