Re: Corolla speaker removal ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-15-2007, 05:58 PM   #1 (permalink)
Pete Moss
Guest
Posts: n/a
View Pete Moss's Photo Gallery
In article <1168827406.039091.309600@m58g2000cwm.googlegroups.com>,
[email]johngdole@hotmail.com[/email] wrote:
[color=blue]
> Check the free online guide at Autozone.com:
> Speakers:
> [url]http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80[/url]
> /16/ab/fe/0900823d8016abfe.jsp
> Doors:
> /16/c3/91/0900823d8016c391.jsp
> bettinamike wrote:[color=green]
> > Hi, I have a 1995 Corolla, I need to replace the front speakers.
> > How do I get to them ? can I just remove the grill that is on th door
> > How do I remove the grills ? Do I have to remove the door panel ?
> > Please...help.. Need tunes.... Thanks Mike[/color][/color]
Thanks for the links, but the speaker removal one is wrong, at least for
the back deck. You have to remove the entire back deck to remove them,
not just pop up the grills like the Autozone site says.
Old 01-17-2007, 07:17 PM   #2 (permalink)
Danny Taggart
Guest
Posts: n/a
View Danny Taggart's Photo Gallery
IF you buy speakers from Crutchfield, they give you instructions and any
hardware you should need for installation.
Old 01-17-2007, 10:25 PM   #3 (permalink)
bettinamike
Guest
Posts: n/a
View bettinamike's Photo Gallery
Re: Re: Corolla speaker removal ?
I allready have the speakers, I only need some instructions on how to
remove window handle, and other parts to remove door panel.
Thanks Mike :?:
"Danny Taggart" wrote:[color=blue]
> hardware you should need for installation.[/color]
Posted at author's request, using [url]http://www.AutoBoardz.com[/url] interface
Articles individually verified to usenet standards. Visit URL to contact author/report abuse
Thread archive: [url]http://www.AutoBoardz.com/speaker-removal-ftopict203302.html[/url]
Old 01-17-2007, 10:56 PM   #4 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"bettinamike" <none@000.com> wrote in message
news:965489_caffb7e709f86e5dd368565329e96a11@autoboardz.com...[color=blue]
> Thanks Mike :?:
> "Danny Taggart" wrote:[color=green]
>[/color]
If you have a manual window, the crank is held on with a C-shaped wire clip.
If you push the inner door panel towards the outer door panel around the
crank, you may be able to see the C-clip. Pop the clip off with a small
screwdriver, or use a rag to snag the end of the clip and work it off.
Look at the underside of the arm rest for plastic plugs. Pop the plugs out
with a small screwdriver to reveal the screws that hold the arm rest in
place.
There may be a screw holding the trim bezel around the door release - if so,
remove it.
Starting at the bottom of the door, carefully pull the inner door panel away
from the rest of the door and work your way around the bottom and sides.
Once all of the clips are released, lift up where the weatherstrip runs
along the window.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
speaker removal sandeep 3rd & 4th Generation (1992–1996 & 1997–2001) 4 10-03-2006 04:29 AM
door speaker removal toyotaholic Camry & Solara Lounge 8 12-24-2005 04:15 PM
2004 Corolla LE Radio removal.. KyChristopher02 Archived Corolla threads 2 09-11-2005 09:04 AM
05 Corolla S Speaker size Front & Rear Kalei Archived Corolla threads 0 04-04-2005 11:22 PM
87 Corolla fx bumper removal? Dicipleofthelie Archived Corolla threads 5 06-11-2004 09:29 PM
