Re: rain water in my 2001 toyota celica
"jaysfastcar" <none@000.com> wrote in message
news:964754_768fd7c6266e8031ec243c1b04d4f8ed@autoboardz.com...[color=blue]
> when it rains the driver side floor becomes soaked and i know this is
> not good. HOW DO I FIX IT QUICK and cheep?
>[/color]
The quick and cheap way to fix a wet floor is to find where the water is
getting in and sealing the leak or allowing the water to drain.
If you have an aftermarket alarm, remote starter, audio system, GPS, etc.,
check where the wires pass through the firewall. Make sure all grommets
through the firewall are in place.
If you have a factory sunroof, make sure the drain is not clogged.
Make sure that the door drains are not clogged.
If the windshield has ever been replaced, make sure the urethane dam is
intact.
Ray O
