2007 Toyota Tacoma odometer - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-04-2007, 10:46 PM   #1 (permalink)
botedoc@bellsouth.net
Guest
Posts: n/a
View botedoc@bellsouth.net's Photo Gallery
After purchasing the 2007 Tacoma I noticed the miles were starting to
pile up in a hurry. By checking the mile markers on the highway I found
that for every 10 miles I drove the odometer read 13.8. As this was
going to make a significant reduction in warranty mileage, I contacted
the Toyota dealership. I was told in no uncertain terms that a 3-4 mile
variation in speedometer reading was acceptable. Acceptable to whom?
After several attempts to have the speedometer recalibrated(flashed) I
finally gave up and out of pocket had a new set of bigger circumference
tires installed. Toyota offered no help whatsoever. This cured the
problem. I just wondered if anyone else has had this particular problem
and if it my be common in the Tacoma.
Old 01-05-2007, 05:29 AM   #2 (permalink)
Bob H
Guest
Posts: n/a
View Bob H's Photo Gallery
Re: 2007 Toyota Tacoma odometer
You need to go up the food chain with that problem.
<botedoc@bellsouth.net> wrote in message
news:1167968794.436898.182330@42g2000cwt.googlegroups.com...[color=blue]
>[/color]
Old 01-05-2007, 07:16 AM   #3 (permalink)
Nicholas Bourne
Guest
Posts: n/a
View Nicholas Bourne's Photo Gallery
>[/color]
I would really have a go at them. While the markers at the side of the road
are not the most accurate, they should be within a few hundred meters of
where they should be.
In Australia our design rules allow for a 5% variation (not the 40% you get)
due to the problems with mass construction, but this should be only limited
to cars that have a cable speedo.
I don't know what the rules are like in the US but it would be classed here
as not functioning correctly and would have to be fixed, either by the maker
or you.
Be warned though, just because the odometer is out does not mean the speedo
is out, whith larger diameter tyres you could now be going faster than you
think.
Also seeing as the dealer has put you off, call Toyota head office directly
and ask to speak to a regional manager or the managing director. The
warrenty is with them directly not the dealer so go straight to the source.
If you are polite and don't sound too pissed they will usually be extremly
helpfull.
NicK
Old 01-05-2007, 09:52 AM   #4 (permalink)
Luba Papageorgio
Guest
Posts: n/a
View Luba Papageorgio's Photo Gallery
You will get a toyota fix if you persist. But I'm sure you'll like the
larger tires of the prerunner and 4wd
>[/color]
Old 01-05-2007, 10:18 AM   #5 (permalink)
C. E. White
Guest
Posts: n/a
View C. E. White's Photo Gallery
> and if it my be common in the Tacoma.[/color]
Maybe the dealers switched the original tires from the truck you eventually
bought with another truck before you bought it to satisfy another Customer.
(I've seen dealers do this- nothing sinister, just the dealer switching
tires/wheels between vehicles they "own"). Do you by any chance have the
original window sticker? It should list the size of the tires installed on
your truck at the factory. It would be worth checking this against the size
tires actually on the truck when it was delivered to you.
A 38% error is completely ridiculous. I am surprised you could fix the error
merely with tires. I am even more surprised that a Toyota dealership would
claim that this ridiculous level of error was acceptable. I can't remember
the last new car I bout where the odometer was more than a little off (i.e.,
read significantly more or less miles than I actually traveled). I checked
by last 5 new vehicles against both Interstate Mile Marker and GPS
navigation systems and 4 of the 5 (all Fords) had odometers that were 1 % to
3% pessimistic (i.e., the odometer says I drove 97 miles, when I actually
drove 100 miles). The other, a Saturn, had an odometer that was about 3%
optimistic (100 actual miles = 103 indicated miles).
As far as I can tell, there are no Federal Regulations that specify an
acceptable accuracy for an odometer. This seems strange, since there are
regulations that make odometer tampering a crime. It seems like it is OK to
equip a car with an odometer that is wildly inaccurate, but illegal to
change the inaccurate reading.
Ed
Old 01-06-2007, 06:24 PM   #6 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
SPEEDOMETER and ODOMETER readings are completely different things. A speedo
that reads in error of 4 mph is a much different thaing than an odometer
that reads wrong by 4 miles in 10.
