Knock Code on 2000 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-02-2007, 12:51 PM   #1 (permalink)
hassnein@yahoo.com
Guest
Posts: n/a
View hassnein@yahoo.com's Photo Gallery
The check engine light came on the other day and i took it in to see
what was wrong. They ran a diagnostic test and said that the Knock
sensor was malfunctioning. He said i had to replace the knock sensor
which would cost about $250.
I'm a little concerned about this because shouldn't they have atleast
tested the sensor to check resistence?
what if the sensor is fine and there really is a "knocking" problem?
I realise that it may be difficult to check the sensor but my car is a
4 cylinder and from what i'm told it appears it is easy to get at.
i don't know a lot about cars but simply replacing a sensor that shows
a malfunction doesn't really seem like a solution.
Any ideas?
Old 02-02-2007, 05:04 PM   #2 (permalink)
ajay_987654
Guest
Posts: n/a
View ajay_987654's Photo Gallery
Re: Knock Code on 2000 Camry
Thanks for the response. I took it into my local Toyota dealership
and the service advisor said (after charging me $90 for the scan) that
the scan shows a "knock sensor" code but they "claim" they checked
everything and its all fine so therefore he felt that the knock sensor
is gone and i should get a new one. I'm not sure if he did any of the
testing you listed but i'm not hearing anything wrong with my engine
so i don't know what to do. He made it sound like just get a new
sensor and the problem will be solved. Surely there must be some kind
of testing to make sure the sensor itself is working or not before
making such a recommendation.
Maybe i should take it to another mechanic to see whats wrong. THe
last thing i want to do is put in a new sensor and have the light go
off again.
Old 02-02-2007, 05:34 PM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"ajay_987654" <hassnein@yahoo.com> wrote in message
news:1170453899.423142.51980@j27g2000cwj.googlegroups.com...[color=blue]
> off again.
>[/color]
If the warranty has expired on the car, I would wait to see if the check
engine light comes back on. Unfortunately, the I don't think the knock
sensor is not covered by the emissions warranty (check your warranty book to
confirm). If the check engine light comes back on, take it to a place that
will let you use the OBD II code scanner for free like AutoZone and check
the codes. If the code is the same one as noted on the repair order from
the dealership, then go to the dealership and purchase the part from the
parts department and replace it yourself. Replacing the sensor involves
unplugging a wire from it, unscrewing the sensor from the engine block, and
reversing the process.
Good luck!
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
Personal Camry Websites - POST HERE Silver Streak Camry & Solara Lounge 193 08-03-2011 12:56 PM
Fusion marches past Camry! sciguy0504 Camry & Solara Lounge 38 05-04-2006 07:27 AM
need advice: what should my next mod be? 2000 camry cman2000 3rd & 4th Generation (1992–1996 & 1997–2001) 17 11-16-2004 11:05 PM
2000 Gen IV Radio security code CamryGordo 3rd & 4th Generation (1992–1996 & 1997–2001) 3 10-13-2004 01:55 AM
