Corolla 2000 Mass Air Flow Sensor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-18-2007, 12:17 PM   #1 (permalink)
Joe
Guest
Posts: n/a
View Joe's Photo Gallery
Hi all,
Recently, the Check Engine light turned on and, after taking it to the shop,
they tell me that a sensor need to be replaced. It is the Mass Air Flow
Sensor. Can anyone tell me 1) Is this is an expensive sensor and 2) Is it
difficult to replace?
My car is a 2000 Toyota Corolla, 4cyl automatic with about 50000 miles on
it.
Your help will be much appreciated...
-Joe.
Old 01-18-2007, 03:34 PM   #2 (permalink)
Joe
Guest
Posts: n/a
Re: Corolla 2000 Mass Air Flow Sensor
Thanks for your reply. I realize that 'expensive' and 'difficult' are
relative terms and I should have been more specific. Thanks again.
-Joe.
"Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message
news:581f$45afceb4$44a4a10d$18966@msgid.meganewsservers.com...[color=blue]
> "Joe" <guichov@yahoo.com> wrote in message
> news:eooa8k$1ui2$1@ihnp4.ucsd.edu...[color=green]
>> Hi all,
>> shop, they tell me that a sensor need to be replaced. It is the Mass Air
>> Flow Sensor. Can anyone tell me 1) Is this is an expensive sensor and 2)
>> Is it difficult to replace?
>> it.
>> -Joe.[/color]
> 1) Whether it is "expensive" or not depends on your definition of
> "expensive." I've never priced one, hachiroku says it is around $325,
> that sounds about right to me.
> 2) Again, whether it is "difficult to replace" depends on your definition
> of "difficult." It is attached to the engine air filter housing. It is
> the only part with wires sticking out on the air filter housing. The MAF
> sensor is not supposed to be a serviceable part, which to me means that
> there is nothing to lose in trying to fix it before replacing it. Remove
> the MAF sensor from the air filter housing, you will see a tube that
> protrudes into the air flowing out of the air filter. Inside the tube is
> a thin metal wire. Try cleaning the wire very gently with rubbing alcohol
> or carburetor cleaner and a Q-tip. The MAF sensor is basically a heated
> wire, and air flowing past it cools the wire. As the wire cools, its
> resistance changes, and as its resistance changes, voltage going back to
> the computer changes. By monitoring the voltage coming from the MAF
> sensor, the computer knows how much air is going into the engine. If the
> wire gets covered with crud, the crud acts like an insulator and so air no
> longer cools the wire.
> If the cleaning attempt doesn't work, then go ahead and replace it. BTW,
> make sure you clear the trouble codes after cleaning and/or replacement.
> Ray O
> (correct punctuation to reply)
>[/color]
Old 01-18-2007, 06:55 PM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
news:eoolpe$22bq$1@ihnp4.ucsd.edu...[color=blue]
> -Joe.
>[/color]
You're welcome! Try cleaning the sensor before you replace it. It
shouldn't take more than 5 minutes and the only skill needed is to unplug it
and remove a couple of screws.
Ray O
Old 01-18-2007, 10:31 PM   #4 (permalink)
=?iso-2022-jp?q?Hachiroku_=1B$B%O%A%m%=2F=1B=28B?=
Guest
Posts: n/a
View =?iso-2022-jp?q?Hachiroku_=1B$B%O%A%m%=2F=1B=28B?='s Photo Gallery
On Thu, 18 Jan 2007 09:17:33 -0800, Joe wrote:
[color=blue]
> Hi all,
> it.
> -Joe.[/color]
Well, I *FINALLY* yanked the manual from my Scion today to have a look
through it. You MAF is only warrantied 24/24,000 per the Feds, or
36/36,000 per Toyota. Some are maked 8/80 (8 years, 80,000 miles)
The MAF is a 3/36,000...
Old 01-19-2007, 11:10 PM   #5 (permalink)
mrsteveo
Guest
Posts: n/a
View mrsteveo's Photo Gallery
I own a 2002 Toyota Corolla and I own a screw driver... and I managed
to clean my MAF sensor myself! Like everyone else said, it's the only
wire thing on the airbox. Mine was 2 screws, and the elctrical wire.
Just unscrew it and pull out the wire. I got some brake cleaner I
think was recommended (?) and sprayed it from a distance. I wouldn't
use a QTIP though. You don't want to break that thin wire and it's
easy to do. Anyway, sprayed with break cleaner and then gently with
canned air afterwards. Let it dry for a few hours and put it back in.
Worked great...
I check it every time I replace my air filter because sometimes it
needs a good cleaning.
Joe wrote:[color=blue]
> Hi all,
> it.
> -Joe.[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
"Check engine light" error codes po446, po442, po440???? serabell xA Forum 10 04-12-2009 11:31 PM
Turbo the tercel? Flymasta K Tercel, Paseo, Starlet, and Sera Forum 19 01-31-2005 12:38 AM
Mass Air Flow Sensor 86CRESSIDA86 General Discussion 4 04-29-2002 02:40 PM
Air Mass Sensor Problem! Vato Loco General Discussion 1 04-28-2002 06:14 PM
