1996 corolla engine vibration - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-02-2007, 06:19 PM   #1 (permalink)
mrmatrix
Guest
Posts: n/a
View mrmatrix's Photo Gallery
Hello, I need to work on my parents 1996 corolla w 165,000 miles
(automatic tranny, 1.8). The problem has gotten progressively worse
since ~120,000 miles. The engine vibrates at idle, both when cold and
warmed up and in park or drive, seems to go away when driving. I
suspect an engine mount(s). Is any particular mount prone to fail?, Or
do I need to replace them all? All maintanance is up to date including
timing belt, and ignition parts(all toyota brand).
any comments would be appreciated.
Old 01-13-2007, 07:17 PM   #2 (permalink)
RT
Guest
Posts: n/a
View RT's Photo Gallery
Re: 1996 corolla engine vibration
On 2 Jan 2007 15:19:45 -0800, "mrmatrix" <thewebbfam1@msn.com> wrote:
[color=blue]
>any comments would be appreciated.[/color]
I just replaced the mounts on a 1.6. It does create lots of
vibrations. At first it seemed the driver and passenger side mounts
were just sagging, but I bought all 4 mounts to replace (cheaper on
ebay for sure). I first replaced passenger/driver side mounts. Then I
took the front mount out and it was very broken. I still need to do
the rear mount , just haven't been able to spend time on it. And yes,
the vibrations are a TON less.
The difference between warm and cold amount of vibrations is probably
due to the fact that the engine at cold runs a bit faster due to
getting more fuel. Running at higher rpm might give out more
vibrations which are transferred into the car if you have bad mounts.
Will you do it yourself? It's not that hard, at least the left/right
and front ones.
Old 01-22-2007, 01:32 AM   #3 (permalink)
Borzou.Shahsavand@gmail.com
Guest
Posts: n/a
View Borzou.Shahsavand@gmail.com's Photo Gallery
hey mrmatrix,
Hope this isn't too late. Yeah it sounds like an engine mount. the
front one on the ae101 is a bit dodgy. its just located above the cross
member (behind the radiator. you can probably feel the mount and see if
the rubber is moving too much or not. replacing it should be easy if
you can use something to push the engine up (even a pully would do,
just have the engine resting on the other three mounts). hope that
helps.
mrmatrix wrote:[color=blue]
Old 01-24-2007, 11:13 PM   #4 (permalink)
RT
Guest
Posts: n/a
On 21 Jan 2007 22:32:04 -0800, [email]Borzou.Shahsavand@gmail.com[/email] wrote:
[color=blue]
>hey mrmatrix,
>helps.[/color]
I just did this on a 96 geo prizm. You do not need to push the engine
up for the front or rear mount. the engine basically hangs on the left
and right (drivers side/passenger side) mounts and the front and rear
mount only prevent the engine from twisting.
Any tips on the rear mount and how to remove it ? I couldn't get it
out last time I tried.
[color=blue]
>mrmatrix wrote:[color=green]
>> any comments would be appreciated.[/color][/color]
BB code is Off
Smilies are Off
[IMG] code is Off
Engine Noise 1996 Tacoma 2RZ-FE :( chipsndukes 1st Generation (1995.5–2004) 20 08-21-2010 09:14 PM
2jz-gtte Jmac279 Supra Forum 30 02-02-2007 01:54 AM
"A" engine info freakinbox Archived Corolla threads 29 05-10-2006 01:05 AM
1996 Corolla Wagon Engine Swap??? itsice Introduce Yourself Here 1 08-08-2005 01:30 AM