>[/color]
Old 01-06-2007, 06:32 PM   #7 (permalink)
Jeff Strickland
Guest
Posts: n/a
"Nicholas Bourne" <nbourne@optusnet.com.au> wrote in message
news:459e41aa@dnews.tpgi.com.au...[color=blue]
> news:1167968794.436898.182330@42g2000cwt.googlegroups.com...[color=green]
>>[/color]
> road are not the most accurate, they should be within a few hundred meters
> of where they should be.[/color]
I do not agree. The markers should be within a few meters of where they say
they are. My disagreement ias solely your assertion of the rate of error
that the highway department will tolerate. I think that the error in placing
a mile marker is within a few meters, not a hundred meters. A highway marker
will be omitted before it will be placed in the wrong location.
If a marker says it is 27.5 miles from somewhere, you can bet that it is
within 10 meters of where it is supposed to be. Keep in mind, the mile
markers are not measuring straight line miles, they are measuring highway
miles, so a highway that twists and turns can place you ten miles form the
start point as the straight line goes, but over twenty miles as the highway
goes.
[color=blue]
> get) due to the problems with mass construction, but this should be only
> limited to cars that have a cable speedo.
> here as not functioning correctly and would have to be fixed, either by
> the maker or you.
> speedo is out, whith larger diameter tyres you could now be going faster
> than you think.
>[/color]
This is true. The larger tires will make the Speedometer read slow, so a
displayed speed of 60 might be an actual speed of 65 or more.
Old 01-07-2007, 04:23 AM   #8 (permalink)
Nicholas Bourne
Guest
Posts: n/a
"Jeff Strickland" <crwlr@yahoo.com> wrote in message
news:jdidnRYqJco5rD3YnZ2dnUVZ_qunnZ2d@ez2.net...[color=blue]
> news:459e41aa@dnews.tpgi.com.au...[color=green]
>> news:1167968794.436898.182330@42g2000cwt.googlegroups.com...[color=darkred]
>>>[/color]
>> meters of where they should be.[/color]
> say they are. My disagreement ias solely your assertion of the rate of
> error that the highway department will tolerate. I think that the error in
> placing a mile marker is within a few meters, not a hundred meters. A
> highway marker will be omitted before it will be placed in the wrong
> location.[/color]
In the city they maybe but out in the country where I live you sometimes
can't be that accurate. Our roads go over very changeable soil types. In the
black soil plains the main highway has more waves in it than a
rollercoaster. Personally I don't trust them to perfectly accurate with the
distance markers over our distances. I think 200Km +- 100m is fine. when the
raod is dead straight and you don't see another car for the whole distance I
don't really care.
[color=blue]
> highway goes.
>[/color]
[color=blue]
>[color=green]
>> the maker or you.
>> than you think.
>>[/color]
>[/color]
Old 01-07-2007, 02:52 PM   #9 (permalink)
Jeff Strickland
Guest
Posts: n/a
news:45a0bc0e@dnews.tpgi.com.au...[color=blue][color=green]
>> in placing a mile marker is within a few meters, not a hundred meters. A
>> location.[/color]
> the black soil plains the main highway has more waves in it than a
> the distance markers over our distances. I think 200Km +- 100m is fine.
> when the raod is dead straight and you don't see another car for the whole
> distance I don't really care.
>[/color]
I don't live in the city either. I do live in California, and your mileage
may vary, but they will not plant a mile marker before they plant one in the
wrong place.
The purpose of a mile marker isn't for you to calibrate your odometer or
speedometer (but they are useful for that), they are for emergency crews and
highway maintenance crews. When you are on the highway and observe a crash,
you can tell the emergency operator that you are east of mile marker 27.5,
and they have a better idea of where to send the response crew. Cellphones
these days have a GPS-like circuit built in that helps the emergency
operator find you as you are making the call, so your observance of mile
markers isn't all that important, but that is why the markers are there.
If there is a mile marker planted on the side of the road, you can take it
to the bank that it is precisely where it says it is, within a few meters.
Old 01-07-2007, 06:08 PM   #10 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
news:2vydnXFi370W0jzYnZ2dnUVZ_r2onZ2d@ez2.net...[color=blue]
> news:45a0bc0e@dnews.tpgi.com.au...[color=green][color=darkred]
>>> location.[/color]
>> whole distance I don't really care.
