Necessary tools for any workshop: - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-17-2007, 11:33 PM   #1 (permalink)
=?iso-2022-jp?q?Hachiroku_=1B$B%O%A%m%=2F=1B=28B?=
Guest
Posts: n/a
View =?iso-2022-jp?q?Hachiroku_=1B$B%O%A%m%=2F=1B=28B?='s Photo Gallery
(Stolen from another group...)
drill PRESS: A tall upright machine useful for suddenly snatching flat
metal bar stock out of your hands so that it smacks you in the chest and
flings your beer across the room, splattering it against that
freshly-stained heirloom piece you were drying.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under
the workbench with the speed of light. Also removes fingerprints and
hard-earned guitar calluses from fingers in about the time it takes you to
say, "You shit...."
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes
until you die of old age.
SKILL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of
blood-blisters. The most often the tool used by all women. BELT SANDER: An
electric sanding tool commonly used to convert minor touch-up jobs into
major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board
principle. It transforms human energy into a crooked, unpredictable
motion, and the more you attempt to influence its course, the more dismal
your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt
heads. If nothing else is available, they can also be used to transfer
intense welding heat to the palm of your hand.
WELDING GLOVES: Heavy duty leather gloves used to prolong the conduction
of intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable
objects in your shop on fire. Also handy for igniting the grease inside
the wheel hub you want the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older British cars and
motorcycles, they are now used mainly for impersonating that 9/16 or ½
socket you've been searching for the last 45 minutes.
TABLE SAW: A large stationary power tool commonly used to launch wood
projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after
you have installed your new brake shoes, trapping the jack handle firmly
under the bumper.
EIGHT-FOOT LONG YELLOW PINE 2X4: Used for levering an automobile upward
off of a trapped hydraulic jack handle.
TWEEZERS: A tool for removing wood splinters and wire wheel wires.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known
drill bit that snaps neatly off in bolt holes thereby ending any possible
future use.
RADIAL ARM SAW: A large stationary power saw primarily used by most shops
to scare neophytes into choosing another line of work.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of
everything you forgot to disconnect.
CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar that
inexplicably has an accurately machined screwdriver tip on the end
opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
TROUBLE LIGHT: The home mechanic's own tanning booth. Sometimes called a
drop light, it is a good source of vitamin D, "the sunshine vitamin,"
which is not otherwise found under cars at night. Health benefits aside,
its main purpose is to consume 40-watt light bulbs at about the same rate
that 105mm howitzer shells might be used during, say, the first few hours
of the Battle of the Bulge. More often dark than light, its name is
somewhat misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids
and for opening old-style paper-and-tin oil cans and splashing oil on your
shirt; but can also be used, as the name implies, to strip out Phillips
screw heads. Women excel at using this tool.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to
convert common slotted screws into non-removable screws.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning
power plant 200 miles away and transforms it into compressed air that
travels by hose to a Chicago Pneumatic impact wrench that grips rusty
bolts which were last over tightened 30 years ago by someone at Ford, and
instantly rounds off their heads. Also used to quickly snap off lug nuts.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket
you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is
used as a kind of divining rod to locate the most expensive parts adjacent
the object we are trying to hit. Women primarily use it to make gaping
holes in walls when hanging pictures.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard
cartons delivered to your front door; works particularly well on contents
such as seats, vinyl records, liquids in plastic bottles, collector
magazines, refund checks, and rubber or plastic parts. Especially useful
for slicing work clothes, but only while in use.
DAMMIT TOOL: Any handy tool that you grab and throw across the garage
while yelling "DAMMIT" at the top of your lungs. It is also, most often,
the next tool that you will need.
Old 01-18-2007, 05:27 AM   #2 (permalink)
mark_digital©
Guest
Posts: n/a
View mark_digital©'s Photo Gallery
Re: Necessary tools for any workshop:
"Hachiroku ????" <Trueno@AE86.gts> wrote in message
news:SMCrh.4390$dV1.1717@trndny02...[color=blue]
> say, "You shit...."
> under the bumper.
> future use.
>[/color]
A friend long ago had a big impressive roll-away. Much nicer than mine. He
also had a cheapy little plastic fishing tackle box where he kept grease
pencils, micrometers and a few little gages.
On the day he retired we all went over to help him clean out his roll-away
so it could be wired (a method of securing a personal item proving no
company owned material was left in it). We laughed. Every drawer was chuck
full of red wipers (mechanics rags).
Everything he ever needed was in the tackle box.
