How do I externally adjust/tune the 2 barrel carburetor on 85 Corolla - Toyota Nation Forum : Toyota Car and Truck Forums
post #1 of 11 Old 02-08-2007, 01:20 PM
marklum@hotmail.com
Guest
Posts: n/a
Quoted: Post(s)
Corolla? My SR5 has the SOHC 4AC engine and is rear wheel drive. USA
Federal emissions model.
I don't know the right order to adjust everything, nor even what the
optimal setting is.
Problems:
1. Very hard starting when cold, won't accept throttle until engine is
fully warmed up.
2. Hesitates/misses at low RPM when throttle is opened, especially
just off idle, like when pulling away from a stop sign (engine
sometimes stalls unless throttle is applied VERY slowly, especially in
cold weather).
3. Engine knocks and pings on gas with octane rating below 91 (when 87
octane
should be sufficient.)
4. I have access to a timing light, and I see the marks on the
flywheel pully and block, but am not sure how to correctly check the
timing, because I plugged two vacuum hoses that were attached to the
distributor advance unit and the timing was unchanged (and it should
have dropped back), so I must be missing something. How do I
correctly set the timing?
What I've done:
Car has only 100k miles, and has excellent compression (about 170 psi
on all cylinders).
I replaced: ignition components (plugs, wires, rotor, distributor),
fuel and air filtes all recently replaced with aftermarket parts. I've
tried some fuel system cleaner that I added to the tank. Exhaust
system appears fine, muffler is new. Everything else seems to be
original.
Here's what I view on the carb:
There's a screw that is on the opposite side of the carb from the
throttle cable. It seems to be a "stop" for when the throttle is
closed, adjusting the amount the throttle is open when the engine is
not running. How is this to be adjusted?
There's a slotted screw that is threaded into the body of the carb
near where the cable assembly is connected,( on the adjacent side of
the carb) This seems to adjust the idle. How is this to be adjusted?
I drilled out the plug over the slow speed mixture screw, but don't
know the correct setting.
I see the high speed idle screw is part of the throttle cable linkage.
When/how is this to be adjusted?
I'm unemployed right now, so if your wisdom can allow me to fix this
myself, I would be most grateful for the savings (versus taking it to
the dealer).
Thanks in advance!
post #2 of 11 Old 02-08-2007, 03:49 PM
Ray O
Guest
Posts: n/a
Quoted: Post(s)
Re: How do I externally adjust/tune the 2 barrel carburetor on 85 Corolla
<marklum@hotmail.com> wrote in message
news:1170958845.208881.327190@a75g2000cwd.googlegroups.com...[color=blue]
> optimal setting is.
> Problems:
> fully warmed up.
> cold weather).
> octane
> What I've done:
> on all cylinders).
> original.
> the dealer).
> Thanks in advance!
>[/color]
It sounds like the choke is either not setting or pulling off prematurely.
In case you are not aware, when the engine is cold, depress the throttle
pedal fully to the floor once and release to set the choke. When the engine
starts, it should be at high idle until you kick the idle speed down.
I can't remember the last time I had to set the idle speed on a carb, but
IIRC, the correct method for your car is called the "lean drop" method. You
might want to try searching to see if you can find it somewhere.
Unplugging the vacuum advance from the distributor should not change
ignition timing at idle. There should be a sticker under the hood that
shows proper ignition timing, IIRC, around 10 degrees BTDC when warmed up.
Ray O
post #3 of 11 Old 02-08-2007, 10:35 PM
larry moe 'n curly
Guest
Posts: n/a
Quoted: Post(s)
[email]marklum@hotmail.com[/email] wrote:
[color=blue]
> Federal emissions model.[/color]
[color=blue]
> fully warmed up.[/color]
[color=blue]
> cold weather).[/color]
[color=blue]
> octane should be sufficient.)
> correctly set the timing?[/color]
For the 1986 Corolla, the timing is 13 degs. BTDC with all the hoses
connected, about 5 degs. BTDC with one of the hoses disconnected and
plugged. Some distributors have two hoses, others have three, and the
hose to remove is not the one at the end of the vacuum advance unit.
[color=blue]
> original.[/color]
[color=blue]
> not running. How is this to be adjusted?[/color]
I don't remember seeing that on my carb, but it seems like the stop
for the throttle plate, in which case it should probably hold it open
just barely enough to keep it from scraping its bore.
..[color=blue]
> near where the cable assembly is connected, (on the adjacent side of
> the carb) This seems to adjust the idle. How is this to be adjusted?[/color]
If it's a screw that angles upward slightly, it's the main idle speed
adjustment. Is it about 3" long with a head big enough to allow for
finger adjustment? For 1986 Corollas it's set to 650 RPM for manual
transmissions, 750 RPM for automatics.
