no heat - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-19-2007, 01:29 PM   #1 (permalink)
89cress
Guest
Posts: n/a
View 89cress's Photo Gallery
no heat
the car is 89 Cressida. Its ac works great but its heater in not. All
the vents and controls work fine. Radiator is full of coolant. All I
get is cold air coming out the vents. I’ve been working on this since
last winter, I gave up now. So please help if you can. Thanks.
89Cress
Posted at author's request, using [url]http://www.AutoBoardz.com[/url] interface
Articles individually verified to usenet standards. Visit URL to contact author/report abuse
Thread archive: [url]http://www.AutoBoardz.com/heat-Toyota-ftopict206808.html[/url]
Old 02-19-2007, 01:41 PM   #2 (permalink)
Coyoteboy
Guest
Posts: n/a
View Coyoteboy's Photo Gallery
Re: no heat
"89cress" <none@000.com> wrote in message
news:979640_e8f3e542b76afb8ac93b7514df4e2156@autoboardz.com...[color=blue]
> get is cold air coming out the vents. I've been working on this since
> 89Cress[/color]
Have you flushed the heater matrix? Checked its not bypassed? Bled the
system properly so you dont have air locks? Checked the water control valve
is connected and functional?
Old 02-20-2007, 11:43 AM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: no heat
news:979813_9e36d1862cea257a487e0b40fd0c0cdf@0000.com...[color=blue]
> How do I flush the heater matrix? What is the proper way to bleed the
> system? Here is what I do: I jack the front end only up as high as
> the jacks can go, then run the engine, open the radiator cap, then
> fill with coolant when the level drops.
>[/color]
When you fill the radiator, do so with the car level, not up on jacks.
Flush the heater matrix (called a heater core in the U.S.) by setting the
interior temperature to full hot while flushing the rest of the cooling
system. Because of environmental laws, I recommend having the cooling
system professionally flushed.
[color=blue]
> I check and I think the water valve is open or closed properly.
>[/color]
Set the heat to full hot and see if the heater control valve opens. If you
are not sure if the heater control valve is moving, open the hood and follow
the heater hose along the firewall to find the valve, and watch the lever on
the valve move while someone changes the interior temperature from full hot
to full cold.
Ray O
Old 02-25-2007, 03:27 AM   #4 (permalink)
89cress
Guest
Posts: n/a
Re: Re: no heat
Ray O,
I did it again last night your way, still no heat. Before when the
heater was working, I heard some clicking sounds, like a sound of the
solenoid clicking, or so, somewhere under the dash, on the
driver-side, whenever I turned on the heater. Now I don’t hear it any
more, and the hear is not working. Is there really a solenoid valve,
(besides the water valve) along the path of the heater circuit?
"Ray O" wrote:[color=blue]
> news:979813_9e36d1862cea257a487e0b40fd0c0cdf@0000.com...[color=green]
> > How do I flush the heater matrix? What is the proper way to[/color]
> bleed the[color=green]
> > system? Here is what I do: I jack the front end only up as[/color]
> high as[color=green]
> > the jacks can go, then run the engine, open the radiator[/color]
> cap, then[color=green]
> >[/color]
> on jacks.
> setting the
> the cooling
> cooling
>[color=green]
> > I check and I think the water valve is open or closed[/color]
> properly.[color=green]
> >[/color]
> opens. If you
> hood and follow
> watch the lever on
> from full hot
> to full cold.
> Ray O
> (correct punctuation to reply)[/color]
Old 02-25-2007, 09:32 AM   #5 (permalink)
Ray O
Guest
Posts: n/a
Re: Re: no heat
news:981650_5d3ef0b36f0cf575b5657156a25e4052@autoboardz.com...[color=blue]
> Ray O,
> driver-side, whenever I turned on the heater. Now I don't hear it any
> (besides the water valve) along the path of the heater circuit?[/color]
AFAIK, there is no solenoid valve in the path of the coolant. The coolant
flow is controlled by the hot water valve on the firewall.
The clicking sounds you are hearing are probably the actuators for the vent
dampers and blend doors or relays for the fan and resistors. Even if the
fan is not working, the heater valve should open.
Did you check to see if the heater valve on the firewall is opening and
closing? Assuming it is, then is the return hose from the heater core warm
or is it cold? Check the return hose to make sure it is not collapsed.
Ray O
[color=blue]
> "Ray O" wrote:[color=green]
> > news:979813_9e36d1862cea257a487e0b40fd0c0cdf@0000.com...[color=darkred]
> > bleed the[color=darkred]
> > high as[color=darkred]
> > cap, then[color=darkred]
> > >[/color]
> > on jacks.
> > setting the
> > the cooling
> > cooling
> >[color=darkred]
> > properly.[color=darkred]
> > >[/color]
> > opens. If you
> > hood and follow
> > watch the lever on
> > from full hot
> > to full cold.
> > Ray O
> author/report abuse
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
1988 Camry Heater Cycles Between Heat & No Heat lashby 1st & 2nd Generation (1983–1986 & 1987-1991) 30 12-11-2006 03:29 PM
help no heat imasmrt1 Celica Forum 5 11-18-2006 10:38 PM
its cold, how's your heat? mazdaverx7 3rd & 4th Generation (1992–1996 & 1997–2001) 16 10-26-2006 07:34 AM
2005 Tacoma Double Cab NO HEAT tooley 2nd Generation (2005+) 2 02-01-2006 05:38 PM
No heat, and it's damn cold. yodanoob Archived Corolla threads 3 11-23-2005 08:36 PM
