Re: "Discussion" in another group
Hachiroku ãƒ?ãƒ?ãƒ*ク wrote:[color=blue]
> I say, overfilling with oil can cause Hydraulic Lock in an engine, others
> there are telling me no way.[/color]
How much oil? If you are meaning "hydraulic lock" not allowing piston /
crankshaft / internal component movement by overfilling a bit, I don't
think so. If you mean filling the entire crankcase, maybe. If you fill
each individual cylinder with oil, yes. Overfilling your crankcase oil
can result in a loss of fuel mileage, interruption of normal design oil
flow causing lack of lubrication, foaming, excessive emissions, and
probably a few more that Ray O can elaborate on. It is usually highly
recommended that the crankcase oil fill level does not come into contact
with the crankshaft unlike an air cooled motor that has a splash lube
system that normally uses a "paddle" bolted on the bottom of the rod
bearing.
