Re: 90 Camry Broken Hood Latch Cable - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-15-2007, 01:42 PM   #1 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"Fritz" <fritz.fischer@gmail.com> wrote in message
news:1168886715.948981.66320@q2g2000cwa.googlegroups.com...[color=blue]
>I have a 1990 Camry wagon that I love, but currently can't open the
> hood. This is a problem because the car leaks oil and I'm becoming
> scared of driving it.
> When I pull on the lever, there is no resistance, but I tried pulling
> the wire itself with a pair of pliers from within the car and the cable
> didn't seem to be completely lose (I wasn't able to pull the broken
> cable into the car).
> I have removed the grille and can't see any way to access the cable at
> the latch to pull it and have removed the bolts holding the latch to
> the car, but the latch catches as I try to lift the hood, so I'm only
> able to open it about an inch.
> I have also tried to push the catch on the latch over, but spent about
> an hour doing this and stopped before complete insanity set in.
> Any help is greatly appreciated because I am quite seriously thinking
> about drilling a hole through the hood and forcing the latch open that
> way.
> Thanks very much,
> Fritz.
>[/color]
There are 2 releases for the hood - the cable release in the car and a
secondary release under the hood.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
how to pop hood if cable is shot?!?! 92v6pickup 89-95 Toyota Pickup/Hilux 4 10-06-2006 02:02 PM
1997 camry battery cable wakeman 3rd & 4th Generation (1992–1996 & 1997–2001) 2 08-01-2006 10:32 AM
Hood Latch prob with '05 Camry????? ASG14 5th & 6th Generation (2002-2006 & 2007-2011) 14 02-25-2005 09:51 PM
broken antenna cable 96 camry tealcamry 3rd & 4th Generation (1992–1996 & 1997–2001) 1 01-19-2002 08:52 AM
