2000 Toyota Sienna - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-13-2007, 10:06 AM   #1 (permalink)
Budro
Guest
Posts: n/a
View Budro's Photo Gallery
2000 Toyota Sienna
My check engine light came on went off and came back on all in two days.
The vehicle has 60,500 original miles. So I took it and had it ran on a
Scanner and got the fault codes P1130 A/F Sensor Circuit
Range/Performance (Bank 1 Sensor 1) & P1150 A/F Sensor Circuit
Range/Performance (Bank 2 Sensor 2). I just think it is kind of strange
that both sensors would go out at the same time. I was just wondering if
anyone knew what could cause both to appear bad at the same time.
Thanks.
Old 01-13-2007, 02:30 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 2000 Toyota Sienna
"Budro" <wo1jan2002@yahoo.com> wrote in message
news:8e3aa60fa4296b7f5ddc941fa7383a0b@localhost.talkaboutautos.com...[color=blue]
> Thanks.
>[/color]
P01130 and P01150 have 2-trip detection logic, which means that the computer
will turn on the check engine light if it detects the same problem on 2
consecutive trips, and conversely, it will turn the light off if it does not
detect the problem on 2 consecutive trips.
If the vehicle has ever been run out of fuel, that can cause that code.
Other possible causes are an open or short circuit in the air/fuel sensor
circuit, bad sensors, or a bad computer. Bad computers are vary rare, so
the other causes are more likely.
If any exhaust work has been done lately or if you have an exhaust leak,
make sure the sensors are not loose and any exhaust leaks are repaired. If
any collision work has been done recently or any electronic accessories have
been installed, make sure that the wire harness hasn't been damaged, cut, or
wrong wires have been tapped.
After the engine is warmed up, if sensor input at the ECM remains over 3.8
volts or less than 2.8 volts, or remains at 3.3 volts, the light will come
on. You have to read voltage with an OBD II scan tool with the capability
of reading sensor output from the ECM, and a generic OBD II code scanner may
read 1/5 of this voltage.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
TOYOTA - an Obsession, a Religion or just Madness? RAV4EVR General Discussion 70 02-22-2008 10:07 AM
Toyota's Dyin out Valentino Celica Forum 16 07-23-2007 11:36 PM
2007 Sienna Upgrades Thundercat Toyota News 7 09-27-2006 11:12 AM
Ford, Nissan license Toyota hybird technology EKam Toyota News 1 01-30-2005 03:25 PM
