Re: Caution re the Camry 3.5 V6 fuel octane
On 15 Feb, 11:20, Moe <BubbleleL...@Fat.City> wrote:[color=blue]
> Spam away wrote:[color=green]
> > Noticing the very high compression ratio of the Camry 3.5L V6, I asked
> > Toyota how they could use the specified regular fuel.
> > Toyota confirmed to me that the stated performance will not be achieved
> > with regular fuel.
> > I've read of engine damage resulting from excessive use of too low an
> > octane fuel. A knock must occur before the timing is changed.[/color]
> If you are a mild driver, don't have to accelerate fast or climb steep
> inclines regular should be OK. If you are a balls to the wall type
> driver pay extra and go for it. The difference in fuel costs over the
> life of the car can be substantial. The cost of engine repair is also
> substantial if engine knocking occurs. I've gotten tanks of regular
> gas that knocked and then bought regular gas at the same place later and
> it didn't knock. My theory, if brake pads last 100K miles you
> probably don't need high test gasoline.[/color]
High octane fuel (all fuel i think to some extent) degrades over time
- if you go to a rarely-filled filling station you may get
significantly lower octane than you pay for.
On the costs over time issue - my car more than makes up the cost of v-
power (99 RON UK) in magically getting more mpg ! I like it!
