Problem with Tire sensors on 4Runner? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-18-2007, 08:56 AM   #1 (permalink)
Anonomouse
Guest
Posts: n/a
View Anonomouse's Photo Gallery
Has anyone else had problems with the tire sensors on the 2004 4runner?
Mine keeps going off and i've had them replaced, but it hasn't solved my
problem.
Old 01-18-2007, 11:29 AM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Problem with Tire sensors on 4Runner?
"Anonomouse" <Anonomouse@verizon.net> wrote in message
news:L0Lrh.3824$E35.620@trnddc02...[color=blue]
> problem.[/color]
When "going off," does that mean that you are getting a low tire pressure
warning?
Assuming that you verified tire pressure with a good tire pressure gauge,
did you also check the spare tire?
Ray O
Old 01-18-2007, 11:49 PM   #3 (permalink)
Ray O
Guest
Posts: n/a
news:3JWrh.2849$jG1.175@trnddc04...[color=blue]
> Yes, the tire sensor warning light is coming on. Yes, the spare has the
> correct amount of air also.
>[/color]
To answer your original question, yours is the first post I recall reading
regarding a low pressure warning system that uses actual air pressure
sensors. Some systems use the ABS speed sesnors that turn on a light if it
detects a speed differential due to an underinflated tire.
Were the sensors replaced at a Toyota dealership? After the sensors were
replaced, did the system work correctly for a while or did the light come on
right away? I assume that the shop that replaced the sensors offers some
kind of warranty on the repair so you should be able to bring it back if it
is still within the warranty period, which I believe is 12 months/12,000
miles or the balance of the 36 month/36,000 original vehicle warranty,
whichever is longer.
I can only think of 6 things that would make the tire pressure warning light
come on.
1) Tire pressure is low in one or more tires (which you have already
eliminated as a possible cause)
2) The new sensors were not "registered" correctly with the receiver or the
receiver is picking up a signal from another source
3) Something has contaminated one or more of the sensors. Possible
contaminants are moisture in the compressed air used to fill the tire, bead
sealer used to seat the tire bead on the wheel rim, or a fix-a-flat or green
slime product
4) One or more of the sensors is defective
5) There is a problem with the low pressure warning light receiver circuit
or control module.
Ray O
Old 01-19-2007, 01:39 PM   #4 (permalink)
mrv@kluge.net
Guest
Posts: n/a
View mrv@kluge.net's Photo Gallery
Anonomouse wrote:[color=blue]
> problem.[/color]
See:
[url]http://www.alldata.com/tsb/Toyota/1164700800000_1165824000000_PG004-06/index.html[/url]
US TSB PG004-06
Direct-type tire pressure warning system diagnositc tips
Nov. 28, 2006
2004-2007 4Runner
2005-2006 Tundra
2005-2007 Sequoia
2006-2006 Land Cruiser, Prius, RAV4, Tacoma
2007 Avalon, Camry, Solara, Scion tC
and
[url]http://www.alldata.com/tsb/Toyota/1166688000000_1167292800000_PG001R-04/index.html[/url]
US TSB PG001-04
Direct tire pressure warning system
March 16, 2004, revised December 21, 2006
2004-2007 4Runner
Old 02-02-2007, 03:32 PM   #5 (permalink)
Ray O
Guest
Posts: n/a
"a27lee" <none@000.com> wrote in message
news:972364_8f12479d6a88d0bb6f061da59c02f316@autoboardz.com...[color=blue]
>I am having this problem as well. 06 4runner, barely 8 months old.
> low pressure signal went on, i checked the tire and it was low, so i
> changed out the spare. light went away. few days later, came back
> on, and i checked all the tires and they are all at 35psi. going to
> dealer later to check it out.
> "Anonomouse" wrote:[color=green]
> > 4runner?
> > solved my
> > problem.[/color]
>[/color]
There is a TSB on an updated Tire Pressure Sensor for 2005 and 2006 Tundras,
perhaps the condition is similar to the 4Runner.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
tire sensors toyotateddy 1st Generation (2000–2006) 10 07-06-2010 07:40 PM
Tire Pressure sensors 05 Highlander GH05 1st Generation (2001–2007) 8 10-31-2007 09:08 PM
Tires Feedback: Everyone please contribute. EKam Hardcore Tech and Competition 98 12-19-2006 03:05 AM
4Runner w/ a different warm start problem Larry39 4Runner Lounge 0 12-24-2005 12:17 AM
4Runner V6 engine problem johnwruss 4Runner Lounge 3 04-24-2005 03:32 AM