[color=blue]
> know the correct setting.[/color]
After the engine is fully warmed up, adjust the idle speed screw for
700 RPM, the idle mixture screw for maximum RPM, then repeat both
adjustments until turning the mixture screw won't increase the RPM.
Then turn the mixture screw in to lean out until the speed drops to
650 RPM.
[color=blue]
> When/how is this to be adjusted?[/color]
Engine warmed up, stop engine, hold throttle open, close choke plate
completely by hand, release throttle, start engine without touching
gas pedal. Turn the fast idle screw for 3,000 RPM.
ToyotaNation.com has great FAQs and forums, [url]www.autozone.com[/url] has some
manuals online for free (if you can't find the SR5, check the Toyota
Corolla or Chevy Nova, which have the same engine and virtually the
same carburetor). Some libraries and tech schools carry factory or
Mitchell manuals, which are much better than the Chilton's and Haynes
books, especially when it comes to stuff like carbs and fuel systems.
post #4 of 11 Old 02-09-2007, 11:25 PM
marklum@hotmail.com
Guest
Posts: n/a
Quoted: Post(s)
On Feb 8, 10:35 pm, "larry moe 'n curly" <larrymoencu...@my-deja.com>
wrote:[color=blue]
> mark...@hotmail.com wrote:[color=green]
> > How do I externally adjust/tune the 2 barrel carburetor on 85[/color][/color]
<snip>
Some libraries and tech schools carry factory or[color=blue]
> books, especially when it comes to stuff like carbs and fuel systems.[/color]
Thanks for all that great info; I really do appreciate it! A local
library did have a Haynes, but it covered a lot of years, and the
carbureter it showed and described was completely different from the
one on my 1985. I never thought of calling the local trade school and
inquiring about a better manual. Great tip!
Because I found a lot of posts suggesting Japanese/OEM ignition parts,
I'm going to get rid of the Bosch plugs I put in it and use some
Japanese ones instead.
I did get my high idle corrected by following advice received here.
Thanks again.
-Mark
post #5 of 11 Old 02-09-2007, 11:41 PM
marklum@hotmail.com
Guest
Posts: n/a
Quoted: Post(s)
Thanks for the advice, Ray, et.al. I did get my high speed idle and
choke adjusted, with the help from this forum. Seems to start about
as well as I can expect for an old car in 20 degree weather.
I have to keep the idle up around 1000rpm for it to be smooth and not
stall, and the slow speed adjusting screw (turned out to avoid
stalling) is rich enough to turn the plugs a light brown (more than
just tan), so something isn't right. When I come to a stop the car
still occasionally stalls.
Without disconnecting any hoses or anything, the timing light shows it
is advanced way beyond the scale (which goes to 20 degrees btdc), so
I've got to find out how to set this timing. I tried retarding it a
little to see what happened, and the car wanted to stall when pulling
away from a stop.
The compression ratio is only like 8.5:1 so there should be no
problem with low octane fuel, yet it still knocks and pings some on 91
octane fuel.
Thanks again, and keep the good advice flowing.
-Mark
post #6 of 11 Old 02-10-2007, 12:45 AM
Ray O
Guest
Posts: n/a
Quoted: Post(s)
news:1171082492.889577.149870@p10g2000cwp.googlegroups.com...[color=blue]
> away from a stop.
> octane fuel.
> -Mark
>[/color]
The engine is probably knocking and pinging because the ignition timing is
advanced too far. Once you get the ignition timing set correctly, the
knocking should subside.
Disconnect and plug the vacuum hoses to the EGR valve and see if the car
idles better when idle speed is set correctly. If it does, the EGR is
opening too soon or not closing properly. You can try removing the EGR
valve and seeing if you can clean out some of the black crusty stuff inside.
Ray O
post #7 of 11 Old 02-10-2007, 03:06 AM
larry moe 'n curly
Guest
Posts: n/a
Quoted: Post(s)
[email]iwhtcimtlfmwmaomopw@yahoo.com[/email] wrote:
[color=blue]
> Dang...these things really do last don't they.[/color]
But not that little plastic clip that holds the prop rod for the
hood! I've had to replace it 4-5 times.
It's too bad the thing has only 75 HP. :(
post #8 of 11 Old 02-10-2007, 03:07 AM
larry moe 'n curly
Guest
Posts: n/a
Quoted: Post(s)
[color=blue]
> Japanese ones instead.[/color]
I'd get the cheapest Densos available because that's what Toyota
installed at the factory, and Toyota owns part of Denso.
