Re: Made a huge mistake with battery - please help
JoeSpareBedroom, 1/3/2007, 11:20:29 AM, <hJQmh.1$ai1.0@news01.roc.ny>
wrote:
[color=blue]
> "arshadmomin" <arshadmomin@gmail.com> wrote in message
> news:1167840307.419474.70390@42g2000cwt.googlegroups.com...[color=green]
> > Hello,
> > I will try to avoid unneccessary details. I removed the battery
> > from my 1995 corolla and when I connected it back, I connected the
> > wrong cables to the wrong terminals. In my defense, both cables
> > were taped black. Now the car is completely dead. I did correct
> > the connections, it is still dead.
> > Someone with knowledge, please help.
> > Thank you
> >[/color]
> I was just on the phone with my mechanic about another subject, and
> asked him about this. He couldn't be specific with locations, but he
> said Toyota uses fusible links to protect against such things. He
> said to first check the fuse box (should be the one under the hood,
> not in the passenger compartment). You're looking for something much
> larger than the plastic rectangular fuses. And, there may also be
> another type - a short piece of wire designed to melt. Go to this web
> page, where for just a little money, you can buy a day's worth of
> access to factory service manuals online:
> [url]http://www.techinfo.toyota.com/[/url]
> Good luck.[/color]
I have also seen fusible links go bad in other vehicles for precisely
the same reason. The ones I have seen were older and resembled a wire
about two inches long if I remember correctly.
