The Subject line pretty much states my point. We have discussed
how carefully a Toyota hybrid's main battery is cosseted by some
fancy control electronics, thereby extending its operating life.
I wondered, how long before this technique is ported to maintain
the basic 12v battery? The two batteries are not working in the
same way, of course; but surely _something_ can be carried over,
even if it's just when to cease (over)charging. Those factories
making the big batteries could also make 12v versions along with
the smaller control gear. Making loads should cut the price and
reduce the number of dead 12v batteries to be dealt with.
Andrew Stephenson
Re: Could normal batteries learn from hydrid tech?
"Andrew Stephenson" <ames@deltrak.demon.co.uk> wrote in message
news:1169421631snz@deltrak.demon.co.uk...[color=blue]
> Andrew Stephenson
>[/color]
The battery packs in hybrid vehicles are dry-cell batteries, while the
"basic 12V" battery is a wet-cell lead-acid battery. To a certain extent,
the voltage regulator already regulates voltage for the conventional
battery, but if it were changed to the same type used for the hybrid power
pack, then I would think that the same regulating logic could be applied to
it.
Andrew Stephenson <ames@deltrak.demon.co.uk> wrote:[color=blue]
> reduce the number of dead 12v batteries to be dealt with.[/color]
Soon, I hope! Considering the corporate interia in Dee-troit however,
I'm not holding by breath.
We have some GP brand NiMH batteries bought at least 10 years ago.
They're just small AA cells, but we've used them a lot over the years
and they're still working.
Every time I look at the toxic white-stuff forming on top of my
12V truck battery, it scares me. (Does it help to pour Diet Coke
on that stuff? I'm concerned about nearby components, such as
headlight, right turn signal, and oil dipstick.)
Of course the conspiracy theorists think it's because Texaco/Chevron
owns large-cell NiMH technology and is trying to suppress it.
"Bill Tuthill" <ccreekin@yahoo.com> wrote in message
news:45b4f9e0@news.meer.net...
<snipped>
[color=blue]
> headlight, right turn signal, and oil dipstick.)[/color]
To get rid of the white stuff forming on top of the battery, you can use a
poultice of baking soda and water or you can use commercial stuff available
at auto parts stores. I would remove the battery from the vehicle before
cleaning, and use lots and lots of water to rinse off the battery and
battery tray afterwards.
Those colored felt washers that go under the battery clamps look gimmicky
but they actually help. Before installing the battery clamps, coat the
posts with dielectric grease, lithium grease, or an aerosol battery
protectant available at auto parts stores. I personally prefer the spray
stuff from auto parts stores because it goes on like spray paint and isn't
as messy as grease. The white stuff that forms on the battery posts and
clamps comes from the gas that naturally escapes from the battery through
the gap between the plastic battery case and the posts, so make sure that
whatever you use to coat the posts covers the seam between the plastic and
posts. Then slip those felt washers on over the posts, install the clamps,
and give it another coat of protectant.
In article <56b38$45b4fe44$44a4a10d$21687@msgid.meganewsservers.com>
rokigawaATtristarassociatesDOTcom "Ray O" writes:
[color=blue]
> [...] the white stuff forming on top of the battery [...][/color]
From your diagnosis of its formation, I am guessing Lead Sulphate
(US:Sulfate), though remotely possibly it could be Lead Oxide.
(Side Bar on this: "Lead white" (lead oxide) was popular with old
time painters as a white. Upon exposure to industrial pollution,
this gradually transforms to lead sulphide, which is dark. Hence
that brilliant white paint dulls. The usual treatment IIRC is to
apply a chemical to convert the sulphide into the sulphate, which
is white again -- but a subtly different white, so the salvage is
not perfect.)
Andrew Stephenson
news:1169495766snz@deltrak.demon.co.uk...[color=blue]
>[color=green]
> not perfect.)
> Andrew Stephenson
>[/color]