Old 01-18-2007, 09:19 AM   #3 (permalink)
jor
Guest
Posts: n/a
View jor's Photo Gallery
On 2007-01-18 06:45:27 -0700, "Mark" <bogusmailmark@yahoo.com> said:
[color=blue]
> LOL, there's at least a kernel of truth (and experience) in many of
> these. My favorites are the table saw, E-Z out and trouble light ;-)
> Yea, easy-out has got to be the most inappropriately named tool there
> is! In my experience, it's never easy and it usually doesn't come out![/color]
jor
Old 01-18-2007, 08:46 PM   #4 (permalink)
Don Fearn
Guest
Posts: n/a
View Don Fearn's Photo Gallery
I think it was Hachiroku ???? <Trueno@AE86.gts> who stated:
[color=blue]
>(Stolen from another group...)[/color]
Compare to the original written by Peter Egan (whose writing I know
and love in Cycle World magazine):
The Right Tool For The Job
by Peter Egan
Road & Track
April, 1996
Had a strange dream the other night: I was out in my workshop, making
sandwiches, for some reason, and I had about a dozen slices of bread
laid out on the workbench. (Sanitation is meaningless in dreams,
unless the dream lasts long enough for you to become seriously ill.)
Oddly, I was spreading mayonnaise on the bread with a tiny Craftsman
screwdriver of the size normally used to fix alarm clocks or busted
Smiths tachometers. Naturally, it was taking forever, and I was quite
frustrated with the whole process.
Before we put too heavy a Freudian spin on this dream (inadequate
tools, etc.), I should mention that I had some Wild Turkey on the
rocks after a dinner of chorizo enchiladas with Negra Modelo, which is
asking for trouble if you include the espresso we had while watching
Bullitt again. When I went to bed, my neurons were firing like a
string of cheap Chinese firecrackers.
Anyway, dedicated mechanics will recognize immediately the source of
frustration in this dream: I was using the wrong tool for the job.
Anyone with an ounce of mechanical experience will tell you that a
better tool for spreading mayonnaise on bread would have been, say, a
broad-tipped Snap- on gasket scraper or an old hacksaw blade with some
spring to it. The only legitimate use of a small, thin-tipped
Craftsman screwdriver, of course, is to mix epoxy resin and hardener
to a consistent dark gray color on the torn-off lid of a Fram oil
filter box.
There's a lot of this kind of tool-use confusion in garages today, so
I thought it might be helpful (leaning on my years of experience, as
usual) to reveal to the novice mechanic the rightful roles of the
tools found in that 2000-piece tool set your family got you for
Christmas ($4000 cheaper than if they'd bought each tool separately!).
Let's start with the main stuff.
Hammers: Probably the Original Tool, if you exempt (as I always do) a
straw stuck down a termite nest in search of food, as used by lower
primates and some of the guys who were in my high school shop class.
Originally employed as a weapon of war, the hammer is nowadays used as
a kind of divining rod to locate expensive car parts not far from the
object we are trying to hit. For those with a more accurate sense of
aim, the hammer is useful for tapping on oilpans, water pumps and
other brittle pot-metal castings to see if we've forgotten to remove
one of the bolts, which we have.
Electric hand drill: Normally used for spinning steel Pop rivets in
their holes until you die of old age, but it also works great for
drilling rollbar mounting holes in the floor of a sports car just
above the brake line that goes to the rear axle.
Pliers: Used to round off bolt heads.
Hacksaw: One of a family of cutting tools built on the Ouija board
dismal your future becomes.
Vise-Grips: Used to round off bolt heads. If nothing else is
available, they can also be used to transfer intense welding heat to
Oxyacetylene torch: Used almost entirely for lighting those stale
garage cigarettes you keep hidden in the back of the Whitworth socket
drawer (what wife would think to look in there?) because you can never
remember to buy lighter fluid for the Zippo lighter you got from the
PX at Fort Campbell.
Zippo lighter: See Oxyacetylene torch.
Whitworth sockets: Once used for working on older British cars and
motorcycles, they are now used mainly for hiding 6-month-old Salems
from the sort of person who would throw them away for no good reason.
Drill press: A tall upright machine useful for suddenly snatching flat
and flings your beer across the room, splattering against the Rolling
Stones poster over the bench- grinder.
Wire wheel: Cleans rust off old bolts and then throws them somewhere
under the workbench with the speed of light. Also removes finger-print
whorls and hard-earned guitar callouses in about the time it takes you
to say, "Django Reinhardt."
Hydraulic floor jack: Used for lowering a Mustang to the ground after
you have installed a set of Ford Motorsports lowered road springs,
trapping the jack handle firmly under the front air dam.
Eight-foot-long Douglas fir 2x4: Used for levering the car upward off
the hydraulic floor jack, perhaps.
Tweezers: A tool for removing wood slivers.
Phone: Tool for calling your neighbor Chris to see if he has another
hydraulic floor jack.
Snap-on gasket scraper: Theoretically useful as a sandwich tool for
spreading mayonnaise; used mainly for getting dog-doo off your boot.
E-Z Out bolt and stud extractor: A tool that snaps off in bolt holes
and is ten times harder than any known drill bit.
Timing light: A stroboscopic instrument for illuminating grease
buildup on crankshaft pulleys.
Sanyo boombox: An electromechanical device that miraculously allows
lovely Cecilia Bartoli to sing Rossini arias in a garage full of
choking paint fumes, which is something she would not normally be
inclined to do.
Two-ton hydraulic engine hoist: A handy tool for testing the tensile
strength of ground straps and hydraulic clutch lines you may have
forgotten to disconnect.
