I need advice about car stereos and must admit I know noting about them.
My pre-owned Toyota Camry came with an in-dash cassette/receiver which
also controls a cd-changer that sits in the trunk. There is a free
pocket just below this receiver. I want to get rid of that changer in
the trunk---it is too much hassle, and also keeps getting bumped by
luggage, grocery bags, and like.
I am considering following solutions:
(1) An in-dash cd player that would go into the free pocket and work
with the existing cassette receiver. It need not and probably should
not have its own radio, amplifier, etc. It could be one disc player or
a changer.
(2) An entirely new cd-cassette-radio player. This seems wasteful but
if it is the best option, or the cheapest or something like that, I
would consider it.
I would appreciate advice from those who know car stereos. Brands, as
well as the kind of stores I should go to (Chicago area). I don't need
MP3, satellite radio etc, just "cd cassette AM FM".
Ajanta wrote:[color=blue]
> a changer.
> would consider it.
> Thanks.[/color]
crutchfield.com has excellent service, and can set you up
with a unit that will fit. They will also provide a wiring
adapter. If you don't mind something a little garish looking, the
Sony 'Explod' AM/FM/Cassette unit is good, and inexpensive. If
you want a more 'classic' look, there are other manufacturers
with units that should fit. Crutchfield sells them all.
"Ajanta" <ajanta@null.void> wrote in message
news:271220062254435530%ajanta@null.void...[color=blue]
> mjc <DELETETHIS>13"@verizon.net> wrote:
> : crutchfield.com has excellent service, and can set you up
> : with a unit that will fit. They will also provide a wiring
> : adapter. If you don't mind something a little garish looking, the
> : Sony 'Explod' AM/FM/Cassette unit is good, and inexpensive. If
> : you want a more 'classic' look, there are other manufacturers
> : with units that should fit. Crutchfield sells them all.
> If I do mail order, where should I go to get it installed?[/color]
Where in the Chicago area are you? Anywhere near Woodfield Mall?
On Thu, 28 Dec 2006 04:54:42 GMT, Ajanta <ajanta@null.void> wrote:
[color=blue]
>: with units that should fit. Crutchfield sells them all.[/color]
[color=blue]
either a car stereo shop, or a mechanic. You just need somebody capable
of pulling the stereo out of the dash and of inserting connectors.
On Thu, 28 Dec 2006 04:09:11 +0000, Ajanta wrote:
[color=blue]
> also controls a cd-changer that sits in the trunk. There is a free pocket
> just below this receiver. I want to get rid of that changer in the
> trunk---it is too much hassle, and also keeps getting bumped by luggage,
> (1) An in-dash cd player that would go into the free pocket and work with
> the existing cassette receiver. It need not and probably should not have
> its own radio, amplifier, etc. It could be one disc player or a changer.
> (2) An entirely new cd-cassette-radio player. This seems wasteful but if
> it is the best option, or the cheapest or something like that, I would
> consider it.
> I would appreciate advice from those who know car stereos. Brands, as well
> as the kind of stores I should go to (Chicago area). I don't need MP3,
> Thanks.[/color]
There are a few car stereos that incorporate the AM/FM/Cassette/CD, but
they are kind of expensive. Can you ditch the Cassette, or do you have a
large variety?
Also, what kind of changer is located in the trunk? There are some units,
ie, Kenwood, Sony, Clarion that have propreitary adapters to only work
with a macthing head unit, 'generic' adapters, such as Sony's D-Bus that
are compatible among head units, or have a built-in FM transmitter that
sends the signal from the CD to the radio via a pre-set (changable) FM
frequency, like some of the XM radios do.
What year Camry is it? Most of the installations of aftermarket radios
into a Toyota are real easy; you can pick up a wiring harness adapter at
Wal*Mart for $7 that works with ANY Toyota from 1980-present. All
aftermarket radios now use the same color coding for the wires, and the
adapter uses the same color scheme, so fitting the new radio is easy;
match the colors to the new adapter harness, twist and secure with
electrician's tape, snap the harness in and bolt the radio in! That simple.
UNLESS, the person before you cut the wires to put in the new radio. Then
it's a bit more difficult, but if it is a recent radio it will still be
the same color scheme, so you can clip the wires from the existing radio
leaving a bit of the colored wire behind, and again match them up, splice
and cover with tape. Either that, or, hopefully the person that installed
the radio left the markers on the wiring explaining which wire is which
connection.
