door detent spring thingy??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-03-2007, 04:49 PM   #1 (permalink)
Pete Moss
Guest
Posts: n/a
View Pete Moss's Photo Gallery
The thingy that holds the door open at different widths (sliding spring
bar thingy) on my Camry has stopped working, so now the door just
flings all the way to maximum open.
Is there a broken spring or something there I could possibly replace, or
do I have to buy the whole assembly and replace it? I'm not familiar
with how the mechanism works and it's too cold out to take it apart and
figure it out myself before I ask someone for advice from the warmth of
their computer chair.
Any advice appreciated.
Old 02-03-2007, 05:11 PM   #2 (permalink)
Art
Guest
Posts: n/a
View Art's Photo Gallery
Re: door detent spring thingy???
You didn't say what year.
On some a rubber insert in the hole where the detent arm slides in and out
does the squeezing job. Maybe yours ripped and fell out. I don't know how
they get replaced. Probably an easy job though.
"Pete Moss" <spraghnum@yahoo.com> wrote in message
news:spraghnum-2200E1.16493203022007@news.iglou.com...[color=blue]
> Any advice appreciated.[/color]
Old 02-03-2007, 09:46 PM   #3 (permalink)
Pete Moss
Guest
Posts: n/a
In article <fM7xh.20332$w91.17037@newsread1.news.pas.earthlink.net>,
"Art" <begunaNOSPAMPLEASE@mindspring.com> wrote:
[color=blue]
> news:spraghnum-2200E1.16493203022007@news.iglou.com...[color=green]
> > Any advice appreciated.[/color][/color]
It's a 2004
Old 02-04-2007, 08:01 AM   #4 (permalink)
Pete Moss
Guest
Posts: n/a
In article <7f9ab$45c548c1$47c2b532$9834@msgid.meganewsservers.com>,
"Ray O" <rokigawaATtristarassociatesDOTcom> wrote:
[color=blue]
> The door check is made up of 2 wedge-shaped pieces of rubber that squeeze
> the bar that slides in and out of the forward door frame, and the cold may
> have made the rubber so hard that it no longer grips the bar or the rubber
> may have broken off. If you want to fix it yourself, purchase a replacement
> door check at your local dealer, remove the inner door panel, and reach
> through the opening to unbolt the door check (IIRC, held in place with 2 10
> mm bolts). Remove the roll pin from where the bar attaches and pivots on
> the door jamb and push the sliding bar all the way through the opening at
> the front of the door frame. Remove the bar and old door check, thread the
> bar through the new door check, and reverse the process.[/color]
Super! Thanks very much for your reply. That's exactly what I'll do.
Old 02-04-2007, 10:54 AM   #5 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
news:spraghnum-16346E.08010404022007@news.iglou.com...[color=blue]
>[color=green]
>> news:spraghnum-2200E1.16493203022007@news.iglou.com...[color=darkred]
>> > or
>> may
>> rubber
>> replacement
>> 10
>> the
> Super! Thanks very much for your reply. That's exactly what I'll do.[/color]
You're welcome!
One more little trick: - after you install the new door check, give it a
liberal dose of lithium grease or even better, silicone grease (used for
plumbing fixtures), to delay the onset of the squeaking before you
re-install the inner door panel. When people hear the door squeaking and
groaning, they think it is the hinges making the noise when it is often the
rubber on the door checks. The bar acts like a violin bow, and as it rubs
against the rubber, the rubber vibrates and the door's cavity acts like the
inside of the violin, amplifying the sound.
Good luck!
Ray O
Old 02-04-2007, 02:46 PM   #6 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
I always thought that spring thingie was there to keep the door open, not
keep the door from opening. When you open the door, the detent thing holds
the door for you so the door does not close itself while you use your hand
and arm to do other things.
Old 02-04-2007, 05:50 PM   #7 (permalink)
Ray O
Guest
Posts: n/a
"Jeff Strickland" <crwlr@verizon.net> wrote in message
news:HKqxh.370$384.94@trnddc05...[color=blue]
>[/color]
On a Toyota, the door check holds the door open and keeps it from flinging
open.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
struts abew330 Camry & Solara Lounge 2 02-14-2007 02:38 PM
Is the upper spring cushion part of the strut boot on front struts? green94camry 3rd & 4th Generation (1992–1996 & 1997–2001) 3 09-15-2006 10:01 PM
1999 2WD Tacoma Coil Spring Compressor bill70 Hardcore Tech and Competition 2 09-23-2005 04:02 PM
confusing on coilover spring yafayu General Discussion 1 06-24-2005 10:19 AM
Change in timing tension spring? awmccready Camry & Solara Lounge 5 11-26-2004 11:15 PM
