1990 celica. Challenging problem. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-03-2007, 12:25 AM   #1 (permalink)
Crazzytown
Guest
Posts: n/a
View Crazzytown's Photo Gallery
I have a 1990 Toyota Celica everything was running perfectly fine
driving it around. One day parked it overnight and it wouldnt start
the next day. Thought ok. Battery must be dead. Even though it was a
brand new battery thought maybe I left a light on. Got a boost and
drove it back to where i live and left it running for 2 hours. Drove
it around for 10 minutes and parked it for the night. Went to start it
again the next day and nothing. Thought I somehow left the light on
again. Got a boost. And let it run for 2 hours.
Went back to try and drive it around and the RPM’s were going from
1200 -1400 constantly up and down. But battery seems fine when I put
on the radio. As soon as I go to put it into reverse and press the
brake. The battery signal comes up. Everytime i hit he breaks the
battery light would come on. So I figure I had a problem with my
altinator. Got a miltimeter the next day. Yet another boost and
checked the battery. It read 15 amps. Should only be high 12’s low
13’s if it is just the charge from the boost... Correct?. So i believe
I found it isnt my altinator. And I checked for corrosion on the
battery. 0.0 amps on the negative and 0.1 on the positive. So good
connections there. So I figure’d I’d let my car run for five minutes
and see what happened. Everything seemed fine. Turned all the lights
off and radio off in the car and left it for an hour. Went back to it
an hour later. The car had shut off by its-self.
Can anyone please lend a hand on this one? Would mean a great deal.
Thank you.
Posted at author's request, using [url]http://www.AutoBoardz.com[/url] interface
Articles individually verified to usenet standards. Visit URL to contact author/report abuse
Thread archive: [url]http://www.AutoBoardz.com/1990-Challenging-problem-ftopict205284.html[/url]
Old 02-03-2007, 01:55 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 1990 celica. Challenging problem.
"Crazzytown" <none@000.com> wrote in message
news:972592_baac2ec7f869f108b9e8642ea95c6150@autoboardz.com...[color=blue]
> Went back to try and drive it around and the RPM's were going from
> checked the battery. It read 15 amps. Should only be high 12's low
> 13's if it is just the charge from the boost... Correct?. So i believe
> connections there. So I figure'd I'd let my car run for five minutes
> Thank you.
>[/color]
When you checked the battery, you should check voltage, not amps. It should
read somewhere from 12+ volts to 14.4 volts.
When a car is idling, if the headlights, radio, heater fan, defogger, etc.
are on, the alternator may not put out sufficient amperage to charge the
battery.
When the car will not start, check battery voltage. If battery voltage is
sufficient, then the problem may be in the battery or starter connections.
Check to make sure the battery is properly grounded.
If the battery is more than 5 years old, it may have lost is ability to hold
a charge and needs replacement.
Ray O
Old 02-05-2007, 09:55 AM   #3 (permalink)
Coyoteboy
Guest
Posts: n/a
View Coyoteboy's Photo Gallery
On 3 Feb, 18:55, "Ray O" <rokigawaATtristarassociatesDOTcom> wrote:[color=blue]
> "Crazzytown" <n...@000.com> wrote in message
>[color=green]
> > again. Got a boost. And let it run for 2 hours.[/color]
>[color=green]
> > an hour later. The car had shut off by its-self.[/color]
>[color=green]
> > Can anyone please lend a hand on this one? Would mean a great deal.[/color]
>[color=green]
> > Thank you.[/color]
> battery.
> Ray O
> (correct punctuation to reply)[/color]
When running fine the stock battery and alt will generally charge
enough with 5 mins running to re-start within 6 or 7 hours even if
from a flat battery start condition. I too would suspect the battery
was the fault here but the car stopping itself would suggest the alt
isnt charging the batt either or it would take up the slack? Battery
is the cheapest part to start the replacements at but if you're mis-
reading the meter and ts charging at 15v not Amps I'd say your alt is
over-charging which has likely toasted the battery. Ive never seen
more than 14.4v out of my celicas alt.
Old 02-06-2007, 04:16 AM   #4 (permalink)
kaabdalis
Guest
Posts: n/a
View kaabdalis's Photo Gallery
I had a similar problem with my 1990 Toyota Corolla.
My problem was that the Alternator diodes had burned (somehow)
If the alternator works you should be able to measure about 14V
between the battery poles.
I discovered that a battery voltage of 10V was enough to drive the
car,
But not enough to start it once I turned the engine off.
//Rickard
On 3 Feb, 06:25, Crazzytown <n...@000.com> wrote:[color=blue]
> Thank you.
> Posted at author's request, usinghttp://www.AutoBoardz.cominterface
> Thread archive:[url]http://www.AutoBoardz.com/1990-Challenging-problem-ftopict205284.html[/url][/color]
Old 02-13-2007, 01:25 AM   #5 (permalink)
CoolPR
Guest
Posts: n/a
View CoolPR's Photo Gallery
your getting 15 volts because of the charge should be right. It sounds
to me that you may have a bad diode in your Alternator that’s not
fully charging or perhaps dis charging your battery.
Try running the car again and remove the positive cable from the
battery while the engine is running. If the engine shuts off its your
Alternator. Try not to do this often as it may cause damage to a good
Alternator..
hope that helps..
"Crazzytown" wrote:[color=blue]
> Hey there. im brand new to the site. Never had to get help
> before but im confused on this one.
> fine driving it around. One day parked it overnight and it
> wouldnt start the next day. Thought ok. Battery must be dead.
> Even though it was a brand new battery thought maybe I left a
> light on. Got a boost and drove it back to where i live and
> left it running for 2 hours. Drove it around for 10 minutes
> and parked it for the night. Went to start it again the next
> day and nothing. Thought I somehow left the light on again.
> from 1200 -1400 constantly up and down. But battery seems fine
> when I put on the radio. As soon as I go to put it into
> reverse and press the brake. The battery signal comes up.
> Everytime i hit he breaks the battery light would come on. So
> I figure I had a problem with my altinator. Got a miltimeter
> the next day. Yet another boost and checked the battery. It
> read 15 amps. Should only be high 12's low 13's if it is just
> the charge from the boost... Correct?. So i believe I found it
> isnt my altinator. And I checked for corrosion on the battery.
> minutes and see what happened. Everything seemed fine. Turned
> all the lights off and radio off in the car and left it for an
> hour. Went back to it an hour later. The car had shut off by
> its-self.
> deal.
> Thank you.[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
1990 Toyota Celica 5sfe vi3tcodon Celica Forum 1 01-25-2006 08:40 PM
1990 Toyota Celica 5sfe vi3tcodon Celica Forum 0 01-25-2006 08:35 PM
Help - Problem with 1994 Celica Starting bpate Celica Forum 2 11-02-2005 09:10 PM
2000 Celica "bogs" Fuel delivery problem? somepersian Celica Forum 3 11-15-2004 10:39 PM