Removal of the dash panel is pretty straightforward; there are usually
screws under the top of the bezel that can be viewed by looking up above
the ashtray, usually above the heater controls. Also, you will need to
pull the ashtray and remove the two screws you'll see, and then the screws
holding the metal 'snuff plate' (as I call it) and then GENTLY unsnapping
the bezel. Again, knowing which year we're dealing with will help here.
The radios are usually secured to the dash using 4 10mm screw/bolts, I
suggest using a 10mm socket since they are soft and if you don't have the
correct screwdriver you'll strip the heads. Then the radio and the pocket
come out as one unit, and there are screws on the side of the radio
securing the bracket to the radio.
Almost every single radio sold now has holes on the side marked "T" and
"N", T for Toyota and N for Nissan. Place the brackets in the holes marked
"T" and use the screws you removed to secure the bracket, then snap the
harness together and mount the radio. It's a fairly simple process, and,
again, unless the harness was cut out, should take less than an hour!
And, another hint: I get most of my aftermarket radios from e-Bay. The
only problem I have had so far was I bought an Eclipse there, and the 13
pin harness (WHO THE HELL thought up a 13 pin harness?!?!?!) was missing
and the radio is 'keyed' to a CD the original owner had. I wouldn't buy an
Eclipse unless the harness is included and the seller either tells you or
provides you with the CD he used as a 'key'! They are REALLY good stereos,
however! Since I only paid $15 for it, eh...live and learn. I can send it
to Fujitsu to have it reset...but I digress.
If you decide to do this yourself, I'm almost always here every day, and
would be glad to answer any more questions.
Hachiroku ãƒ?ãƒ?ãƒ*ク wrote:
[color=blue]
> to Fujitsu to have it reset...but I digress.[/color]
Hachiroku,
Regarding your eBay adventures, are you buying new radios or used? Do
you have a reliable seller?
news:271220062319395243%ajanta@null.void...[color=blue]
> Ray O wrote:
> : Where in the Chicago area are you? Anywhere near Woodfield Mall?
> I can drive anywhere within reasonable distance. Woodfield would be ok.
> Although I would imagine that many suitable stores would be nearer. I
> just don't know them.[/color]
Most places that sell automotive audio systems like Circuit City and Best
Buy also do installations. If you have the installation kit and adapter
harness and you were close by, I might even pop it in myself.
On Thu, 28 Dec 2006 13:24:54 -0500, BCDrums wrote:
[color=blue]
>[color=green]
>> an Eclipse unless the harness is included and the seller either tells
>> you or provides you with the CD he used as a 'key'! They are REALLY good
>> stereos, however! Since I only paid $15 for it, eh...live and learn. I
>> can send it to Fujitsu to have it reset...but I digress.[/color]
> Hachiroku,
> Regarding your eBay adventures, are you buying new radios or used? Do you
> Thanks!
> BC[/color]
I'll have to check it. There was one guy from Vancouver, IIRC, that was
very good. I bought 2 JVC MP3 players from him. But all the radios I
bought from e-Bay were no problem, except for the Eclipse.
Hachiroku ãƒ?ãƒ?ãƒ*ク wrote:[color=blue]
>[color=green]
>>consider it.
>>Thanks.[/color]
> large variety?
>[/color]
I'm *fairly* sure that the Sony 'Explod' stereo I mentioned
has a CD changer controller as well as the cassette deck, but I
don't know if it's proprietary. That's a question that
Crutchfield could also answer. I mention this model not because
it looks like a jukebox or video game (which, unfortunately, it
does), but because it's made in Thailand, where they actually
have labor unions and decent working conditions.
On Thu, 28 Dec 2006 21:29:39 +0000, mjc<DELETETHIS>13 wrote:
[color=blue]
> Hachiroku ãƒ?ãƒ?ãƒ*ク wrote:[color=green]
>>[color=darkred]
>>>with the existing cassette receiver. It need not and probably should not
>>>have its own radio, amplifier, etc. It could be one disc player or a
>>>changer.
>>>consider it.
>>>Thanks.[/color]
>> large variety?
>> units, ie, Kenwood, Sony, Clarion that have propreitary adapters to only
>> work with a macthing head unit, 'generic' adapters, such as Sony's D-Bus
>> that are compatible among head units, or have a built-in FM transmitter
>> that sends the signal from the CD to the radio via a pre-set (changable)
>> FM frequency, like some of the XM radios do.