>>[/color]
> the wrong place.
> and highway maintenance crews. When you are on the highway and observe a
> crash, you can tell the emergency operator that you are east of mile
> marker 27.5, and they have a better idea of where to send the response
> crew. Cellphones these days have a GPS-like circuit built in that helps
> the emergency operator find you as you are making the call, so your
> observance of mile markers isn't all that important, but that is why the
> markers are there.
>[/color]
I found this research paper:
[url]http://onlinepubs.trb.org/onlinepubs/nchrp/nchrp_rpt_506.pdf[/url] and while I did
not read all 108 pages or some other info on other sites, I found some
surprising information. I would have thought that there is a uniform method
of placing mile markers, but there is not, and methods and accuracy vary by
state.
Among the methods used to measure position are optical survey instruments,
laser distance measuring, measuring wheels, digitized aerial photographs,
and distance measuring devices installed in vehicles (fancy odometers), with
the most common being a combination of several methods.
Some are measured in 2 dimensions and some are measured in 3, taking
elevation into account.
Some measure from a lane centerline, some measure the centerline between
directions, and some measure between markers.
There is relative accuracy (accuracy between markers and geographic
locations) and there is spatial accuracy - distance from a specified
starting point in the road system.
Depending on the state and the method used to place the particular marker,
it looks like accuracy will vary from inches to about 300 feet.
For the purposes of determining odometer and/or speedometer accuracy, the
most accurate method seems to be GPS or measuring the mile marker distance
over as long a distance as possible and averaging out.
Ray O
Old 01-08-2007, 06:14 AM   #11 (permalink)
Nicholas Bourne
Guest
Posts: n/a
>>> location.[/color]
>>[/color]
> the wrong place.
> markers are there.
>[/color]
Your mile markers are used for different things. Ours are only used to tell
you the distance to the next town along the road and are usually every 20 to
30 kilometers so if it's out by 200m it doesn't really matter. In the
country at best you can only give a rough area where you are anyway and
thats usually enough.
By the way (I'm not being picky) our mobiles dont cover much for real
emergancy use. My state along covers some 720,000 square miles (I think it's
about 10% bigger than Texas with about a fifth the population) and less than
10% is covered by mobile reception.
Old 01-08-2007, 04:00 PM   #12 (permalink)
Danny G.
Guest
Posts: n/a
View Danny G.'s Photo Gallery
"Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message news:165d1$45a17fdd$47c2b532$22576@msgid.meganewsservers.com...[color=blue]
> "Jeff Strickland" <crwlr@yahoo.com> wrote in message news:2vydnXFi370W0jzYnZ2dnUVZ_r2onZ2d@ez2.net...[color=green]
>> "Nicholas Bourne" <nbourne@optusnet.com.au> wrote in message news:45a0bc0e@dnews.tpgi.com.au...[color=darkred]
>>>> I do not agree. The markers should be within a few meters of where they say they are. My disagreement ias solely your assertion
>>>> of the rate of error that the highway department will tolerate. I think that the error in placing a mile marker is within a few
>>>> meters, not a hundred meters. A highway marker will be omitted before it will be placed in the wrong location.
>>> In the city they maybe but out in the country where I live you sometimes can't be that accurate. Our roads go over very
>>> changeable soil types. In the black soil plains the main highway has more waves in it than a rollercoaster. Personally I don't
>>> trust them to perfectly accurate with the distance markers over our distances. I think 200Km +- 100m is fine. when the raod is
>>> dead straight and you don't see another car for the whole distance I don't really care.
>>>[/color]
>> I don't live in the city either. I do live in California, and your mileage may vary, but they will not plant a mile marker before
>> they plant one in the wrong place.
>> The purpose of a mile marker isn't for you to calibrate your odometer or speedometer (but they are useful for that), they are for
>> emergency crews and highway maintenance crews. When you are on the highway and observe a crash, you can tell the emergency
>> operator that you are east of mile marker 27.5, and they have a better idea of where to send the response crew. Cellphones these
>> days have a GPS-like circuit built in that helps the emergency operator find you as you are making the call, so your observance
>> of mile markers isn't all that important, but that is why the markers are there.
