Re: 2006 Toyota avalon - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-04-2007, 11:57 PM   #1 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"glide" <bacadon@valornet.com> wrote in message
news:1167964104.309717.100690@q40g2000cwq.googlegroups.com...[color=blue]
> Has anyone had problems with the battery on there '06 Avalons. My
> mother bought a new '06 in June and has had it towed to the shop three
> times because of a dead battery. Each time the battery has been dead
> and has had to be replaced. The reasons for the dead battery given has
> been that the key fob is too close to the car and it's continuously
> communicating with the brain in the car, therefor draining the battery.
> The car is parked in a garage. The fob is about 15 feet from the car on
> a inside wall in the house. The second reason she was given was the car
> was to low on gas. The third reason was she had let the car set too
> long, 3 weeks. This car has only 7,275 miles on the odometer. I just
> found out about all the run around she has been giving this evening. I
> plan going to the dealer Tuesday morning when I get back to town. The
> dealer told her not to worry we will come pick you up each time the car
> doesn't start, after all you have a phone. The second time the car
> wouldn't start she had went into a store for less than 10 minutes. When
> she questioned the manager all he could say was that you have a cell
> phone, but to me that is not the point. Does this car have a serious
> problem My mother is 70 years old and she has bough a new car every 2
> years since 1970. She has never had any porblems like this with any car
> she has ever ownned.This is the first Toyoda and if satisfaction is not
> met Tuesday it will probably be the last.
> thanks for anu help, glide
>[/color]
The easiest way to check the dealer's diagnosis is to move the key fob
farther away from the car and see if the battery drain goes away, although I
doubt if that is the problem. Most state lemon laws cover defects that
affect the use, value, or safety of the vehicle, and I think it is
reasonable to say that a car that does not start is not very useful. The
dealer should be checking for a parasitic draw as well as checking
alternator output.
I would ask the dealer to contact the technical hot line while politely
mentioning that the vehicle has been X times for the same repair without a
satisfactory long-term solution. If they give you the same story, call
Toyota's customer relations line at 1-800-331-4331 or take it to another
dealership if that is not too inconvenient.
Ray O
Old 01-05-2007, 08:40 PM   #2 (permalink)
glide
Guest
Posts: n/a
View glide's Photo Gallery
Ray O wrote:[color=blue]
> news:1167964104.309717.100690@q40g2000cwq.googlegroups.com...[/color]
Has anyone had problems with the battery on there '06 Avalon's? My
Mother bought a new '06 in June and has had it towed to the shop three
and has had to be replaced. The reasons for the dead battery given have
communicating with the brain in the car, therefore draining the
battery.
an inside wall in the house. The second reason she was given was the
car was to low on gas. The third reason was she had let the car set too
doesn't start; after all you have a phone. The second time the car
problem my mother is 70 years old and she has bough a new car every 2
years since 1970. She has never had any problems like this with any car
she has ever owned. This is the first Toyoda and if satisfaction is not
Thanks for any help, glide[color=blue][color=green]
> >[/color]
> alternator output.
> Ray O
> (correct punctuation to reply)[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
History of the Toyota Avalon Ratko 1st Generation (1995-1999) 5 06-01-2011 07:59 PM
Avalon shows dent in Toyota quality sciguy0504 Toyota News 98 03-26-2007 12:49 AM
Tsb Bulletin El Tano 5th & 6th Generation (2002-2006 & 2007-2011) 20 11-29-2006 01:47 PM
Toyota's Hybrid Sales Continue Strong in First Half of 2006 Tideland Prius Toyota News 3 07-10-2006 12:30 PM
1985 Pickup starting problem...HELP twinturbonoy Pre-88 Toyota Pickup/Hilux 10 03-15-2006 02:25 AM
