Hi, I have a 1993 Camry Wagon and I just replaced the battery. When I
did so the stereo went into a security mode. The display just reads
"SEC" right now. I know the 3 digit code to unlock the stereo, but I do
not have an owner's manual anymore so I do not know how to enter the
code.
Can anyone explain to me the steps involved in entering the code? Or is
there somewhere I can obtain a PDF of the owner's manual or a scan of
the stereo pages? Thanks for your help.
On Sat, 23 Dec 2006 11:08:28 -0800, Jeff Van Boxtel wrote:
[color=blue]
> Hi, I have a 1993 Camry Wagon and I just replaced the battery. When I did
> so the stereo went into a security mode. The display just reads "SEC"
> right now. I know the 3 digit code to unlock the stereo, but I do not have
> an owner's manual anymore so I do not know how to enter the code.
> there somewhere I can obtain a PDF of the owner's manual or a scan of the
> stereo pages? Thanks for your help.[/color]
Try this:
Question
The battery on my 95 Avalon was removed by my son and now the radio or CD
player will not play. I have to the correct security codes but I have lost
my owners manuel. Can you help me input the security codes so i can listen
to the radio? the !2 disc CD changer quit working a long time ago but it
would be nice to be able to listen to the radio. You haelp would be
greatly appreceated.
Answer
i believe that you use only the first 4 digits to input the code example code 5351
button 1 press 5 times
button 2 press 3 times
button 3 press 5 times
button 4 press 1 time and after that you press the am fm button or tunner
button sorry i can not help more
Or:
but with the key in the ignition on acc ...
the screen display SEC
push and hold the "UP" button on the right ...
that will then display _ _ _ ... 3 blank spots ...
input your code ...
then press and hold "SCAN" on the top left withing 10
seconds of completing the code
hope thats it ???
Suprathai
Sep 12 2006, 10:17 AM
Cool thanks, I'll try it tomorrow...I thought it was a
bit more intensive then that. Something with holding down the numbers 1
and 3 and a bunch of other numbers. Anyways if it doesn't work then I'll
be back. In the meantime...Thanks.
Cheers
Suprathai
Sep 12 2006, 10:52 PM
This is for a corolla conquest, headunit is different
to the sportivos. Could someone help me out urgently please!! Plenty of
karma to the person that helps out.
IT WORKED. I think your key needs to be on the 'ON' position also press
numbers 1,2 or 3 to start entering the code.
On my BMW, the code is entered by pressing the Station Select Buttons. On my
cars, the buttons are numbered 1 - 6, and the code digits are all 6 or less.
I simply press the buttons in the correct sequence to input the code.
"Jeff Van Boxtel" <sailorh@gmail.com> wrote in message
news:1166900907.981290.65820@73g2000cwn.googlegroups.com...[color=blue]
> code.
>[/color]
I would like to caution you to NOT attempt to enter the code until you know
the proper procedure. Back to my BMW example, if the wrong code is input,
the system will lock out and stop allowing the input of any codes. When this
happens, the ignition must remain in ON, but not START, for an hour or so to
reset the Attempt Counter.
Obviously, Toyota and BMW might not do this the same way, but in the event
they do, you want to avoid incorrect input of the code.
> code.
>[/color]
"Jeff Strickland" <crwlr@yahoo.com> wrote in message
news:A4udnalrvtyaGhDYnZ2dnUVZ_uqvnZ2d@ez2.net...[color=blue]
> my cars, the buttons are numbered 1 - 6, and the code digits are all 6 or
> less. I simply press the buttons in the correct sequence to input the
> code.
>[/color]
On a Toyota, if you input the incorrect code too many times, the radio goes
into lockdown mode and you have to take it to a dealer and pay money to get
it unlocked. I would not attempt a BMW programming sequence on a Toyota.
ok you have 4 shots before it goes in to HELP lock mode. You have like 10
seconds to complete the code entry. If invalid key is hit you'll get a
temporary ERR.
1. Make sure radio is off with ignition key to ACC
2. while holding the "1 PROG" and the "6" button in, press and hold the
PWR/VOL knob until "SEC" appear on the display
3. press the "1 PROG" button while holding the "TUNE FF " button and the
tape operation indicator will appear on display
4. Input your id # by pressing the "1 PROG", "2 APS" and "3 RPT" buttons
repeately. the "1 PROG" for first digit, "2 APS" for second, and "3 RPT"
for third. So if # were 345 - pres 1 4x, 2 5x and 3 6x. If the disply goes
to "---" while inputing, try again.
I didn't know about the 10 second limit - was too careful and locked mine
up! Dealer wanted $80 to reset so its still sitting in garage. Was a
really stupid antitheft feature - glad they dropped it.
> code.
>[/color]
On Sat, 23 Dec 2006 19:52:33 -0500, "Wolfgang"
<NOwolfXgang_dieterxSPAM@NOXcox.netNOT> wrote:
[color=blue]
>really stupid antitheft feature - glad they dropped it.[/color]
No, it's a really good security feature, but not implemented so well
- it should be more intuitive. And it only got bad after the dealers
decided to turn radio unlocking into a Major Profit Center.
