help, celica stats - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-19-2007, 01:26 PM   #1 (permalink)
stocky
Guest
Posts: n/a
View stocky's Photo Gallery
help, celica stats
ive recently bought a celica st202 automatic can anyone give me some
stats on this engine
cheers :D
Posted at author's request, using fully moderated [url]http://www.AutoBoardz.com/Toyota-Celica-forum-86.html[/url] interface
Old 02-19-2007, 01:37 PM   #2 (permalink)
Coyoteboy
Guest
Posts: n/a
View Coyoteboy's Photo Gallery
Re: help, celica stats
If you can tell me what it was badged as - ST202 covers the body code
primarily, there were a few versions under it with different engines IIRC.
"stocky" <none@000.com> wrote in message
news:978829_c7d3949523f02220c713ea712ba8f59a@autoboardz.com...[color=blue]
> cheers :D
> [url]http://www.AutoBoardz.com/Toyota-Celica-forum-86.html[/url] interface[/color]
Old 02-19-2007, 01:39 PM   #3 (permalink)
Coyoteboy
Guest
Posts: n/a
Celica GT-i
Official name Celica GT-i
Generation 6
Model Code ST202
Chassis Code
release date 1994
final date 1999
Engine
Code 3S-GE
Aspiration natural
Cylinders 4
Valves/Cylinder 4
Valves 16
displacement 1998cm3
Bore 86.0mm
Stroke 86.0mm
Bore/Stroke Ratio 1.000
Compression ratio 10.0:1
Power output 129kW@7000rpm (173bhp)
Torque output 186Nm@4800rpm (137lb/ft)
Power over displacement 64.565kW/1000cm3 (86.583bhp/l)
Torque over displacement 93.093Nm/1000cm3 (68.662lb/ft/l)
Fuel Unleaded
Alternator 840W DC, max current 70A
Battery 12V 48Ah
Head material alloy
Block material cast iron
Ignition electronic
Injection electronic
Cooling injected liquid
Cams two overhead
Cam drive belt
Drivetrain
Transmission 5 speed manual
gear ratios
Final drive
Performance
0-100km/h (62mph) 7.9s
Top speed 220km/h (137mph, 367454furlong/fortnight)
Power per Tonne 111.688kW (149.776bhp)
Weight per Power 8.953kg/kW (6.677kg/bhp)
Fuel Economy
Motorway 7.3l/100km (38.7mpg (UK), 32.2mpg (US), 649579rods/hogshead)
City 12.3l/100km (23.0mpg (UK), 19.1mpg (US), 385522rods/hogshead)
Overall 9.1l/100km (31.0mpg (UK), 25.8mpg (US), 521091rods/hogshead)
Measurements
Length 4.420m (15' 6.0")
Width 1.750m (6' 8.9")
Height 1.305m (4' 3.4")
Wheel Base 2.540m (8' 4.0")
track width Front: 1.510m
Rear: 1.490m
mass 1155kg
fuel capacity 60l
oil capacity 4.5l
coolant capacity 7.0l
Drag coefficient
Steering Wheel Rotations
Brakes
Brake System Features powered brakes
Front ventilated discs
Rear discs
Suspension
Mount Front: independent, McPherson
Rear: independent
Shock absorbers telescopic gasfilled
Stabilisers front and rear
Tyres
Rim size 7jx15
Tyre size 205/55R15 87V
Old 02-19-2007, 01:40 PM   #4 (permalink)
Coyoteboy
Guest
Posts: n/a
Celica GT-i
Generation 6
Model Code ST202
Chassis Code
release date 1994
final date 1999
Engine
Code 3S-GE
Aspiration natural
Cylinders 4
Valves/Cylinder 4
Valves 16
Bore 86.0mm
Stroke 86.0mm
Fuel Unleaded
Battery 12V 48Ah
Head material alloy
Ignition electronic
Cams two overhead
Cam drive belt
Drivetrain
gear ratios
Final drive
Performance
Fuel Economy
Measurements
Rear: 1.490m
mass 1155kg
fuel capacity 60l
oil capacity 4.5l
Drag coefficient
Brakes
Rear discs
Suspension
Rear: independent
Tyres
Rim size 7jx15
BB code is Off
Smilies are Off
[IMG] code is Off
1980 Celica Camry GT HomeGrown 1st & 2nd Generation (1983–1986 & 1987-1991) 5 03-05-2007 09:40 PM
Celica springs on Camry nogard Camry & Solara Lounge 9 06-22-2006 02:11 AM
