Re: 1995 Pickup with coolant leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-03-2007, 01:58 PM   #1 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
<overconsolidated@gmail.com> wrote in message
news:1170482542.867090.164730@q2g2000cwa.googlegroups.com...[color=blue]
>I have a 1995 V6 extracab SR5 Toyota Pickup (not tacoma) that has a
> coolant leak. The leak is coming from the bottom of the engine. I
> thought it was the lower engine block to radiator return hose, but
> when I inspected it, there was no sign of leaking on the hose or
> connection assembly. However, I can still see fluid on parts located
> directly underneath this assembly. Does anyone know what the problem
> might be? What is located beneath the engine block that might be
> allowing this leak and what will it take to get it fixed? I am a do-it-
> yourself type of guy, and would like to fix it myself if I can figure
> out what it is. When I showed it to a mechanic, he didn't believe me
> that it was even leaking - he thought it was power steering fluid,
> which is leaking too, but that is a whole other post in itself.
> If anyone could help me, I would greatly appreciate it.
> Thanks,
> Dan
>[/color]
If the coolant is leaking from the area near the timing cover and crankshaft
pulley, the leak may be coming from the water pump. The water pump has a
weep hole - check it for drips.
Another possibility is from the casting plugs, commonly referred to as
freeze plugs, on the side of the block.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
Coolant leak from 1990 Camry tracyf 1st & 2nd Generation (1983–1986 & 1987-1991) 5 03-28-2006 09:24 AM
92 tercel coolant leak (somewhere) chrisusvi Tercel, Paseo, Starlet, and Sera Forum 7 03-01-2006 09:02 AM
location of coolant temp sensor on 94 pickup dave42 89-95 Toyota Pickup/Hilux 10 11-17-2004 12:47 PM
TB Coolant bypass. CrawlingEye Camry & Solara Lounge 24 09-12-2004 12:03 AM
