Re: plastic-metal-lube - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-03-2007, 03:27 PM   #1 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"mark_digital©" <976-XXX@comcastnot.com> wrote in message
news:rJadnUcIxO1edVnYnZ2dnUVZ_uSgnZ2d@comcast.com...[color=blue]
> Searching around my abode for some light lubricant for a small DC motor I
> happened to spot a small unused aerosol can of Mobil 1. The motor itself
> isn't binding but the long metal shaft is. There's three speeds. At the
> lowest speed setting the shaft doesn't want to turn. The end of the shaft
> simply inserts into a mating plastic hole which is integral to the plastic
> housing.
> Mobil 1 or what would you suggest?
>[/color]
If the shaft is binding in the plastic collar, a dab of automatic
transmission fluid or silicone spray would be friendlier to the plastic than
motor oil or petroleum-based oil. You can also try removing the shaft from
the plastic and using a fine steel wool or 1000 grit sandpaper on the metal
shaft and cleaning the shaft thoroughly before re-installing it in the hole.
If the motor binds even when it is not in the plastic hole, check the
condition of the motor brushes and springs or try WD-40 on the motor itself,
avoiding getting it on the plastic.
Ray O
Old 02-03-2007, 04:56 PM   #2 (permalink)
mark_digital©
Guest
Posts: n/a
View mark_digital©'s Photo Gallery
"Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message
news:7a57d$45c4f0bf$47c2b532$7812@msgid.meganewsservers.com...[color=blue]
> news:rJadnUcIxO1edVnYnZ2dnUVZ_uSgnZ2d@comcast.com...[color=green]
>> plastic housing.
>>[/color]
> than motor oil or petroleum-based oil. You can also try removing the
> shaft from the plastic and using a fine steel wool or 1000 grit sandpaper
> on the metal shaft and cleaning the shaft thoroughly before re-installing
> it in the hole.
> itself, avoiding getting it on the plastic.
> Ray O
>[/color]
Will do. Thanks. The shaft is a elongated squirrel cage type blower which
will normally turn effortlessly with a simple brush of my finger. Low speed
consumes about 25 watts AC all told between motor and circuitry. I wanted to
avoid taking the whole unit apart but if a drop of transmission fluid will
do the trick I don't mind.
Old 02-03-2007, 09:37 PM   #3 (permalink)
Ray O
Guest
Posts: n/a
news:oYWdnRTOsNOymFjYnZ2dnUVZ_tOmnZ2d@comcast.com...[color=blue]
> news:7a57d$45c4f0bf$47c2b532$7812@msgid.meganewsservers.com...[color=green]
>> news:rJadnUcIxO1edVnYnZ2dnUVZ_uSgnZ2d@comcast.com...[color=darkred]
>>> I happened to spot a small unused aerosol can of Mobil 1. The motor
>>> itself isn't binding but the long metal shaft is. There's three speeds.
>>> At the lowest speed setting the shaft doesn't want to turn. The end of
>>> the shaft simply inserts into a mating plastic hole which is integral to
>>> the plastic housing.
>>>[/color]
>> it in the hole.
>> Ray O
>>[/color]
> speed consumes about 25 watts AC all told between motor and circuitry. I
> wanted to avoid taking the whole unit apart but if a drop of transmission
> fluid will do the trick I don't mind.[/color]
ATF is friendly to plastic and rubber. Use an old-fashioned oil can or a
syringe or eye dropper to apply the ATF.
Good luck!
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
*DIY* Stock Stereo LED color change - (Lots of PICS) - 56k no way SnakeyeS Camry & Solara Lounge 56 12-09-2010 03:51 AM
Toyota Metal Headgasket Luspher 3rd & 4th Generation (1992–1996 & 1997–2001) 3 09-08-2006 12:15 AM
Jiffy Lube stevenh563 Off Topic 21 06-16-2006 12:50 AM
FS: 500 pc 11.5 poker set w/ cards and metal case Quach88 Non-Automotive 0 06-04-2005 09:04 AM
DIY Cold-Air Intake bondobondo Hardcore Tech and Competition 40 11-24-2004 02:41 PM
