2006 Camry JBL radio harness? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-27-2006, 09:43 PM   #1 (permalink)
Netsirk
Guest
Posts: n/a
View Netsirk's Photo Gallery
I'm having trouble finding a wiring harness for my 2006 Camry.
It is the JBL unit, with the in-dash 6-CD changer. It has a "SAT"
button, but no satellite radio. I have the separate JBL amp behind the
glove compartment (it's marked 86280-AA074). The amp has two plugs on
it.
How can I get rid of the head unit and seperate amp, and use my
aftermarket unit (I already have the mounting bracket that fits where
the JBL head unit is).
I can't seem to find the harness for this anywhere. Do I have options?
Thanks
Old 12-27-2006, 10:06 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 2006 Camry JBL radio harness?
"Netsirk" <netsirk@nc.rr.com> wrote in message
news:1167277393.420532.185340@42g2000cwt.googlegroups.com...[color=blue]
> it.
> Thanks
>[/color]
Try crutchfield.com.
Ray O
Old 12-28-2006, 11:05 AM   #3 (permalink)
=?iso-2022-jp?q?Hachiroku_=1B$B%O%A%m%=2F=1B=28B?=
Guest
Posts: n/a
View =?iso-2022-jp?q?Hachiroku_=1B$B%O%A%m%=2F=1B=28B?='s Photo Gallery
On Wed, 27 Dec 2006 19:43:13 -0800, Netsirk wrote:
[color=blue]
> It is the JBL unit, with the in-dash 6-CD changer. It has a "SAT" button,
> but no satellite radio. I have the separate JBL amp behind the glove
> compartment (it's marked 86280-AA074). The amp has two plugs on it.
> aftermarket unit (I already have the mounting bracket that fits where the
> JBL head unit is).
> Thanks[/color]
Try Wal*Mart. The connector is specific to the car, not the radio. They
have them for $7.
The only problem here is presented by the amp. I am not sure if the head
unit sends out a low-level signal or if there is an attenuator built into
the amp. I know on Chryslers there is an attenuator in the amp, so you can
plug in any moderate-powered head unit, but Toyota may work differently.
If you plan on bypassing the amp, there are companies that make a harness
that attach the incoming connector to the outgoing connector, but the only
place I an aware to buy these is online. If you're handy with an ohm meter
you can figure this out yourself, or look online for a diagram...
Good Luck!
Old 12-28-2006, 11:21 PM   #4 (permalink)
cat06
Guest
Posts: n/a
View cat06's Photo Gallery
cool
Netsirk wrote:[color=blue]
> it.
> Thanks[/color]
Old 12-28-2006, 11:46 PM   #5 (permalink)
Guest
Posts: n/a
[color=blue]
> compartment (it's marked 86280-AA074). The amp has two plugs on it.[/color]
Take a look at Scosche's web site. I believe I saw something there for JBL
car audio.
[color=blue]
> JBL head unit is).
> Thanks[/color]
Old 12-31-2006, 11:34 AM   #6 (permalink)
Netsirk
Guest
Posts: n/a
Well, it turns out that I didn't need a harness that fit the plug at
the amp.
Also, I didn't need a harness that fit either radio plug.
Thanks to an installer at my local Circuit City, I was able to get this
done.
The standard Toyota harness that you can get anywhere will work - the
trick is to find the place to plug them in. The cables are tied down
under the radio, where you can't see them. Digging them up reveals the
standard connectors, unplug them and nothing goes to the Amp anymore,
so it can be removed. I didn't even need to expose the amp - you can
do the whole job right in the dash area thanks to those connectors
being there.
Thanks for the replies
> it.
> Thanks[/color]
Old 12-31-2006, 08:44 PM   #7 (permalink)
Guest
Posts: n/a
On Sun, 31 Dec 2006 09:34:00 -0800, Netsirk wrote:
[color=blue]
> Well, it turns out that I didn't need a harness that fit the plug at the
> amp.
> done.
> standard connectors, unplug them and nothing goes to the Amp anymore, so
> it can be removed. I didn't even need to expose the amp - you can do the
> whole job right in the dash area thanks to those connectors being there.
> Thanks for the replies[/color]
Thanks for the info! As you can see, my 'guess' was wrong. Bet your 'gums'
I'll file this one away for future reference!
[color=blue]
> Netsirk wrote:[color=green]
>> it.
>> Thanks[/color][/color]
BB code is Off
Smilies are Off
[IMG] code is Off
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 11:48 AM
98 camry radio install/amp bypass dontbesojumpy 3rd & 4th Generation (1992–1996 & 1997–2001) 11 08-04-2009 08:07 AM
1st issue with 07'Camry AESANTIAGO 5th & 6th Generation (2002-2006 & 2007-2011) 949 01-08-2008 02:49 PM
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 10:55 PM
