Re: Oil Leak and Coolant Issue? 96 Camry
#1 they are proned to leaking oil from the distributer "o" ring you have to
remove the distributer to replace that. the other thing is i think you have
a head gskt problem.to determine this there is a block tester that goes on
where your rad cap fits it has a solution in it that changes colour from
the engine gases indicating a leak. you can also buy a special ultriviolet
dye that goes in your engine oil for easy tracing of oil leaks,if you us
this shampoo your engine first
