Re: 86 Toyota 4-door Stalling! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-15-2007, 11:17 AM   #1 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
<jweissig@gmail.com> wrote in message
news:1171556435.988793.62820@k78g2000cwa.googlegroups.com...[color=blue]
> Thanks for the info. I tried both options and I still have the same
> issue.
> 1, I used carb cleaner to clean out the carb. Didn't change the
> problem.
>[/color]
Look into the carburetor when the engine is running and make sure that the
fuel coming out of the justs is a fine mist and not dripping.
[color=blue]
> 2, EGR, I disconnected all the vacuum hoses and tested the EGR. It had
> some crap in it but nothing was blocking the air flow and it seemed to
> be working fine. I fired the car up after I cleaned it out and nothing
> changed. I talked to one of my roommates he we fabricated a piece of
> metal to cover the intake from the exhaust. I pulled everything off
> and tried again with it completely block and still the same problem.
> Nothing changed.
> I should mention that when the car is cold is seems to work fine for
> about 5 minutes till the idle comes down and then it wants to stall.
> It'll rev really high then almost like its going to stall and then rev
> up again. It'll do this for a while till it finally stalls.
> Do you have any other suggestions? Do you think its a fuel filter or
> bad gas or something?
> Thanks,
> - Justin
>[/color]
It is not a fuel filter or bad gas because the engine would not rev up. I
think the problem is electrical or vacuum-related.
Check all of the vacuum hoses to make sure none are cracked or disconnected.
If you have a vacuum gauge, measure vacuum at idle. There should be at
least 14 in Hg.
There should be a sight glass on the side of the carburetor somewhere with
metal tabs about halfway up the glass. Fuel level should be even with the
tabs.
I don't remember when the Tercel got the variable venturi electronic
carburetor, but if that is what your car has, they are a nightmare to adjust
or fix.
If those fixes don't work, it is time to bite the bullet and take it to a
competent technician for diagnosis and repair.
Ray O
Old 02-15-2007, 11:33 AM   #2 (permalink)
jweissig@gmail.com
Guest
Posts: n/a
View jweissig@gmail.com's Photo Gallery
Awesome, thanks. I'll check these and out keep you posted.
- Justin
On Feb 15, 9:17 am, "Ray O" <rokigawaATtristarassociatesDOTcom> wrote:[color=blue]
> <jweis...@gmail.com> wrote in message
>[color=green]
> > issue.[/color]
>[color=green]
> > problem.[/color]
>[color=green]
> > Nothing changed.[/color]
>[color=green]
> > up again. It'll do this for a while till it finally stalls.[/color]
>[color=green]
> > bad gas or something?[/color]
>[color=green]
> > Thanks,
> > - Justin[/color]
> least 14 in Hg.
> tabs.
> or fix.
> Ray O
> (correct punctuation to reply)[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
TOYOTA - an Obsession, a Religion or just Madness? RAV4EVR General Discussion 70 02-22-2008 10:07 AM
I just found this article your comments on this? dario Camry & Solara Lounge 18 07-26-2005 09:39 PM
Ford, Nissan license Toyota hybird technology EKam Toyota News 1 01-30-2005 03:25 PM