[color=blue]
> I did get my high idle corrected by following advice received here.[/color]
Here's information about some other adjustments. I wouldn't tweak
the throttle positioner or throttle position switch settings without a
tachometer, unless they're really out of whack, but the throttle
position switch should trigger when the throttle is opened just
slightly, and the throttle positioner should make the idle increase
noticeably but not by a huge amount. I once misadjusted the latter,
and the engine would briefly rev up a lot when I took my foot off the
gas pedal, causing the car to speed up instead of slow down. :(
Adjust carb mixture: [url]http://farm1.static.flickr.com/[/url]
156/385280264_6e713d62c7_b.jpg
Adjust regular and idle speeds: [url]http://farm1.static.flickr.com/[/url]
124/385279726_c0765cd887_b.jpg
Adjust throttle positioner: [url]http://farm1.static.flickr.com/[/url]
158/385279721_a6f0b76df5_b.jpg
Throttle positioner diagraem: [url]http://farm1.static.flickr.com/[/url]
186/385279724_4184ca0b52_b.jpg
Adjust throttle position switch: [url]http://farm1.static.flickr.com/[/url]
151/385285108_4705b4413b_b.jpg
Vacuum diagram: [url]http://farm1.static.flickr.com/183/385279725_081677c7fe_b.jpg[/url]
post #9 of 11 Old 02-11-2007, 11:27 PM
Wayne
Guest
Posts: n/a
Quoted: Post(s)
On 10 Feb 2007 00:07:46 -0800, "larry moe 'n curly"
<larrymoencurly@my-deja.com> wrote:
[color=blue]
>marklum@hotmail.com wrote:
>[color=green]
>[color=green]
>[/color]
In two of the jpg pics you posted links to, you have handwritten a
note re an "acceleration hesitation modification". Can you explain
what you did to, I presume, eliminate or improve the hesitation
problem?
Thanks, Wayne
post #10 of 11 Old 02-12-2007, 01:27 AM
larry moe 'n curly
Guest
Posts: n/a
Quoted: Post(s)
Wayne wrote:
[color=blue]
> <larrymoencurly@my-deja.com> wrote:[/color]
[color=blue][color=green]
> >Vacuum diagram: [url]http://farm1.static.flickr.com/183/385279725_081677c7fe_b.jpg[/url][/color]
> problem?[/color]
There are three overlapping technical service bulletins from Toyota
about this, and they make a noticeable difference, although they won't
turn a 70-75 HP engine into one that gives neck-snapping
acceleration. :(
Bulletin 11-21-86, issued Nov. 1986, to reduce hesitation during warm-
up, applies to 1984-1986 FWD Corollas and consists of simply adjusting
the float so that the fuel level is at the upper allowed range in the
sight glass and then readjusting the mixture as described in one of
the figures. BTW for 1984 and 1985 Corollas with automatic
transmissions, the idle speed should be 800 RPM, not 750 as with 1986
and 1987 models.
Bulletin Volume 8, Section Engine, # 018, issued May 1986 for
1985-1986 FWD Corollas, consists of installing a restrictor in the
vacuum line between the R port of the EGR vacuum modulator and the EGR
port on the carburetor. Also the ignition timing is changed from 5
degs. BTDC to 3 degs. BTDC while a certain hose is disconnected and
plugged.
Bulletin Vol. 8, Section Engine #030, issued Feb. 1987 for 1985-1987
FWD Corollas with automatic transmissions, involves making the above
changes plus also changing the accelerator pump arm, main carb jet,
coil spring in the vacuum diaphram that opens the secondary port, and
possibly also adding a restrictor or one-way valve between the Q port
of the EGR vacuum modulator and the EGR valve, but nothing is
mentioned about the latter in the text, only in one diagram (black
side of the restrictor/valve goes toward Q port, light-colored side to
EGR valve).
post #11 of 11 Old 02-12-2007, 09:49 PM
Wayne
Guest
Posts: n/a
Quoted: Post(s)
On 11 Feb 2007 22:27:08 -0800, "larry moe 'n curly"
[color=blue]
>Wayne wrote:
>[color=green]
>[color=green][color=darkred]
>> problem?[/color]
>acceleration. :(
>and 1987 models.
>plugged.
>EGR valve).
>[/color]
Thank you for the very detailed information! Much appreciated.
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota
User Tag List
Linear Mode Linear Mode
BB code is Off
Smilies are Off
[IMG] code is Off
« Back
