Corolla - Hard Start Help and Distr O Ring - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-03-2007, 10:07 PM   #1 (permalink)
blake18
Guest
Posts: n/a
View blake18's Photo Gallery
Hello Folks -
I have a 1996 Corolla with 160k miles on it, I have two questions
below; one on a recent hard start and another on replacing distributor
o rings.
1. I had a problem starting my Corolla in the wee hours of the morning
the other day. The car had only been run for less than a minute in the
previous 24 hours. The dash lights came on so I think I am safe to
rule out a dead battery. A check engine light was on as well, I gave
the car a good 6-7 "chug-chug-chug-chugs" to get going and nothing.
I opened the hood, poked around for a minute and then in frustration
turned the key and let it try to turn over for a good 10 seconds, and
slowly, it came to life and I goosed the gas. I have started the car
6+ times since with no problems. Any ideas? Should I replace the
starter or was this a fluke? I had a another car that the stated died
on and that was a slow process where the starts got slowly worse, not
all of a sudden like this. Could the engine have been flooded or
something? The only thing I did between the two attempts to start was
to open the hood and open the garage door letting a rush of fresh air
in.
2. My Corolla also appears to be leaking oil at the distributor, I
understand the internal O-rings are a common cause. I seem to be
getting mixed signals on the difficulty of removing the distributor,
when I remove it is it possible to mark the orientation and carefully
replace it without adjusting the timing? I would like to simply pull
it out, replace the ring and put it back, some of the various sources I
have been looking at seem make it sound like I need to consult NASA to
align the bugger! Any advice would be greatly appreciated, and any
advice on what else might be leaking in this area (already replaced a
clogged PCV).
Thanks again!
Blake
Old 01-03-2007, 11:50 PM   #2 (permalink)
=?iso-2022-jp?q?Hachiroku_=1B$B%O%A%m%=2F=1B=28B?=
Guest
Posts: n/a
View =?iso-2022-jp?q?Hachiroku_=1B$B%O%A%m%=2F=1B=28B?='s Photo Gallery
Re: Corolla - Hard Start Help and Distr O Ring
On Wed, 03 Jan 2007 19:07:48 -0800, blake18 wrote:
[color=blue]
> Hello Folks -
> below; one on a recent hard start and another on replacing distributor o
> rings.
> 1. I had a problem starting my Corolla in the wee hours of the morning the
> previous 24 hours. The dash lights came on so I think I am safe to rule
> out a dead battery. A check engine light was on as well, I gave the car a
> slowly, it came to life and I goosed the gas. I have started the car 6+
> times since with no problems. Any ideas? Should I replace the starter or
> was this a fluke? I had a another car that the stated died on and that
> was a slow process where the starts got slowly worse, not all of a sudden
> like this. Could the engine have been flooded or something? The only
> thing I did between the two attempts to start was to open the hood and
> open the garage door letting a rush of fresh air in.
> understand the internal O-rings are a common cause. I seem to be getting
> mixed signals on the difficulty of removing the distributor, when I remove
> it is it possible to mark the orientation and carefully replace it without
> adjusting the timing? I would like to simply pull it out, replace the
> ring and put it back, some of the various sources I have been looking at
> seem make it sound like I need to consult NASA to align the bugger! Any
> advice would be greatly appreciated, and any advice on what else might be
> leaking in this area (already replaced a clogged PCV).
> Thanks again!
> Blake[/color]
How old is the battery? Over 5-6 years, then it may be time for another.
Old 01-03-2007, 11:56 PM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"blake18" <zachenos@hotmail.com> wrote in message
news:1167880066.644394.316530@11g2000cwr.googlegroups.com...[color=blue]
> Hello Folks -
> o rings.
> in.
>[/color]
When you say "hard starting," do you mean that the engine did not turn over
or did it turn over without catching?
If the engine did not turn over, check the starter solenoid contacts. If
the engine cranked without catching, check the fuel pressure regulator.
[color=blue]
> clogged PCV).
> Thanks again!
> Blake
>[/color]
Leaking distributor O-rings are not that uncommon. Use an awl to scribe
alignment marks on the distributor base and head so that you can re-align
it. The proper method is to re-check engine timing, but the scribe method
will do in a pinch. If you are chasing leaks, also check the valve cover
gasket.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