>>[/color]
> has a CD changer controller as well as the cassette deck, but I don't know
> if it's proprietary. That's a question that Crutchfield could also answer.
> I mention this model not because it looks like a jukebox or video game
> (which, unfortunately, it does), but because it's made in Thailand, where
> they actually have labor unions and decent working conditions.[/color]
Most of the stuff I buy says Made In Japan.
I tend to shy away from the Made in China stuff...
: There are a few car stereos that incorporate the AM/FM/Cassette/CD, but
: they are kind of expensive. Can you ditch the Cassette, or do you have a
: large variety?
I do have a cassette collection but also, at $2 each rather than $10-15
pr cd's, tend to buy cassettes when traveling overseas, to experiment
with music that seems interesting but not a sure bet.
Thank you for your detailed advice. My car is 1998 Camry LE 6-cylinder
4-door sedan. The in-dash cassette receiver is branded "Toyota" and is
working just fine. There is free pocket below it. The cd changer in the
trunk has some other name ("Eclipse"? I'll have to look). I want to get
rid of it because it tends to get bumped by luggage and sometimes won't
play unless I stop the car, open the trunk, and reset it.
So ideally, I would just want a cd player that would go into the free
pocket and connect to the cassette receiver. I don't really want a new
AM/FM/Cassette/CD unit, I am just prepared to consider it if
it is the only solution.
: Also, what kind of changer is located in the trunk? There are some units,
: ie, Kenwood, Sony, Clarion that have propreitary adapters to only work
: with a macthing head unit, 'generic' adapters, such as Sony's D-Bus that
: are compatible among head units, or have a built-in FM transmitter that
: sends the signal from the CD to the radio via a pre-set (changable) FM
: frequency, like some of the XM radios do.
: What year Camry is it? Most of the installations of aftermarket radios
: into a Toyota are real easy; you can pick up a wiring harness adapter at
: Wal*Mart for $7 that works with ANY Toyota from 1980-present. All
: aftermarket radios now use the same color coding for the wires, and the
: adapter uses the same color scheme, so fitting the new radio is easy;
: match the colors to the new adapter harness, twist and secure with
: electrician's tape, snap the harness in and bolt the radio in! That simple.
: UNLESS, the person before you cut the wires to put in the new radio. Then
: it's a bit more difficult, but if it is a recent radio it will still be
: the same color scheme, so you can clip the wires from the existing radio
: leaving a bit of the colored wire behind, and again match them up, splice
: and cover with tape. Either that, or, hopefully the person that installed
: the radio left the markers on the wiring explaining which wire is which
: connection.
: Removal of the dash panel is pretty straightforward; there are usually
: screws under the top of the bezel that can be viewed by looking up above
: the ashtray, usually above the heater controls. Also, you will need to
: pull the ashtray and remove the two screws you'll see, and then the screws
: holding the metal 'snuff plate' (as I call it) and then GENTLY unsnapping
: the bezel. Again, knowing which year we're dealing with will help here.
: The radios are usually secured to the dash using 4 10mm screw/bolts, I
: suggest using a 10mm socket since they are soft and if you don't have the
: correct screwdriver you'll strip the heads. Then the radio and the pocket
: come out as one unit, and there are screws on the side of the radio
: securing the bracket to the radio.
: Almost every single radio sold now has holes on the side marked "T" and
: "N", T for Toyota and N for Nissan. Place the brackets in the holes marked
: "T" and use the screws you removed to secure the bracket, then snap the
: harness together and mount the radio. It's a fairly simple process, and,
: again, unless the harness was cut out, should take less than an hour!
: And, another hint: I get most of my aftermarket radios from e-Bay. The
: only problem I have had so far was I bought an Eclipse there, and the 13
: pin harness (WHO THE HELL thought up a 13 pin harness?!?!?!) was missing
: and the radio is 'keyed' to a CD the original owner had. I wouldn't buy an
: Eclipse unless the harness is included and the seller either tells you or
: provides you with the CD he used as a 'key'! They are REALLY good stereos,
: however! Since I only paid $15 for it, eh...live and learn. I can send it
: to Fujitsu to have it reset...but I digress.
: If you decide to do this yourself, I'm almost always here every day, and
: would be glad to answer any more questions.
On Fri, 29 Dec 2006 00:30:11 +0000, Ajanta wrote:
[color=blue]
> : large variety?