The cars are getting old enough that they should ease up on the
Unlock Code security concerns a bit, or they're going to annoy
potential new car buyers. Do the unlock and clear the code for $5 or
$10 and write the rest off to 'Goodwill'.
What was originally meant to stop thefts of fairly State Of The Art
radios out of new cars is going to have a bunch of Transportation Car
and Beater Car Owners (fourth and fifth owners that didn't know there
even was a code feature on the radio, let alone what the code is)
cursing at Toyota over having to replace the radio simply because they
had a stupid car battery go dead...
Make them mad when keeping their old car running, and they will
remember it when it's time to go buy their First Really "New" new car.
In my case the dealer really turned me off --- he claimed he'd have to hook
the computer up to it to unlock it. Even after I said NO you enter some key
combo and then a code to reset it - he argued with me. Guess the key combo
required is secret even to the dealer. ( I do have the supposed secret
code - but not the key combo to be able to enter it). And this was the
dealer from which I had purchased the vehicle years earlier.
"Bruce L. Bergman" <blPYTHONbergman@earthlink.invalid> wrote in message
news:9r8so29pt7l87d51bdavgijiebrp3dute5@4ax.com...[color=blue]
>[color=green]
> --<< Bruce >>--
>[/color]
Wolfgang, this seems to work, but after I enter the code do I need to
press a final "enter" button? How do I tell it I am finished with the
code? I tried waiting and it resets back to saying "---" Does this mean
I have the code wrong?
Also you mention if my number is 3 to press the button 4x.. Did you
mean 3x?
Thanks again for the help.
On Dec 23, 4:52 pm, "Wolfgang" <NOwolfXgang_dieterxS...@NOXcox.netNOT>
wrote:[color=blue]
> temporary ERR.
> "Jeff Van Boxtel" <sail...@gmail.com> wrote in messagenews:1166900907.981290.65820@73g2000cwn.googlegroups.com...
>[color=green]
> > code.[/color]
>[color=green]
> > the stereo pages? Thanks for your help.- Hide quoted text -- Show quoted text -[/color][/color]
The final step is to press and hold SCAN as suggested by Hachiroku.
Thank you all so so much for your help! Finally I can listen to music
on the commute to work again. You guys have all really made my day!!
On Dec 25, 7:41 am, "Jeff Van Boxtel" <sail...@gmail.com> wrote:[color=blue]
> Thank you everyone for your information and help.
> mean 3x?
> wrote:
>[color=green]
> > temporary ERR.[/color]
>[color=green]
> > to "---" while inputing, try again.[/color]
>[color=green]
>[color=green]
> > "Jeff Van Boxtel" <sail...@gmail.com> wrote in messagenews:1166900907.981290.65820@73g2000cwn.googlegroups.com...[/color]
>[color=green][color=darkred]
> > > code.[/color][/color]
> > > the stereo pages? Thanks for your help.- Hide quoted text -- Show quoted text -- Hide quoted text -- Show quoted text -[/color][/color][/color]
On Mon, 25 Dec 2006 08:15:47 -0800, Jeff Van Boxtel wrote:
[color=blue]
> Haha, nevermind.
> The final step is to press and hold SCAN as suggested by Hachiroku. Thank
> you all so so much for your help! Finally I can listen to music on the
> commute to work again. You guys have all really made my day!![/color]
You're welcome! Enjoy!
If there's one thing I can't stand, it's driving without a radio!
Merry Christmas!
[color=blue]
> On Dec 25, 7:41 am, "Jeff Van Boxtel" <sail...@gmail.com> wrote:[color=green]
>> Also you mention if my number is 3 to press the button 4x.. Did you mean
>> 3x?
>> wrote:
>>[color=darkred]
>> > like 10 seconds to complete the code entry. If invalid key is hit
>> > you'll get a temporary ERR.[/color]
>>[color=darkred]
>> > 1. Make sure radio is off with ignition key to ACC 2. while holding
>> > the "1 PROG" and the "6" button in, press and hold the PWR/VOL knob
>> > until "SEC" appear on the display 3. press the "1 PROG" button while
>> > holding the "TUNE FF " button and the tape operation indicator will
>> > appear on display 4. Input your id # by pressing the "1 PROG", "2
>> > APS" and "3 RPT" buttons repeately. the "1 PROG" for first digit, "2
>> > APS" for second, and "3 RPT" for third. So if # were 345 - pres 1 4x,
>> > 2 5x and 3 6x. If the disply goes to "---" while inputing, try again.[/color]
>>[color=darkred]
>> > mine up! Dealer wanted $80 to reset so its still sitting in garage.
>> > Was a really stupid antitheft feature - glad they dropped it.[/color]
>>[color=darkred]
>>[color=darkred]
>> > > I did so the stereo went into a security mode. The display just
>> > > reads "SEC" right now. I know the 3 digit code to unlock the stereo,
>> > > but I do not have an owner's manual anymore so I do not know how to
>> > > enter the code.[/color]
>>[color=darkred]
>> > > is there somewhere I can obtain a PDF of the owner's manual or a
>> > > scan of the stereo pages? Thanks for your help.- Hide quoted text --
