97 Tercel cylinder misfire.......... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-08-2007, 04:06 PM   #1 (permalink)
treesrcool
Guest
Posts: n/a
View treesrcool's Photo Gallery
I've replaced the plugs, wires and coil packs............what's left?
I constantly have a cylinder 2 misfire.
I have had it clear up after replacing the coil pack on that cylinder
for a week, but....it came back?!
Thanks
Old 01-08-2007, 04:20 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 97 Tercel cylinder misfire..........
"treesrcool" <chainsaw@softhome.net> wrote in message
news:duf5q2pktj3mvllcb4hplv0mka95kucfvl@4ax.com...[color=blue]
> Thanks[/color]
How did you determine that it is cylinder #2 that is misfiring?
Are the replacement plugs, wires, and coil packs OEM or aftermarket?
What was the condition of the spark plugs you removed? Was there any oil or
gas on the electrodes?
Ray O
Old 01-08-2007, 04:37 PM   #3 (permalink)
treesrcool
Guest
Posts: n/a
Hi, I used a code reader.Coils are factory parts, plugs are Bosch
Platinum (double electrode).
The plug in No. 2 looked fine.
Thanks
On Mon, 8 Jan 2007 16:20:58 -0600, "Ray O"
<rokigawaATtristarassociatesDOTcom> wrote:
[color=blue]
>news:duf5q2pktj3mvllcb4hplv0mka95kucfvl@4ax.com...[color=green]
>> Thanks[/color]
>gas on the electrodes?[/color]
Old 01-08-2007, 05:32 PM   #4 (permalink)
=?iso-2022-jp?q?Hachiroku_=1B$B%O%A%m%=2F=1B=28B?=
Guest
Posts: n/a
View =?iso-2022-jp?q?Hachiroku_=1B$B%O%A%m%=2F=1B=28B?='s Photo Gallery
On Mon, 08 Jan 2007 22:37:12 +0000, treesrcool wrote:
[color=blue]
> Thanks[/color]
I used Bosch in my '95 with no problem.
Funny thing, about 2 weeks after I sold the car, it started having the
same problem. I don't know if the new owner ever got it fixed...
[color=blue]
>[color=green]
>>news:duf5q2pktj3mvllcb4hplv0mka95kucfvl@4ax.com...[color=darkred]
>>> Thanks[/color]
>>gas on the electrodes?[/color][/color]
Old 01-08-2007, 05:39 PM   #5 (permalink)
Ray O
Guest
Posts: n/a
news:doh5q2t548u2fpob9ig06ej1jeubla1t3u@4ax.com...[color=blue]
> Thanks
>[/color]
So the code reader showed P0302? Can you feel any hesitation in the engine
when driving?
Ray O
Old 01-09-2007, 12:38 AM   #6 (permalink)
Stephen H
Guest
Posts: n/a
View Stephen H's Photo Gallery
this is all I found directly on a toyota 4 cyl- I'd try swapping the
injectors and see if the misfire moves.-- Stephen W. HansenASE Certified
Master Automobile TechnicianASE Automobile Advanced Engine PerformanceASE
Undercar Specialist Currently working at a Subaru
Dealershiphttp://autorepair.about.com/cs/troubleshooting/l/bl_obd_main.htmhttp://www.troublecodes.net/technical/http://www.familycar.com/Alignment.htmHello,
The toyota sets a code 303, immediatly after warmed up.
Ignition system has been checked as stated before has new
plugs, cap, rotor, and ign. wires. We checked the wave forms
of the crank and cam sensors. all OK. Checked fuel system and
injector wave forms, all OK. Checked valve adjustment and
compression, all within specs. No vacuum leaks or other
mechanical problems found. When perfoming a cylinder balance
test, the miss is barely noticed, but the scanner shows the
misfires especially under a load.
thanks for all the replies. This Toyota needed the #3 injector. As I said
in my original post, it
passed resistance and wave form test perfectly. When i removed
the injector rail I did a quick volume test and visually
inspected the spray pattern of all the injectors. Again
everything looked fine. I replaced the #3 injector with an
original Toyota part, the misfire and code were gone. The
network came through again!
> Thanks[/color]
Old 01-09-2007, 03:01 PM   #7 (permalink)
treesrcool
Guest
Posts: n/a
There is hesitation under acceleration, or load...example.. going up
hill.
On Mon, 8 Jan 2007 17:39:55 -0600, "Ray O"
[color=blue]
>news:doh5q2t548u2fpob9ig06ej1jeubla1t3u@4ax.com...[color=green]
>> Thanks
>>[/color]
>when driving?[/color]
Old 01-09-2007, 03:08 PM   #8 (permalink)
treesrcool
Guest
Posts: n/a
Is injector removal on this model that involved of a job?
Thanks
On Tue, 09 Jan 2007 06:38:44 GMT, "Stephen H" <hansensw@hotmail.com>
wrote:
[color=blue]
>> Thanks[/color]
>[/color]
Old 01-09-2007, 05:50 PM   #9 (permalink)
Ray O
Guest
Posts: n/a
news:oi08q25l3fu055t26gleu2mfpvn04nalqm@4ax.com...[color=blue]
> hill.
>[/color]
See Stephen H's post about he cured a car with the same problem, differenct
cylinder.
Ray O
[color=blue]
>[color=green]
>>news:doh5q2t548u2fpob9ig06ej1jeubla1t3u@4ax.com...[color=darkred]
>>> Thanks
>>>[/color]
>>engine
>[/color]
Old 01-09-2007, 06:48 PM   #10 (permalink)
treesrcool
Guest
Posts: n/a
Thanks for the input guys !
I'll look at the injectors.
On Tue, 09 Jan 2007 21:08:28 GMT, treesrcool <chainsaw@softhome.net>
wrote:
[color=blue]
>Thanks
>wrote:
>[color=green]
>>> Thanks[/color]
>>[/color][/color]
Old 01-09-2007, 08:39 PM   #11 (permalink)
Ray O
Guest
Posts: n/a
news:nud8q2l8inpth7nmej588ma7c5dokd9mk6@4ax.com...[color=blue]
>[/color]
You're welcome and good luck!
Ray O
Old 01-09-2007, 11:58 PM   #12 (permalink)
Stephen H
Guest
Posts: n/a
> See Stephen H's post about he cured a car with the same problem,[color=blue]
> differenct cylinder.
> Ray O
> (correct punctuation to reply)[/color]
Not my cure; something I found on a service I subscribe to; but it is the
next obvious route.
When I first got to this shop,. a tech was showing a lot car that had a
misfire- he had disassembled it several times. It too turned out to be an
injector. I wondered if I were doing the diag, I might have swapped the
injector allot sooner.
Steve
Old 01-10-2007, 11:21 AM   #13 (permalink)
Ray O
Guest
Posts: n/a
"Stephen H" <hansensw@hotmail.com> wrote in message
news:2g%oh.677836$QZ1.328716@bgtnsc04-news.ops.worldnet.att.net...[color=blue][color=green]
>> Ray O
> next obvious route.
> Steve[/color]
It' good to hear from you again!
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 09:38 AM
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