> I do have a cassette collection but also, at $2 each rather than $10-15 pr
> cd's, tend to buy cassettes when traveling overseas, to experiment with
> AM/FM/Cassette/CD unit, I am just prepared to consider it if it is the
> only solution.[/color]
Whoa! Eclipse is Good Stuff! Maybe I'll throw you a few bucks for it!
I'd move it to under the driver's seat, myself. Since it is an Eclipse,
unless there is a direct connection to your radio (meaning you have a
Fujitsu Radio...) then does it tune into the radio, or is there a button
on the radio to allow control of the changer from the stock radio?
This is interesting...
The only place you're going to find a direct-connect CD changer is from
Toyota, or from a junkyard or e-Bay. I'd like to see this setup so I could
tell what is needed! A lot of the stock Toyota radios through the 80's and
into the 90's had a DIN connector on the back of them to plug in other
accessories such as a CD deck or an Equalizer. But, even though DIN
'means' STANDARDIZED, it is not possible to tell if one manufacturer's
pinout matches another's pin-in! If you can get a look at the back of the
radio and see if there is a DIN connector that is plugged into a socket,
then you may be able to get something that will work.
I can't remember how Fujitsu marks their units. At one time, even though
the radio said TOYOTA on it, there was also another little mark on the
faceplate that defines the MFG; a small Capital N with a lightening
bolt for National (Panasonic), or what kind of looked like the GE (General
Electric) 'meatball' with the word "TEN" across it for Fujitsu. (See, I DO
remember!) If one of these marks is on there, it will help even further;
I'm willing to bet since it is an Eclipse changer then it's probably a
Fujitsu head unit...
If you find something, let me know!
There is another way to tell...the National branded radios had REALLY good
FM reception (almost TOO good! Stations splashed over each other) while
the FM section on the Fujitsu's wasn't as good, but the tape section
sounded GREAT! (but that's a generalization...)
: Whoa! Eclipse is Good Stuff! Maybe I'll throw you a few bucks for it!
: I'd move it to under the driver's seat, myself. Since it is an Eclipse,
: unless there is a direct connection to your radio (meaning you have a
: Fujitsu Radio...) then does it tune into the radio, or is there a button
: on the radio to allow control of the changer from the stock radio?
The cassette receiver has a button marked cd and that controls the
changer just fine. The changer works fine and I am glad it is a good
brand; as my posts have made clear, I am only unhappy about its
location in the trunk. You have given me another idea; maybe I should
look into moving it inside the car.
: This is interesting...
: The only place you're going to find a direct-connect CD changer is from
: Toyota, or from a junkyard or e-Bay. I'd like to see this setup so I could
: tell what is needed! A lot of the stock Toyota radios through the 80's and
: into the 90's had a DIN connector on the back of them to plug in other
: accessories such as a CD deck or an Equalizer. But, even though DIN
: 'means' STANDARDIZED, it is not possible to tell if one manufacturer's
: pinout matches another's pin-in! If you can get a look at the back of the
: radio and see if there is a DIN connector that is plugged into a socket,
: then you may be able to get something that will work.
: I can't remember how Fujitsu marks their units. At one time, even though
: the radio said TOYOTA on it, there was also another little mark on the
: faceplate that defines the MFG; a small Capital N with a lightening
: bolt for National (Panasonic), or what kind of looked like the GE (General
: Electric) 'meatball' with the word "TEN" across it for Fujitsu. (See, I DO
: remember!) If one of these marks is on there, it will help even further;
: I'm willing to bet since it is an Eclipse changer then it's probably a
: Fujitsu head unit...
: If you find something, let me know!
: There is another way to tell...the National branded radios had REALLY good
: FM reception (almost TOO good! Stations splashed over each other) while
: the FM section on the Fujitsu's wasn't as good, but the tape section
: sounded GREAT! (but that's a generalization...)
: Most places that sell automotive audio systems like Circuit City and Best
: Buy also do installations. If you have the installation kit and adapter
: harness and you were close by, I might even pop it in myself.
Thanks, but I haven't found the right solution yet. My cassette
receiver is working fine, there is a free pocket below it. What is
bothering me is the location of cd player: in the trunk. Ideally then,
I would like a cd player that fits in the free pocket and is controlled
by the cassette receiver. I haven't found it.
Lacking that, I'll see if the cd player can be moved from the trunk to
somewhere inside the car. It is kind of big, but maybe a spot could be
found.
Otherwise, I need to junk both cassette receiver and the cd player and
buy a new unit with cassette and cd. The selection however is very
limited and prices are high.
