1992 toyota corola lights dim in idle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-03-2007, 08:13 PM   #1 (permalink)
loren
Guest
Posts: n/a
View loren's Photo Gallery
I replaced the battery and altinator and im still gettind dimming
lights when i stop.
Old 01-03-2007, 11:58 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 1992 toyota corola lights dim in idle
"loren" <wormusic@mac.com> wrote in message
news:1167873201.107092.203320@q40g2000cwq.googlegroups.com...[color=blue]
> lights when i stop.
>[/color]
Check the output voltage of the replacement alternator, especially if it is
an aftermarket one. Check cable and ground connections.
Ray O
Old 01-04-2007, 08:22 AM   #3 (permalink)
Jirí Lejsek
Guest
Posts: n/a
View Jirí Lejsek's Photo Gallery
Slight dimming of lights is normal when idling because alternator does not
output so much energy. It should disapear after slight increase of RPM (more
than 1000).
"loren" <wormusic@mac.com> píse v diskusním príspevku
> lights when i stop.
>[/color]
Old 01-04-2007, 01:08 PM   #4 (permalink)
Reasoned Insanity
Guest
Posts: n/a
View Reasoned Insanity's Photo Gallery
<nospampls2002@yahoo.com> wrote in message
news:1167926417.270826.220860@s80g2000cwa.googlegroups.com...[color=blue]
> loren wrote:[color=green]
>> lights when i stop.[/color]
> I'd check the battery also.
> Sometimes a "new" battery isn't. If it has been on the shelf more than
> six months after date of manufacture "sulfation" of the internal plates
> can begin. Also, sometimes new batteries aren't fully charged. There
> should be a date code on the side of the battery - "A" for January,
> etc.[/color]
So in other words, batteries are like milk.
Old 01-04-2007, 04:08 PM   #5 (permalink)
Guest
Posts: n/a
View nospampls2002@yahoo.com's Photo Gallery
Reasoned Insanity wrote:[color=blue]
> So in other words, batteries are like milk.[/color]
Apart from the obvious difference that you don't drink what's in the
container, and that after six months unrefrigerated it is still ok.
Old 01-04-2007, 06:34 PM   #6 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
On Thu, 4 Jan 2007 12:08:20 -0600, "Reasoned Insanity"
<mintclovers@@yahoo.com> wrote:
[color=blue]
Sorta - but you can't pour battery acid on your corn flakes.
Car batteries go bad just on time if nothing else. If you bought a
battery with a 60-month warranty and it's 60 months old, better get it
load-tested and think about changing it. Because it's thinking about
going bad - at the worst possible moment...
Milk goes bad quicker if it isn't refrigerated, batteries go bad if
you try to deep-cycle a regular starting battery, or you overcharge or
undercharge (bad alternator or voltage regulator), or you subject it
to wild temperature extremes regularly.
If it's sub-zero weather, better have the battery fully charged or
the acid gets weak, it'll freeze and crack the case.
--<< Bruce >>--
Old 01-05-2007, 07:38 PM   #7 (permalink)
loren
Guest
Posts: n/a
On Jan 5, 2:52 pm, "Danny G." <dan...@pacbell.net> wrote:[color=blue]
> "loren" <wormu...@mac.com> wrote in messagenews:1167873201.107092.203320@q40g2000cwq.googlegroups.com...[color=green]
> > lights when i stop.For $5 and 15 minutes of your time Sears (or someplace like that) will test it for you.[/color][/color]
I purchased the 200$ optima battery from auto zone and bought a meeter
when the engin is off it say 13.88 when the engin is on
with lights running it says 15.00 so i guess its ok. thanx too all off
you for your help.
Old 01-06-2007, 12:46 AM   #8 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
On 5 Jan 2007 16:38:47 -0800, "loren" <wormusic@mac.com> wrote:[color=blue]
>On Jan 5, 2:52 pm, "Danny G." <dan...@pacbell.net> wrote:[color=green]
>> news:1167873201.107092.203320@q40g2000cwq.googlegroups.com...[/color][/color]
[color=blue][color=green][color=darkred]
>you for your help.[/color]
That sounds good. The alternator doesn't put out it's full power
output at curb idle, an 80-Amp rated alternator might only put out 25
Amps if the engine is only turning 600 to 800 RPM.
The ignition, headlights, taillights, brake lights, heater fan and
radiator fan can easily draw more than 25 Amps. So if you are stopped
with the headlights and the heater fan on, you are running partially
off the battery and the system can drop into the 13V or even the 12V
range safely. As long as it picks back up to the 13.8 to 14.5 Volt
range when you start moving, it's fine.
--<< Bruce >>--
BB code is Off
Smilies are Off
[IMG] code is Off
Toyota to Offer XM Radio as a Factory-Installed Option EKam Toyota News 1 08-17-2011 07:53 PM
TOYOTA ENGINES AND OIL SLUDGE - WALL ST JOURNAL bondobondo General Discussion 99 02-02-2007 07:54 PM
2006 Yaris: Toyota Canada Announces Nameplate For New Global Subcompact rolla-XRS Toyota News 34 12-03-2005 12:48 AM
Toyota's global strategy looks inward rolla-XRS Toyota News 7 11-29-2004 04:55 PM
Article: Toyota Profits Jump Phi Toyota News 0 11-01-2004 12:53 PM
