Regarding surging at idle
Hi. I have a 1986 Camry with a 2SE 2.0L engine, and the idle sometimes drops (surges) 300 - 400 RPM, sounding like it wants to quit almost. If the idle control valve is clogged, is it serviceable or does it need replacing?
I am also looking at buying a 90 - 92 Camry. Are both the I4 and V6 engines DOHC? I have a motorbike with DOHC, and valve (shim) adjustment is a major operation. Do both these engines use shims, and do you have to take the cams out to replace the shims? I know some engines you do, and some you don't.
Thanking you in advance,
Herb Kruschke
Calgary, Canada
