Re: 1992 Toyota Corolla Startup Problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-28-2006, 11:52 PM   #1 (permalink)
RnR
Guest
Posts: n/a
View RnR's Photo Gallery
On Thu, 28 Dec 2006 19:25:30 GMT, nathan-lee <none@000.com> wrote:
[color=blue]
>I think I found the problem, there was oil in my spark plugs, i’m low
>on oil, and transmission fluid, and also my battery had leaking acid
>coming from the positive side. The problem may be the valve basket
>which is cracked causing the oil to reside in the spark plugs.
>"Ray O" wrote:[color=green]
> > "nathan-lee" <none@000.com> wrote in message
> > news:956101_5d01ac8aaf7dc038cb5d88f25e3c9adb@autoboardz.com...[color=darkred]
> > >I was on the freeway, and my RPM was going crazy boosting up[/color]
> > and down.[color=darkred]
> > > My service engine check light came on, I pulled over to the[/color]
> > side and[color=darkred]
> > > I couldn't start my car up anymore. Does anyone know what[/color]
> > this could[color=darkred]
> > > be? It's the first time something like this happened.
> > >[/color]
> > The first thing to do is to pull the trouble codes from the
> > computer.
> > Ray O
> > (correct punctuation to reply)[/color][/color]
Sorry to sound stupid but what is a valve basket? I also have a 92
Corolla with a very small oil leak but otherwise runs fine. Simple
but good dependable transportation.
Old 12-29-2006, 01:11 AM   #2 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
On Thu, 28 Dec 2006 23:52:33 -0600, RnR wrote:[color=blue]
>On Thu, 28 Dec 2006 19:25:30 GMT, nathan-lee <none@000.com> wrote:[/color]
[color=blue][color=green]
>>which is cracked causing the oil to reside in the spark plugs.[/color]
>but good dependable transportation.[/color]
I think he's referring to the sparkplug wells in the valve cover.
On a twincam engine the sparkplugs are between the two camshafts and
sit in individual tubular cups, sealed at top (valve cover) and bottom
(top of the cylinder head) with gaskets or O-rings.
If the O-rings start seeping oil into the cup, or the cup is cracked
or damaged, the oil can coke up from the heat, carbon track into a
high-resistance leakage path, and short out the plugs at the ceramic.
--<< Bruce >>--
BB code is Off
Smilies are Off
[IMG] code is Off
History of the Corolla Ratko Corolla Lounge 26 06-16-2010 04:20 AM
WTB 88 toyota pickup parts 88toyota Pre-88 Toyota Pickup/Hilux 7 09-04-2007 07:48 PM
Corolla 1992 radio problems peptobysmol Archived Corolla threads 0 04-18-2006 10:17 PM
Toyota Corolla XRS (Canada) I hate Toyota Corp :( General Discussion 1 03-12-2004 01:07 PM
