toyota automatic starlet cd - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-23-2006, 10:31 AM   #1 (permalink)
snooch34
Guest
Posts: n/a
View snooch34's Photo Gallery
my car won't start every time. It will usually start 1st thing but if I
leave the car for 1/2 hr or more then try and start the car again it won't
turn over. I did put it in gear then back to park which seemed to help
somehow at 1st but now it won't start until about 6 or more trys. The
garage thought it was the inhibitor but checked it & said everything looks
& seems fine but the problem seems to be getting worse. I drove 40miles
last week stopped then got back in & wouldn't start so it's not the
battery. Any ideas anyone???pls help?
Old 12-23-2006, 11:40 AM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: toyota automatic starlet cd
"snooch34" <suzib_34@hotmail.com> wrote in message
news:ad3fdb51c55fec7487a1e923bfaf23be@localhost.talkaboutautos.com...[color=blue]
>[/color]
It is possible that the contacts on the starter solenoid are worn and need
replacement. If inspection of the solenoid shows worn or damaged
contact, the contacts are available as replacement parts (at least in the
U.S.). If you cannot get replacement contacts, then you may have to replace
the starter solenoid or entire starter.
There is a neutral safety switch in the transmission that only allows the
starter to engage if the transmission is in park or neutral. If it does not
start in park but does start in neutral, have the transmission neutral
safety switch checked.
Ray O
Old 12-23-2006, 03:41 PM   #3 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
"Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message
news:4bb23$458d6dff$47c2b532$15932@msgid.meganewsservers.com...[color=blue]
> news:ad3fdb51c55fec7487a1e923bfaf23be@localhost.talkaboutautos.com...[color=green]
>> won't
>> looks
>>[/color]
> replace
> not
>[/color]
What Ray said.
You did not describe the symptom with very much detail, but Ray hit the two
top suspects. Given the symptom you describe, I'd put the Neutral Safety
Switch ahead of the starter relay or selonoid, but like I said, your
description is a bit lacking. If you try Ray's ideas, you'll hit the
possible things.
BB code is Off
Smilies are Off
[IMG] code is Off
Avalon shows dent in Toyota quality sciguy0504 Toyota News 98 03-25-2007 11:49 PM
Tsb Bulletin El Tano 5th & 6th Generation (2002-2006 & 2007-2011) 20 11-29-2006 12:47 PM
I just found this article your comments on this? dario Camry & Solara Lounge 18 07-26-2005 09:39 PM
Ford, Nissan license Toyota hybird technology EKam Toyota News 1 01-30-2005 03:25 PM