Shop manual: A kind of mirror whose smudges and grease stains reflect
the true soul of the clean and apparently innocent car standing
nearby; the automotive equivalent of a police blotter.
Shop rags: Composed almost entirely of pink lint, shop rags are
essentially a washable version of the shop manual; when laundered at
home they add a nice fresh scent to the washer and dryer.
Craftsman ½ x 16-in. screwdriver: A large motor mount prying tool that
without the handle.
Compression gauge: Used during buyer's inspections by overly cautious
consumers who do not own a 2-ton hydraulic engine hoist or a Craftsman
½ x 16-in. screwdriver.
Outside micrometer: A device for periodically reviewing the meaning of
all those little incremental marks on the barrel and trying to
remember whether they translate into thousandths or hundred
thousandths of an inch and exactly how many decimal places to the
right of the period that is, anyway.
Battery electrolyte tester: A handy tool for transferring sulfuric
acid from a car battery to the inside of your toolbox after
determining that your battery is dead as a doornail, just as you
thought.
Metric wrenches: Used on cars from countries whose citizens believe
that an acute misunderstanding of the earth's circumference (updated
to a unit equal to 1,650,763.3 wavelengths of the orange-red radiation
of an isotope of krypton) is a more legitimate and easier–to–visualize
form of measurement than the instep of a dead king (as in, "Ludwig,
let us pace off those wavelengths again!" Or, "Zut alors! I need to
measure the curtains and I have forgotten my isotope of krypton!"). On
American and British cars, metric tools are used primarily to round
off bolt heads.
Aviation metal snips: See hacksaw.
Trouble light: The mechanic's own tanning booth. Sometimes called a
aside, its main purpose is to consume 40-watt light bulbs at about the
same rate 105-mm howitzer shells might be used during, say, the first
few hours of the Battle of the Bulge. More often dark than light, its
name is somewhat misleading.
Phillips screwdriver: Normally used to stab the lids of old-style
paper-and-tin oil cans and splash oil on your shirt; can also be used,
as the name implies, to round off Phillips screw heads.
Air compressor: A machine that takes energy produced in a coal-burning
powerplant 200 miles away and transforms it into compressed air that
suspension bolts last tightened 40 years ago by someone in Abingdon,
Oxfordshire, and rounds them off.
Grease gun: A messy tool for checking to see of your zirk fittings are
still plugged with rust.
Deep-well sockets: Normally used as piston-pin and wheel-bearing
drifts, deep- well sockets are also good for drawing circles when a
coffee-can lid would be way too big.
Toshiba miniature refrigerator: A trouble-free appliance, manufactured
to metric standards; used primarily to chill Lotus piston pins down to
an easy press-fit while storing up to 12 bottles of Guinness stout,
proving once again that Science is really at its best in the service
of Art.
Well, that's enough for now. I've got lots of unmentioned tools left
in the old box, but I should probably save them for another day when I
run out of column ideas, much as I did earlier this morning.>
Now you know the ORIGINAL version!
I wish the buck stopped here; I could use a few
Old 01-18-2007, 11:11 PM   #5 (permalink)
Guest
Posts: n/a
On Thu, 18 Jan 2007 19:46:13 -0600, Don Fearn wrote:
[color=blue]
> Toshiba miniature refrigerator: A trouble-free appliance, manufactured to
> metric standards; used primarily to chill Lotus piston pins down to an
> easy press-fit while storing up to 12 bottles of Guinness stout, proving
> once again that Science is really at its best in the service of Art.
> Now you know the ORIGINAL version![/color]
Damn! The version I stole left out the most important tool! Guiness...the
man's a man after my own heart.
And, IIRC, I used to read his stuff elsewhere about 20 years ago, either
in Dirt Bike or Car and Driver, I can't remember...
AND, IIRC, if it was Dirt Bike, I think he was the one talking about an
evening with his lady, and in the morning she came out to the kitchen
while he was making coffee, with the handlebars still strapped to her back
and a tear in her eye, that he decided he was spending too much time
riding bikes...
Old 01-19-2007, 12:01 AM   #6 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"Don Fearn" <pooder@charter.net> wrote in message
news:dc80r2hg8kjvbp9mc745i8hpm9jl50df9r@4ax.com...[color=blue]
>[color=green]
> by Peter Egan
> Road & Track
> April, 1996[/color]
<snipped>
[color=blue]
> Stones poster over the bench- grinder.[/color]
Who has pictures of Mick and Keith in their garage? Most garages I've
visited seem to have pictures of the car or model they lust after.
[color=blue]
> still plugged with rust.[/color]
Also useful for blowing out the boots on ball joints.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
Harbor Freight Tools? bowlofturtle General Discussion 17 02-21-2006 11:55 PM
Tools what do you have? bowlofturtle Off Topic 27 02-15-2005 12:16 AM
The Mandatory Tools Thread brink General Discussion 30 10-23-2004 01:21 PM
Tools needed to work on a camry zoni Camry & Solara Lounge 10 05-05-2004 07:39 PM