>> If there is a mile marker planted on the side of the road, you can take it to the bank that it is precisely where it says it is,
>>[/color]
> I found this research paper: [url]http://onlinepubs.trb.org/onlinepubs/nchrp/nchrp_rpt_506.pdf[/url] and while I did not read all 108 pages
> or some other info on other sites, I found some surprising information. I would have thought that there is a uniform method of
> placing mile markers, but there is not, and methods and accuracy vary by state.
> Among the methods used to measure position are optical survey instruments, laser distance measuring, measuring wheels, digitized
> aerial photographs, and distance measuring devices installed in vehicles (fancy odometers), with the most common being a
> Some are measured in 2 dimensions and some are measured in 3, taking elevation into account.
> Some measure from a lane centerline, some measure the centerline between directions, and some measure between markers.
> There is relative accuracy (accuracy between markers and geographic locations) and there is spatial accuracy - distance from a
> specified starting point in the road system.
> Depending on the state and the method used to place the particular marker, it looks like accuracy will vary from inches to about
> 300 feet.
> For the purposes of determining odometer and/or speedometer accuracy, the most accurate method seems to be GPS or measuring the
> mile marker distance over as long a distance as possible and averaging out.
> Ray O
> (correct punctuation to reply)[/color]
I would imagine the distance traveled would very quite a bit even between a cars left and right side tires.
Dan
Old 01-08-2007, 04:04 PM   #13 (permalink)
edv
Guest
Posts: n/a
View edv's Photo Gallery
And for the front and rear wheels
between a cars left and right side tires.[color=blue]
> Dan[/color]
Old 01-08-2007, 04:09 PM   #14 (permalink)
Ray O
Guest
Posts: n/a
"Danny G." <dandog@pacbell.net> wrote in message
news:whyoh.30197$hI.5848@newssvr11.news.prodigy.net...[color=blue]
>[/color]
<snipped>
[color=blue]
> Dan
>[/color]
Yup, the distance traveled varies enough to require a differential ;-)
Ray O
Old 01-08-2007, 04:55 PM   #15 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
On Mon, 8 Jan 2007 21:14:23 +1000, "Nicholas Bourne"
<nbourne@optusnet.com.au> wrote:
[color=blue]
>thats usually enough.[/color]
We're not talking about the "Distance to next town" signs meant for
use by the motorists. Look for smaller markers placed by the road
maintenance crews at every bridge and improvement. I'll bet you the
Australian highways have them, but you never had a reason to notice.
They are used to catalog all the drain culverts, bridges, tunnels,
etc. so they can go clean out the right one. And keep records of the
ones that need work. When they repair the pavement the contractor
gets paid by the mile/KM, so it's important that they can survey what
they did.
Ours are marked in miles to the hundredth from the staring point of
the highway down the center-line, and they're accurate to the rounding
factor. (.01 mile is 52.8 feet or 16 meters and change.) Close
enough to find the right bridge...
For example the marker for a drain culvert undercrossing might be
signed as (Mile) 23.96 (which could be give or take 50 feet) and a bit
farther on you'd see a standalone sign for (Mile) 24.00 which will be
spot-on.
[color=blue]
>10% is covered by mobile reception.[/color]
That's not a problem if you have a vast flat area with the
occasional outcropping (Ayers Rock?) that you can put a base station
on top of. They are getting really good at disguising the base
station antennas as native trees - I've seen them done up as various
species of pines, oaks, elms, date palms, queen palms, saguaro
cactus... It's all in breaking up the silhouette and getting the
color match close to the real trees surrounding it.
Or you put up a 40M tower for the antennas every 50 or 100Km down
the highway, in the outback that'll give plenty of coverage with only
a few towers. The equipment has been miniaturized to where it can be
a single rack cabinet at the base of the tower. If they aren't
heavily used, solar cells and batteries will run them.
--<< Bruce >>--
BB code is Off
Smilies are Off
[IMG] code is Off
TOYOTA - an Obsession, a Religion or just Madness? RAV4EVR General Discussion 70 02-22-2008 11:07 AM
TOYOTA ENGINES AND OIL SLUDGE - WALL ST JOURNAL bondobondo General Discussion 99 02-02-2007 07:54 PM
2007 Tacoma Vehicle Stability Control off switch and side curtain airbag off switch kowached 2nd Generation (2005+) 17 10-13-2006 08:07 PM
In hybrids, it's Toyota vs. the world EKam Toyota News 2 03-27-2005 09:04 PM
