Serpentine Belt Replacement & tensioner pulley - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-11-2007, 10:37 PM   #1 (permalink)
mrsteveo
Guest
Posts: n/a
View mrsteveo's Photo Gallery
Hi,
I have a 2002 Corolla that sounded like a bad belt squeak or whatever.
The shop says the belt needs replaced (that's fine, I haven't done it
in 60,000 miles..) and they also said the tensioner pulley had a
bearing going out causing the noise.
They're quoting $150 for the belt and tensioner pulley. That sound
accurate or close? Will any tensioner pulley they put on suffice, or
is that something that should surely be OEM only and not generic?
Just wondering.
Thanks!
Old 01-11-2007, 11:20 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Serpentine Belt Replacement & tensioner pulley
"mrsteveo" <mrsteveo@gmail.com> wrote in message
news:1168576637.579955.270780@51g2000cwl.googlegroups.com...[color=blue]
> Hi,
> Just wondering.
> Thanks!
>[/color]
Whether the price is reasonable or not depends on where you are located.
Large metro areas tend to be higher than rural areas. $150 for the belt
tensioner, and about an hour and a quarter labor sounds about right for a
metro area. I doubt if aftermarket tensioners are available so the
tensioner is probably OEM.
Ray O
Old 01-12-2007, 08:47 AM   #3 (permalink)
=?iso-2022-jp?q?Hachiroku_=1B$B%O%A%m%=2F=1B=28B?=
Guest
Posts: n/a
View =?iso-2022-jp?q?Hachiroku_=1B$B%O%A%m%=2F=1B=28B?='s Photo Gallery
On Thu, 11 Jan 2007 20:37:17 -0800, mrsteveo wrote:
[color=blue]
> Hi,
> Just wondering.
> Thanks![/color]
$150 for OEM is OK, I guess. Aftermarket belts go for $20-30 and a
tensioner is $30-60.
But make sure this is it! The manual says...but the manual doesn't have
ears to pinpoint the sound. It could be a water pump or alternator bearing.
And, in 259,000 on one car, and 240,000 on another, I never had to replace
a tensioner.
Old 01-12-2007, 09:28 AM   #4 (permalink)
wenmang@yahoo.com
Guest
Posts: n/a
View wenmang@yahoo.com's Photo Gallery
On Jan 12, 9:47 am, Hachiroku ãƒ?ãƒ?ãƒ*ク <Tru...@ae86.gts> wrote:[color=blue]
> On Thu, 11 Jan 2007 20:37:17 -0800, mrsteveo wrote:[color=green]
> > Hi,[/color]
>[color=green]
> > bearing going out causing the noise.[/color]
>[color=green]
> > is that something that should surely be OEM only and not generic?[/color]
>[color=green]
> > Just wondering.[/color]
>[color=green]
> > Thanks!$150 for OEM is OK, I guess. Aftermarket belts go for $20-30 anda[/color]
> a tensioner.[/color]
I just have my tensioner pulley replaced for my 2001 Corolla for $305
at Dealer(not include belt). I was told that tensioner pulley was worn
and belt was loosen up. I was warned about the danger of loosing the
belt during the driving, so I did. But I know it was a mistake since I
never noticed the belt was loosen up and I did replace the belt by
myself a while ago. It was done during a warranty service for CAT
converter within 80K mile.
Old 01-12-2007, 12:04 PM   #5 (permalink)
mrsteveo
Guest
Posts: n/a
FWIW, it appears there was a TSB regarding the tensioner assembly in
some Toyota vehicles including the 2002 Corolla.
I also do a 7 hour freeway drive at about 80mph once a month too.
Dunno if that affects the rate at which a 'bearing' would go bad..
Hachiroku ãƒ?ãƒ?ãƒ*ク wrote:[color=blue]
>[color=green]
> > Hi,
> > Just wondering.
> > Thanks![/color]
Old 01-12-2007, 06:29 PM   #6 (permalink)
Guest
Posts: n/a
On Fri, 12 Jan 2007 10:04:54 -0800, mrsteveo wrote:
[color=blue]
> FWIW, it appears there was a TSB regarding the tensioner assembly in some
> Toyota vehicles including the 2002 Corolla.[/color]
Well, that's much different.
[color=blue]
> I also do a 7 hour freeway drive at about 80mph once a month too. Dunno if
> that affects the rate at which a 'bearing' would go bad..[/color]
Nah. I made numerous trips from Hartford to Toronto twice a year, for
seven years.
[color=blue]
> Hachiroku ãƒ?ãƒ?ãƒ*ク wrote:[color=green]
>>[color=darkred]
>> > Hi,
>> > Just wondering.
>> > Thanks![/color]
>> bearing.
>> replace a tensioner.[/color][/color]
BB code is Off
Smilies are Off
[IMG] code is Off
Changing V6 Timing Belt Pics and the $270 Coil Connector marc780 5th & 6th Generation (2002-2006 & 2007-2011) 81 04-09-2012 07:26 AM
Camsprocket alignment marks? Help! Atk350 1st & 2nd Generation (1983–1986 & 1987-1991) 20 12-18-2006 11:44 AM
When to Replace Drive Belt and Tensioner ?? jason18631 Archived Corolla threads 7 10-25-2006 06:13 AM
Where is the belt tensioner Order 66 89-95 Toyota Pickup/Hilux 2 01-08-2006 01:33 PM
Help me with correct belt size- underdrive crank pulley for 5SFE cman2000 3rd & 4th Generation (1992–1996 & 1997–2001) 13 01-24-2005 09:05 PM
